I needed to exchange my casio phone for another. I kept the same battery. When I try to pair my phone states to PLACE THE DEVICE YOU ARE CONNECTING TO IN DISCOVERABLE MODE. I don't have such a mode that I am aware. I place the phone in front of the parrot mini slim and go through the steps, and my phone has found the parrot it asks to pair I press OK to pair then the phone askes ENTER PASSKEY. I don't know what that is. The phone tells me pairing failed when I attempt to enter a new passkey number since I don't know the old one. What should I do. Thank You.
Casio is a manufacturing company; you do not say what the device is. If it is run by battery perhaps it has died and needs re charging. Or even if it is dead, a new battery. But Casio what?
If the Bluetooth versions are different it means the two will not pair, you need a device that shares the same versions of Bluetooth for easy compatibility with your phone. You will need to trade that for a compatible version of Headsets.
The pin or the passkey is "0000". To pair the SGH-T749 (Highlight) handset with a Bluetooth Device follow the steps below:
Place the Bluetooth device in discoverable mode
From the standby screen, press on Menu
Press on Settings
Press on Bluetooth
Search for the Bluetooth device by pressing on Search, located at the bottom
Press on Yes to Activate Bluetooth and start the search
Press on the desired Bluetooth Device (if not shown press on the left or right arrows until displayed)
If prompted, press the Passkey "0000" then press on OK
You will get a brief message stating connecting followed by connected, if prompted press OK again
Note: The first time you try to pair with another handset, you and the owner of the other handset must enter the same PIN. Once the handsets have been paired, you will not need to use the PIN again.
Normally, two
Bluetooth
devices must be paired before they can exchange data. The term pairing usually
means that two devices are exchanging protected passkeys. Once paired, all
information sent over the Bluetooth link is
encrypted and will only be able to reach devices that are authorized to do so by
the pairing process. In certain instances it may not be necessary to conduct the
pairing procedure. For example, when exchanging business cards between two
mobile phones it may be too cumbersome to pair with a password. Usually there is
a setting in the device, in which you can set a lower level of security.
you might need to check the bluetooth device you are connecting to is working and if it is turn it off and try it again, if no luck turn them both of and disconnect any additionals such as battery sim etc for a minute and switch them both on again
please try to powercycle your phone... turn it off and remove the battery. make sure your headset is fully charged... the indicator light should be in steady blue before pairing it
You Need To Type In A 4 Digit PassCode To Get Through To Another BlueTooth Device. Pairing Bluetooth Phones Is Kind Of Complicated. If You Are Pairing 2 Phones... Here Are The Steps:
1.) Find The Other Phone By Searching For It On BlueTooth
2.) Select The Device/Phone You Want To Pair With
3.) Enter The Last 4 Digits Of The Phone Your Trying To Pair With's Phone Number
4.) The Other Phone Should Be Asked If It Wants To Pair With Your Phone, Say Yes
5.) Type In The Last 4 Digits Again Of The Phone Your Trying To Pair With's Phone Number, Except This Time ON The Phone You Are Trying To Pair With
6.) You Should Get A Paired Successful
Pairing With Any Other BlueTooth Enabled Device:
1.) Search Through BlueTooth For The BlueTooth Enabled Device You Want To Pair To
2.) Select The Device You Want To Pair With
3.) Read The Instruction Manual That Came With The BlueTooth Device You Are Trying To Pair With, You Should Find A Pair Key In There Somewhere
4.) Enter The Passkey You Found (OR Already Know) And You Should Be Ready To Go
If All Else Fails, The BlueTooth Is Obviously Broken On Your Phone... Exchange It For A New One
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
