Question about Magellan GPS 315 GPS Receiver
Firmware Update Fails
I'm trying to update my GPS 315 firmware from v2.02 to v3.15. The software finds the receiver and connects at the correct baud rate. The receiver screen shows "Software Upload Mode Active" and the software stays at "Creating Link". Eventually the receiver times out and turns off without any update taking place. I'm using a homemade cable that works well with easyGPS and have tried 'Expert' and 'Auto' modes at 4800 and 9600 baud. I've tried XP, WIN2K, and WIN98 with the same results. Any help is appreciated.
Thanks and regards,
Larry
I'm not sure this will help, but per Magellan (see below), the firmware update must be run twice as your firmware is earlier than version 3. I have a GPS 315 with v2.03 and can't find a cable to update mine. My GPS 315 does not appear to have a cable connection either, just a screw port on the back for a carrying strap. Was your homemade cable wireless? How did you make it?
You must follow instructions exactly to avoid corrupting your unit's flash memory.
  1. Select the .zip file and save it to your hard drive. Open the .zip file using WinZip.
  2. Connect your receiver to your PC using the PC or Power/Data Cable.
  3. Turn on the receiver and press the NAV key.
  4. Make sure the batteries are at least 50% full.
  5. Select the MAGUP executable file from your PC.
  6. Follow the instruction until you see the message Upload Complete.
  7. If your unit's software version is earlier than 3.00, you will be prompted to turn the unit on again and load the software a second time. Follow the instructions.
Posted on Dec 26, 2008
I've bought a Garmin Nuvi 215w. The gps does not display all the road names on the map. Is there any way i can update the firmware?
I don't think updating the firmware will solve the problem however if you want to try you can update the firmware by connecting your satnav to the computer and downloading webupdater from http://www8.garmin.com/support/collection.jsp?product=999-99999-27 When you have it set up it will automatically check for the latest version of software for your satnav. I don't think that will solve your problem though. The satnav will only show road names that are on the map.
Before trying to update the software try this solution first. On the satnav press Tools, then Settings, then Map. Under Map Detail press whatever it says and you'll get a list of options. Press Most. This will show the most map details and will show any roadnames that are on the map.
Jul 30, 2010 | Garmin nuvi 215 GPS Receiver
Nuvi 200 'Updating GPS Firmware 1%' Problem
there is actually a problem lots of people have with this unit and it seems in the FAQ i can find through garmin that it can take up to 30 minutes to aquire the satellites. there is no fix but if it has the option to get a additional antenna i would try so. If not id suggest a new unit.
Jun 18, 2008 | Garmin nuvi 350 GPS Receiver
Loosing signal pop up GPS Firmware update
With unit Off
plug unit into computer with usb cable
go to www.mygarmin.com to update firmware
Jun 21, 2010 | Garmin nuvi 260W GPS Receiver
Magellan triton locking up
Dan, download from jungleghost.com and reload the same firmware FORCED UPDATE software and rewrite over the firmware.
To do this just attach the GPS to the computer and turn it on and set it for Connect to PC.
Then fire up the firmware software and let it do its job.
JG
Oct 22, 2009 | Magellan Triton 500 Handheld GPS Receiver
My garmin nuvi 5000 is frozen.
You need to download and install this update (firmware). This will correct the problem. If you cannot get the system connect to the PC try installing the software directly to the SD Card.
Follow the below link to download new firmware -
http://www8.garmin.com/support/collection.jsp?product=010-00639-10
Good Luck!!
Thanks
Jul 24, 2009 | Garmin Nuvi 5000 GPS Receiver
GARMINC330
Have you tried firmware update for your gps .
If you have not tried it try to update the latest firmware .
By updating firmware your problem can be fixed .
Link for updating firmware select your model
hope this helps .
Mar 08, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin Nuvi Firmaware Update Complete, Unable to catch satellite signal
Try performing a reset of the unit. Hold down the bottom right of the touchscreen and turn the unit on. It will ask you whether you want to reset allk data. Choose yes and try again. This should solve your problem. Hope this helps.
Feb 20, 2009 | Garmin Nuvi 660 GPS Receiver
Nuvi 660 update firmware offers a g CHIP choice
Chipset "G" is an update of the GPS firmware for the SiRFstarIII receiver in the flip up antenna. I would update the firmware because it has updates to help improve satellite acquisition.
- Jim
Aug 18, 2008 | Garmin Nuvi 660 GPS Receiver
Magellan Roadmate 360?
There should be a firmware update, i will try to find it
Mar 29, 2008 | Magellan RoadMate 360 GPS Receiver
Magellan GPS 315 GPS Receiver Logo
452 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
