Thinkpad 380Z need to reset the bootup sequence
When I press the F1 key during startup I get the EASY SETUP screen. Opening the CONFIG window I need to set the options in NETWORK and QUICK BOOT so that the computer looks first to the floppy and then to the harddrive to boot - just like it did before I screwed around with it. I assume after setting these options I then hit INITIALIZE to save the settings. Would appreciate it if someone could check their 380Z EASY SETUP screen and let me know. I recently upgraded my 380Z with 128MB of memory and a 20GB, 5400RPM HDD - what a difference! Be happy to give you the 64MB of memory and 6GB, 4200RPM HDD (fresh load of XP PRO not including SP2) that I no longer need for the help. If you like email jnappi@embarqmail.com with a time I can call you. Should be easy if we worked over the phone with both computers on. THZ, Joe
  • jcn1 Jul 19, 2008
    SOLVED IT - NOT TOO HARD AFTER YOU FIGURE OUT WHAT THE SYMBOLS MEAN. iF ANYONE ELSE NEEDS HELP WITH THIS LET ME KNOW.
  • 2,427 Answers
Good job Jcn1..
Posted on Jul 19, 2008
How to reset all settings to my lenovo a269i mobile thru pc
Is it a think pad ?
Power off your Thinkpad.
Press and hold the "F1" key and turn your Thinkpad on, still holding the "F1" key down.
Release the "F1" key when you hear repeating beeps. Wait for the "IBM BIOS Setup Utility" to load.
Select "Startup" using the arrow keys and press "Enter."
Select "Boot" or "Startup Sequence" and press "Enter."
Select "CD-ROM Drive."
Press the "F6" key repeatedly until "CD-ROM Drive" sits at the top of the list.
Insert your recovery CD into your Thinkpad's CD-ROM drive.
If you have multiple recovery CDs, insert the CD that has "Disc 1" on its label.
Press "F10" to save your changes and exit the BIOS Utility.
Select "Yes" and press "Enter" when the "Setup Confirmation" window appears.
Your laptop will restart. Wait for the Recovery Utility to load.
Select "Restore to Factory Specifications" to erase the contents of your hard drive and reinstall the Windows version and drivers that your Thinkpad originally came with.
Follow the Recovery Utility's onscreen instructions.
When prompted to insert another disc, do so according to the numerical labels on your recovery CDs (e.g., insert "Disc 2" after "Disc 1" and "Disc 3" after "Disc 2").
Your Thinkpad restarts when the restore process finishes. Power off your Thinkpad.
Hold down the "F1" key and power on your laptop to access the "IBM BIOS Setup Utility."
Press "F9."
Select "Setup Defaults" from the menu and press "Enter" so that your Thinkpad no longer boots from the CD-ROM drive.
Press "F10" and select "Yes" to confirm your changes.
Your Thinkpad will restart and load your newly installed operating system.
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-61432
ThinkVantage Technologies downloads
Feb 20, 2014 | Computers & Internet
DELL 300M
Easy Way --- Note that this doesn't always work.
When you are booting your system, press the F8 key during the start of the bootup sequence, meaning after it does the Power On Self Test.
Once you press the F8 key, you will be taken to a Menu. Select "Boot Using Last Known Good Configuration".
It will now attempt to load Windows XP using a past set of configuration files.
If that doesn't work, there is the next step....the hard way.
Hard Way
Boot your system with the Windows XP Install CD, let the system boot into the Setup. Once in the Setup, choose to run the Recovery Console.
You will now be presented with a screen similar to good old DOS.
First, we will recover the System Hive.
Now, type in the following commands with pressing Enter after each line.
md tmp
copy C:\windows\system32\config\system C:\windows\tmp\system.bak
delete C:\windows\system32\config\system
copy C:\windows\repair\system C:\windows\system32\config\system
Be very careful when you are typing in these commands, one wrong move, and you have, broken Windows XP.
Also, change the C in the commands to whatever your Windows XP drive letter is.
Attempt to boot the system, if it doesn't boot, get back into the Recovery Console and do the following commands.
md tmp
copy C:\windows\system32\config\software C:\windows\tmp\software.bak
delete C:\windows\system32\config\software
copy C:\windows\repair\software C:\windows\system32\config\software
Sep 08, 2012 | Dell Inspiron 300M Notebook
How do I acces the Bios on a Compaq Presario 5000 built somehere around 2002.
during the bootup post routines you should see a message that tells you what to do to go into the bios.
Sometimes the post routine is run without being shown on the screen. If so, try pushing the F2 button, or DEL key during the bootup sequence.
Dec 29, 2009 | Compaq Presario 5000 PC Desktop
My tecra 8000 fails to boot cannot find config sys
Originally Posted by Don this problem occurs when you try to update drivers in the computer..sometimes windows XP cannot update the driver and that corrupts system.ini file as it has a lot of bad entries..Due to this you will get this error mesage..No its not due to virus.its due to an attempt to change system.ini file
Windows could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM
That means the System Registry Hive has become corrupted.
There are two ways to get back up and running. The easy way which doesn't always work, and then there is the hard way.
Hard Way
Boot your system with the Windows XP Install CD, let the system boot into the Setup. Once in the Setup, choose to run the Recovery Console2.gif.
md tmp
md tmp
Aug 22, 2009 | Toshiba Computers & Internet
Entering BIOS settings, Easy-Access, after POP, with external KB
The Power On Password problem is near impossible to crack. It is designed to prevent unauthorized access to the Thinkpad and removing the BIOS battery will not remove the password because the password is stored on an EEPROM chip.
There are no backdoor passwords available, the only option is to ask the person who set the password.
OR
There is a way to hack into the Thinkpad to see and remove the password but it requires electronic skills, a program and a working computer.
For details on how to do this go to :-
http://sodoityourself.com/hacking-ibm-thinkpad-bios-password/
Feb 03, 2009 | IBM ThinkPad 600X Notebook
161 and 163
Are you trying to access the Bios set up? I own the IBM ThinkPad 380Z, 13" full Screen, 233MHz Pentium II model. If you power on the machine and just hold down the Q button it will then take you to easy set up. If you have Windows on it just wait to the IBM logo screen clears and press and hold F8 and that will bring you to Windows setup.
Nov 26, 2008 | IBM ThinkPad 380ED
Old Pentium III
Are you refering to the system config utility at the begining of the boot up? I am guessing that is what you are trying to get into . .... Simply press F1 durring the first few moments of boot up and it should take you right into the setup.
Apr 28, 2008 | Computers & Internet
Bootup
Have you tried changing the cmos battery on the motherboard?
Jan 07, 2008 | Computers & Internet
Having problems with my compaq Persario 2500
Hard Way
md tmp
md tmp
Oct 11, 2007 | HP Compaq Presario 2500 HP Pavilion ZE...
Computers & Internet Logo
David Payne
David Payne
