Coffee and Espresso Makers
Problem for Coffee and Espresso Makers
Generic problem for all Coffee and Espresso Makers
Saeco Incanto not grinding
By cdleighton on Jul 19, 2008
My Saeco Incanto, Type SUP 021YDR, started making very short coffees a few days ago. Today it has stopped grinding the beans - like when I  press the button to use pre-ground coffee.
It has also started leaking and hissing after making hot milk.
I want my coffee machine back ;( - Chris
Comments:
Jul 19, 2008
- Descale... not as often as I should. I did it again this week, it made just two coffees after that :(
Machine is 4 years old.
The grinder does not start at all.
- Chris
Best Solution
posted on Jul 19, 2008
Helpful)
mirran
Rank: Guru
Rating: 87%, 324 votes
Hi Chris,
The leaking is your steam valve that has to be replaced, you can see this if you open the door and look up in the right corner there you will see water drip.
If not then you have a pipe or boiler leak.
How old is your machine?
How often do you descale the machine?
When you try to make a cup of coffee, starts the grinder for two seconds or is it dead?
Hope this will help you.
Comments:
Jul 19, 2008
- Hi,
Ok, i recommende my customer to descale their machine one time every two month just to make sure the calcium not broke down the boiler.
Are there any lamp that is lighting on your machine?
If so, open your steam knob and try to make a full cup of water, if you only get a half cup of water then you have to replace you water turbine in the machine. Can you get a full cup of water then your machine shuold get in ready mode.
Was this helpful?
Yes
No
Popular Solutions for Coffee and Espresso Makers
Questions and Unsolved Problems for Coffee and Espresso Makers
Answer
Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop... (More)
Answer
need an instruction manual for the 42 cup coffee urn
Answer
Is there a water filter in the B40? If so were is it in unit? Also I am looking for a parts book
Answer
The water does not drip into the coffe pot, it is stuck in the filter area. what do we do?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Coffee and Espresso Makers:
Top Coffee and Esp... Experts
Rank: Guru Guru
Solutions: 901
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Coffee and Esp... Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
