Projection Televisions
Problem for Projection Televisions
Generic problem for all Projection Televisions
Red shadow on screen double
By blue5j on Jul 19, 2008
red shadow on screen double image
Clarification Request
Posted by BIG IRISH on Jul 19, 2008
Good day, blue5j;
Color shadows on Projection TV's normally indicate a convergence concern. So, go into the customer menu and attempt to adjust it. If the red shadow is 'bowed' then don't attempt adjustment, because that means that the TV has a circuit problem. Most likely the convergence IC's, chips.
If you want to try to yourself I will need more information, like brand, model # etc.
Good luck, let me know, big IRISH>
Same Problem
Dec 15, 2008
-   i have a red shadow on my 50" sony rear projection tv only occours when is running on 60 hetz can any one help??????? if so is it going to be expensive -   scat740
Oct 06, 2008
-   I have a Sony Bravia model no. KDF-50E2010 and the problem only occurs with video input through RGB which is on AV3. The AV3 in the corner has the same shadow but AV4-AV7 looks perfect. it must be some technical problem like circuit or something. please help. it makes my xbox look horrible. -   fintang
Sep 25, 2008
-   I have a red shadow or film over the picture on a Hatachi MODEL 50DX20B projection tv,what can I do for this
-   bramahrock1
Jul 25, 2008
-   I have a Philips 60PP9292 60in Rear Projection HDTV-Ready.
AKA DPTV305F-   sethricard
Best Solution
posted on Mar 16, 2009
Very Helpful)
davymactech
Rank: Apprentice
Rating: 98%, 16 votes
Well this is the fix for the usual Ghosting problem....
To bring up the "service" menu, put the TV in standby mode, then press in sequence :
Onscreen Display ( the little screen with the i+ in it )
5 ( channel number 5 )
Volume Up ( upper end of volume button )
Analogue ( middle top button )
The TV should switch on and when it's warmed up, you should see a screen with lots of big green lettering on it.
Press the "menu" button ( middle bottom )
Use the direction dial to move down to "LCD Drivers" and press right on the dial to enter this menu.
Move down to "S H Pos Reg R". It should be "10", change it to "11". ( Left/Right to adjust )
Move down to "S H Pos Reg G". It should be "10", change it to "11".
Move down to "SHPos Reg B". It should be "10", change it to "11".
Press the menu bottom to drop out of the menus, and the standy button to drop to standby. Switch back on, and hopefully your ghosting will be gone
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #2
posted on Oct 06, 2008
Somewhat Helpful)
fintang
Rank: Apprentice
Rating: 75%, 1 votes
Was this helpful?
Yes
No
Solution #3
posted on Apr 29, 2009
Not Rated)
scottc1975
Rank: Apprentice
Rating: 0%, 0 votes
changing the values or the lcd drivers in the "secret" service engineer menu works! ghosting gone ps3 now looks as crisp & clear as it should be ;)
Was this helpful?
Yes
No
Popular Solutions for Projection Televisions
Questions and Unsolved Problems for Projection Televisions
Answer
i HAVE A 47" PANASONIC REAR PROJECTION TV. pURCHASED NEW FROM CIRCUIT CITY DEC 2001. wORKS... (More)
Answer
sony wega kf-42sx300 when i turn tv on lights flash green and red no fan starts up
Answer
rca 52'' rear projection hd52w67 with back off lower left side bottom tray had eletical buzzing... (More)
Answer
i have a red bow on my magnavox 51mp392h rear projection can i just change the red lamp
Describe your Projection Televisions problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
