Question about Olevia LT27HVX 27 in. LCD Television
Settings I bought this TV from a hotel sale. It didnt come with the manual and i cant figure out how to unlock or change the settings. Channel 3 worked but then my dad touched something in the menu and i cant get it back. Douse anyone know what i can do?
Press source on the TV, then use the up down arrows to make the new selection and press the volume to make the selection. If you have the remote press the TV/Video button to make the selections.
Posted on Sep 05, 2009
Remove hotel lock
You have to get into its Service Menu option to unlock Hotel Mode. Contact any service technician. They only can do it, as entering into service mode, and adjust data values there; without any knowledge about it; might make the TV irreparable.
Jul 30, 2012 | Sanyo 21MT4 21" TV
I have a Phillips Tv That I have bought off of my employer (Hotel Industry) with the Model # 32HF7544D/27 and I'm unable to get it programmed to channel 73 which is what my Satalite company uses (
Hotel sets use a special remote with specific instructions--you need to get that remote and the instructions---hotel knows that..........
Apr 08, 2012 | Televison & Video
Bought new samsung dvd/vcr. have an older admiral tv with just a cable hole. this is the second tv on a dish network, so this tv only has a cable, the box is in the living room. so how do I hook this...
The easiest way to make it work is to:
1- run your cable into your new VCR to CATV IN.
2-Your VCR should have come with a short length of cable. Connect it from the OUT jack to the TV.
3- Set the TV to either channel 3 or 4- you need to check the VCR manual to see which channel you have to use. Some VCR's have a small switch labeled "channel select"- if so, set it and your TV to the same channel... your choice.
4- Leave your TV on the channel you set above all the time. You will now change your channels using your VCR. You will be able to record whatever you are watching.
Feb 12, 2011 | Televison & Video
I have a Zenith Tv that I bought from a resale store after it had been used by a hotel. When the hotel had owned it they had programmed it to return to a specified channel every time that it is turned off...
there should be an auto program on the menu, but you can also download the complete manual for this model here http://www.retrevo.com/support/Zenith-B27A11Z-TVs-manual/id/277dj086/t/2/
Jan 13, 2011 | Zenith B27A11Z 27" TV
Tv seems to be locked, cant access the program settings has it got a hotel lock?
hi,
u can remove the lock by fallowing settings.
1. press menu button and select channel and press enter.
2. select channel manager and press enter.
3. select channel lock then press enter.
4. select off and then press enter.
ok
Dec 15, 2010 | Samsung LA22A450 22 in. LCD TV
I bought a 32LC5DC Lg tv from an hotel auction. The side panel doesnt work. The thing I need to find is how to access the "setup menu" inside the regular menu. I can get into the regular menu just fine,...
The only thing that would cause this is a lock!
If you ever forget your password, key in ‘7’, ‘7’, ‘7’, ‘7’
on the remote control.
If unlocking does not free up the unit menu then the unit has most likely had a software upgrade at some point to disable these functions permanently. This is normal hotel based systems in order to prevent them being used if they are stolen. In this case you will have to contact LG directly with Model no and Serial No details to get them to assist you.
Oct 01, 2009 | LG 32LC5DC 32 in. LCD HDTV
How do I unlock the tv's settings?
you should be able to go into your menu options. under channel set up. there should be an add or remove channel option and if your set has a locking feature it should be right in there that you'll find the unlock feature, Other than that, if you dont find it really the only other locking feature would be in your menu, under the parental control setting, this is another way to block and unblock channels as well, good luck. feel free to ask me any other questions you have!
Mar 24, 2009 | Zenith H27E55DT 27" TV
Unlockin all the channels
In order to get all the channels u have to have the original remote or a universal remote that has a menu button, an enter button, and directional pad (the directional pad cannot control the volume and channels it must be for navigating). push and hold the menu button, the menu will appear then disappear, once it disappears release the button and enter 9876 then press enter. a different menu will appear and it will b three black lines, one at the top of the screen, one in the middle and one at bottom. the middle line has 3 sections the first part is the item number the second part is the description and the last part is the on/off switch using either a 0 or 1. push down on the directional pad until u get to the 00 factory settings 0 and change the 0 to a 1 with the right button on the directional pad. then scroll up to 20 channel lock 0 (i think its 20, it may be like 22 but it is in the twenties for sure) and change the 0 to a 1. then go back down to the 00 factory settings and change the 1 back to 0 then turn the tv off. when u turn the tv back on it will either automatically ask u to auto tune or u will have to go to auto program to program the channels. there are like 80 different menu items, be sure not to mess with any other ones unless u know what ur doing, u could cause ur tv not to function properly or even be able to turn on.
this problem frustrated me greatly and im very happy to help whoever i can with the solution
Feb 07, 2009 | Zenith C27A24T 27" TV
Zenith Concierge hotel tv wont work with my xbox 360
I doubt the TV even has a tuner if it is designed for a hotel. It may be a "dumb" receiver, nothing else. Do to channel 2 and then press the down arrow for channel, does it flip to 138 or AV1?
Mar 19, 2008 | Zenith C27A24T 27" TV
Olevia LT27HVX 27 in. LCD Television Logo
179 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
