Question about Nintendo DS Console
Mic for ds lite
What do u mean by hold power for ten seconds...?
  • chocofreak1 Jul 23, 2008
    thanks ill try it.
    ok well that did not work is there anything else i can do maybe with like the settings or something... plz help me i love playing my dogs game and now i cant!
Take your battery out of the DS. Slide the power slide to the On position and hold. This has worked for me on multiple electrical devices. By theory it will eliminate the static stored by electrical current. mic for ds lite - close.gif Read more >> Options >>
Posted on Jul 19, 2008
  • Arrigo Jul 23, 2008
    If your mic for the DS is still not working you can try going to the settings in the game and test out the mic. Try doing the same thing with another game. Also, like i said before take out your battery and HOLD the power slide On for ten or more seconds. If still you cannot get your mic working you will have to call nintendo. Hopefully, you are still under warranty then they will swap you out with a different ds.
DS Lite top screen and mic not working properly. Good ole boyfriend tried to replace the casing and the mic on my nds lite, but apparantly, I'm the more technical talent of the two. The problem...
Hi - either the cable is not ALL the way in the connector ( double check) or the cabels damaged after install ( common) you need to repalce the entire screen on a ds lite as the cable is not detachable.
as for the mic - you will need some PCB rework on the motherboard to rectify that I'm afraid, contact us at www.dsdoctor.co.uk if you need any more help :-)
Sep 15, 2010 | Nintendo DS Lite Console
DS Lite mic is not working for brain age or nintendogs help!!!
i think you should look for atechnician to
fix it !!!!!!!!!..........ok?
Aug 03, 2009 | Nintendo DS Lite Console
I`ve had my ds for about 3 yrs now, and my mic
you can fix it just replace it but it means nearly completely stripping down your ds as the mic is fitted in the top part and plugs into the motherboard in the bottom part.
Jun 26, 2009 | Nintendo DS Lite Console
A Problem Wiht My DS Lite System
Try resetting the Ds lite by taking the battery out for a few minutes then try the mic again.
If this fails the mic has blown and needs to be replaced. This involves taking the unit apart and installing the new mic and cable from it's location in the top screen to the port in the motherboard in the bottom screen.
If you are not handy at repairs i would suggest bringing it to a local repair shop as it is a relatively cheap repair to fix (€20 approx).
Jan 05, 2009 | Nintendo DS Lite Console
Nintendo DS Will Not Charge
Try if the battery is charged right, when batter is fully charged disconnect from AC adapter. Hold the power button for 5 seconds. If it does not work that means that you need a replacement battery for the Nintendo DS. When you receive the replacement batter, follow the steps again.
Sep 11, 2008 | Nintendo DS Lite Console
DS lite
I'd suggest removing and then re-inserting the battery (this should at least switch the power off).
Is the power switch loose? If so it's been broken and needs replacing (not an easy job).
Alternately it could just be stuck in sleep mode which happens when the DS is closed while powered on but should awaken when re-opened.
HTH
Mar 03, 2008 | Nintendo DS Lite Console
Microphone not working
The microphone level can only be adjusted in certain games. Have you tried using the mic in any other games? Most likely, the mic is simply defective; I have heard of more than one case of manufacturing defects with Nintendo DS microphones. How long have you had the system? If it is still under warranty, Nintendo should fix the system for free.
Jan 27, 2008 | Nintendo DS Console
My Nintendo microphone
My Nintendo ds lite also would not respond to voices. I have brain age 2 and Zelda. In the Zelda options there is a mic test. This will show a graph bar that measures your voice. Well the mic was not working at all for either game. I simply took out the battery and held the power slide for a couple seconds. Amazingly the mic works now for both games. I do not know if moving the power slide is significant, but on computers to de-static them you remove all power sources(battery and ac adapter) and hold the power button for 10 seconds.
Oct 30, 2007 | Nintendo DS Console
Nintendo ds lite microphone doesnt work
I fixed the MIC on my DS LITE very easily, after first replacing the MIC with a new one and finding that it still did not work (not an easy thing to replace either)! The internal MIC signal is routed to a contact at the front edge of the DS, which allows the internal MIC to be disconnected when an external MIC is connected. If this contact (which is normally held closed by the springy nature of the contact) gets dirty, then it effectively goes open circuit, disconnecting the internal MIC signal. You can use a cotton bud and a little WD-40 (contact cleaner) to clean the contact (clean the two pins next to the 3.5mm jack connector) to restore the electrical contact. Takes 5 minutes and is a LOT easier and cheaper than replacing the MIC or paying someone to repair it!
Oct 30, 2007 | Nintendo DS Lite Console
Nintendo DS Console Logo
50 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
