Stairmaster 7000PT Nautilus Stepmill Logo
Posted on Jan 28, 2011
My stairmaster 7000pt step is grinding and slipping
Anonymous
Level 1:
New Friend:
  • Contributor 30 Answers
  • Posted on Feb 03, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
30
Questions
0
Helped
14386
Points
33
Most likely your gear reducer (transmission ) has stripped and wii have to be replaced . call glide fitness products in santa ana california 1 866 637 4600. they will sell you a new one for about $180 or send in your old one and they will send you a rebuilt one for about $75 note shipping is extra
The chain feels like it is slipping and a clunking noise when it slips.
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
This can be caused by either a loose chain, a failing chain tensioner or possibly, a failing transmission. You can find some troubleshooting information at the following link.
Search Results
My stairmaster will not rotate
Check the following video out for some troubleshooting steps regarding this issue.
Stairmaster Stepper 7000PT Stepmill Parts Transmission SPORTSMITH net
Belt slips off stairmaster stepmill
There are a couple of different belts available for this unit. The following link will take you to the parts available for your model.
Stepmill 7000pt is free spinning and has no resistance.
How to Test the Relay Board on Stairmaster 7000PT Stepmill How to Test Relay Board of a Stairmaster Stepmill 7000PT Disconnect power from the machine.
Disconnect the main cable from the relay board J1 terminal. Main cable should remain disconnected for the duration of the relay board tests.
With the Power ON, place a jumper wire across the GND/BLK and RLY/RED test points. (Ensure jumper wire only makes contact with the designated test points.)
  • Verify that the Relay LED is lit. Remove jumper wire.
With the Power ON, place jumper wire across the +/WHT and FLD/BRN test points. (Ensure jumper wire only makes contact with the designated test points.)
  • Verify that the Field LED is lit. Remove jumper wire.
With the Power ON, place jumper wire across the +/WHT and with the other end touch the ALT/C, FLD/NC, and RES/NO.
  • Verify that the Field LED lights.
If any of these jumps fail, replace the relay board and or power supply. Stairmaster Stepmill 7000PT Electronic Testing of Relay Board
The second link will take you to the service manual. Starting on page 13, you will find some more valuable information on the relay board. Last link will take you to a video on how to test the alternator
Video about Performing Jumper Test on Stairmaster Alternator
My Stairmaster 7000PT has no resistance past level 10 or 11?
This could be caused by worn alternator brushes. The following link will take you to a video on testing the alternator. If the alternator checks out, you may be dealing with a faulty display console.
Stepmill has no resistance when starting
First thing you'll want to do is check the alternator brushes. Here's a link to the different types offered for the Stairmaster 7000PT:
Repair Parts for Stairmaster Equipment Batteries Springs Belts Chains...
If the brushes look like they are in good condition you can also test the relay board. This link will take you to the procedures for checking the relay board:
Stairmaster stepmill 7000pt all pwer is on but will not start the stairs
console could be defective try to diagnose it by entering diagnostic codes from your manual
also check the mechanical parts inside , a hinge rod could have slipped out and has pinned the entire stairs
When I get on the stairmaster it starts going really fast and will not slow down. Does anyone know how to fix this?
check inside where power receptacle is sometimes the steps hit the wiring and breaks a wire off therefore no power to the control board
if not that do an alternator check refer to owners manual not hard to do could be diode that needs replacing usually the small electrical component on the exterior of the alternator
last if you have all electrical working the gear reducer gears may be stripped (usually a grinding noise or skipping feeling when this happens ) a rebuilt one or new one can be purchased from glide fitness products in santa ana california for very reasonable price they are good people to deal with also they can assist with trouble shooting
good luck
I have problem with master console of step mill 7000 pt stair master
If you have a Stairmaster Stepmill 7000PT that has an older style console with the red LEDs and you want to upgrade to the newer, console with the blue LCD; the parts necessary for this upgrade include the console and the console cable.
Stairmaster Stepmill 7000PT Console Upgrade
C40 Console Repair Video for Stairmaster Steppers
Top Stairmaster Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Larry Ng
Larry Ng
ADMIN Andrew
ADMIN Andrew
Are you a Stairmaster Exercise and Fitnes Expert? Answer questions, earn points and help others
