I have a DVD recorder DMR-EX77 I can record the digital tv channels but not the analogue ch.when I try to tune the analogue ch I just get No Signal message The connection are as per page 15 of the instruction manual one through a video then to the analogue TV the video and tv are panasonics.
Tuner fault
Posted on Jul 21, 2008
How do i record tv programs on digital stations. Only option is analogue.
On the EPG (of the DMRs channels) press OK on the remote at the program you want to record. After that you can choose HDD or DVD-RAM and the quality Ep-Xp and possible subtitles (STTL). Press OK and the recording settings are saved. Note that to record 16:9 or 4:3 aspect ratio, you have to have that setting made from setup.
Nov 09, 2013 | Televison & Video
My mother has a Panasonic DMR-ES20D DVD recorder it plays back DVD's ok but has lost all tuned channels. When performing a auto tune it gets to ch 53 and appears to hang with error code U80 in the dis
could be its not digital, so it will not pick up any channels as they are now all digital not terestrial through the aerial like the y used to be. you need a digi box now to plug the recorder into
Dec 11, 2011 | Panasonic DMRES20D DVD Recorder
My problem is I have a dvd player DMR-ES 15 I live in australia is it possible to tune in the new tv stations example seven 2
It is not possible to tune in 7two, channel 11, GO! or similar digital channels with this model DVD recorder, as its tuner would most likely be analogue only. You would either need to upgrade to a model with a digital tuner built in, or purchase an external set top box, capable of SD and HD digital reception, and connect its AV outputs to the respective inputs of the recorder, in order to record the channels you want.
However, being in OZ, those digital channels are available as free to air - all you would need is the appropriate receiver to enjoy them. I recommend a set top box which offers HD as well as SD.
May 05, 2011 | Panasonic DMRES15 DVD Recorder
My Panasonic dvd recorder appear to no longer be receiving TV channels it was working and then suddenly not. I canstill view TV through my TV so Im doubtful that it is an ariel problem and I have checked...
Sounds like the inbuilt ATSC tuner has failed; if this is analogue only, it may not be worth repairing that. If however it is a digital tuner, it may not be economical nor cheap to replace at component level. It is up to you, if you want to submit this unit to an authorised Panasonic service centre, to get a quote and second opinion about it. At least then you could make a firm decision afterwards.
The DMR-EZ27K was a reasonable model Panasonic DVD recorder, and it's better than their DMR-ES15V.
Nice unit. The cheapest option I can suggest would be if it is an analogue tuner model, simply connect an external digital set top box to the respective inputs on the unit and record the TV that way (assuming the channels are not encrypted with macrovision). It's crude, but it will save you an expensive workshop hassle.
Mar 16, 2011 | Panasonic DMR-EZ27K
My old samsung dvd recorder dvd/r120 doesnt work with my new digital tv. can only record 4 analogue channels worked fine before with digi box.have a digital aerial
> digi box (?)
Is this digital converter?
Your new TV doesn't need it but it could well work with your DVR. It wouldn't give you the benefit of HD recording but with it, you could convert the digital signal into analog and record the results.
Jan 02, 2010 | Panasonic DMR-ES10 DVD Recorder
I cannot get any tv channels though my panasonic
This model only has an analogue tuner so wont receive anything if the analogue signal in your area has been switched off. either buy a new new with a freeview tuner built in or just use that one in conjunction with a freeview box.
Dec 02, 2009 | Panasonic DMR-ES10 DVD Recorder
DVD recorder will not pick up digital channels from TV
Our DVD recorder DMR-EH57 is recording but not able to show its video
recording to the LCD what is the problem.
Nov 08, 2009 | Panasonic DMR-EH57 HDD Recorder Player
Panasonic DVD Recorder DMR-EX77 My DVD Recorder is communicating between the Remote Control and the DVD Recorder, but the Recorder is not communicating correctly with the television. The DVD Recorder seems...
It sounds as if the actual T/V channel is out of tune.
I,d suggest powering the player On.
Then using channel 8-12 on the T/V to Scan for its frequency.
When you,ve located it to the Player.
Lock the channel, then use the DVD on Channel 8-12.
Mike @ compurepair.
p.s also check the output from DVD To T/V lead has,nt come loose.
Mar 17, 2008 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Panasonic DVD Recorder - Digital tuner stopped working
Is your recorder hooked up to the new convert box for digital antenna reception?
I am currently researching the convert boxes for my dvd recorder. I found that some dvd recorders already have digital converter boxes already installed. This might be the case for you.
Mar 08, 2008 | Panasonic DMR-EX85EB-S DVD Recorder/HDD...
Watching tv while recording onto vhs or dvd
This could be a couple of problems. I'm not trying to make you feel dumb or anything but sometimes people miss the obvious. Do you have an universal remote? How is your vct wired to your tv? Does your cable go to your vct or your tv first? These sound like silly questions but they are important.
Jun 02, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
Televison & Video Logo
138 people viewed this question
Top Televison & Video Experts
