Question about InFocus LP 600 Multimedia Projector
LP600 - Grainy picture, very poor quality
Used projector last night for about 3 hrs with no problem. Turned it on today and picture is very grainy and visually "noisy".
Single chip DLP projectors use a spinning color wheel between the lamp and the DMD (mirror chip) to produce colors. If the wheel rotation/synchronization is disturbed, colors will not be displayed correctly.
In my case it looks like the wheel became un-synchronized, probably because the projector was dusty/dirty inside (a light senor is used to detect the wheel position), resulting in a grainy, slightly flickering image.
I simply blew out the components with a can of 'Dust-off' and, using a small tool, rotated the color wheel by hand to make sue it wasn't rubbing or jammed.
I reassembled & started the projector and the image was back to normal.
Posted on Jul 19, 2008
I used an extreme 32gb memory card with my Nikon 80 and first time ever-got grainy-poor resolution pictures. How can I improve their quality
Try changing the ISO setting from AUTO to 100. Fast ISO speeds create more grainy photos. The SD chip should not have any affect on sharpness. Either you ISO is too fast, or your shutter speed is too slow. You might also try formatting the sd chip using the menu on the camera.
Jun 10, 2014 | Computers & Internet
Finepix 410 picture grainy
You may have the ISO setting too high.
Try ISO 200
May 20, 2012 | FUJIFILM Cameras
Color went in and out, no i only get fair black and white picture often grainy
I'm assuming here that this tv is being used for analogue reception because on digital you either get a perfect picture or when the signal is weak enough, nothing at all (common when trying to use rabbits ears or in poor reception areas). Assuming analogue then, when the signal is weak (grainy or snowy picture) the colour (called chroma) is automatically turned off because grainy colour is unwatchable. This is normal. Solution, a better aerial to provide a stronger signal.
Jan 20, 2011 | Akai PDP4206EM Television
My Canon S3IS is about 4 years old. It used to
You need to check your ISO setting and the picture quality you have your camera set to. It should be at the maximum megapixels and fine quality and the ISO should be below 800 or even 400.
Jan 11, 2010 | Canon PowerShot S3 IS Digital Camera
Our church has two projectors Fron and Rear). Both are sourced from the same HP computer using SongShow Plus. The rear has an excelent picture quality. The front is very poor. The color is almost maxed out...
Using composit cable will not help better to use VGA also what hrs do you hacve on the lamps and have the projectors had their 1000Hrs service?
Marc Engineer
Mar 09, 2009 | NEC MT1075 Multimedia Projector
Very poor quality pictures; grainy.
This is easily fixed - go into MENU and you will find a picture quality Q. This is designed to go from FINE - Medium - POOR in order to enable you to take more photos on you cameras memory. Install at least a 1gb memory stick into your camera and then choose HIGHEST QUALITY you will now be able to get plenty a photos at the highest quality possible gor the camera with an 8.2 megapixal those photos should be really nice. Have Fun Lancer721
Dec 07, 2008 | Fuji Finepix J50 Digital Camera
Grainy LCD display
Are you in night mode? Sounds like you are in a high gain setting, like ISO 3200 or night mode.
Jul 17, 2008 | Canon PowerShot SD1000 Digital Camera
Grainy Pictures
This camera with the ISO set to 100 ASA, the electronic zoom turned off, and with the mode on Automatic "A", should take very good pictures.
I would give the camera to the manufacture for service, and include some samples of what the results are. It would be recomended to do this while the camera is under warranty.
Jerry G.
Apr 27, 2008 | Olympus Stylus 820 Digital Camera
Grainy Photos using Natural Light
Sounds like the 'shutter speed' as it was called is too fast.
Jun 23, 2017 | Nikon Cameras
InFocus LP 600 Multimedia Projector Logo
448 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
