RCA HD TV When you turn it on it turned off. Took 5 or 6 time before it stayed on. And then it was fuzzy screen with audio. Now we just leave it on, but the fuzzy screen happens more frequently now.
Cancel my problem it's Fixed !
Posted on Jul 20, 2008
Fuzzy/Scramble screen when first turned on.
check solder joints on top of screen some screens were sub contracted to a chineese company called chi mai and had inherant defects
Nov 30, 2012 | Samsung LNT5265FX 52 in. LCD Television
I have a 52" RCA
sounds like the power supply capacitors CP150, CP120 and CP114 need replacement. You can get the RCA repair kit by that same name from which has the caps and the CD with repair instructions.
Aug 05, 2011 | RCA HD52W56 52" Rear Projection HDTV
Why does my emerson tv stay on standbye mode
Do you mean the power switch does not shut it off, or do you mean it does not show the signal you want it to show?
I can't help you over it not turning off, but if you are not seeing the signal, it may be because the TV has various alternate inputs, and has to be switched between which one you want to show, such as:
2 x HDMI input ( 19 pin HDMI Type A ) - rear
1 x VGA input ( 15 pin HD D-Sub (HD-15) ) - rear
2 x S-Video input ( 4 pin mini-DIN ) - rear
1 x audio line-in ( mini-phone stereo 3.5 mm ) - rear
5 x audio line-in ( RCA phono x 2 ) - rear
2 x component video input ( RCA phono x 3 ) - rear
2 x composite video input ( RCA phono ) - rear
Try using the on screen menu to bring up a choice over which input to show.
Switch it to the one you have connected to it.
Feb 13, 2011 | Emerson LC320EM9 32 in. LCD HDTV
White/Grey screen with non-HD channels
I removed the HDMI cable and connected with component video and rca audio. No more white screen.
Picture quality looks good. I don't know if it's as good as HDMI, but then I don't need to reboot the TV three times to get to teh on-demand menu... Grrrrr....
I am trying to contact Toshiba on this as well. I have seen several reports of this problem on the web.
Dec 04, 2009 | Toshiba 19AV500U 19 in. LCD HDTV
Rca l32wd22 blackscreen
Just recently, I was told how to get another tv.
You find a good TV service centre and ask them to fix it. If they cant you take the work order from your tv sc and call 1-877-297-8391.
You will get yourself a tv
Jun 01, 2009 | RCA L32HD31 32 in. LCD HDTV
If I tap the rca jacks in the back the screen gets distorted
You need a hdmi connector from your tv source to the TV. RCA connectors don't have the capability for HD signal transmission. You can use them for a connection but the picture will be fuzzy if trying to watch HD signal. Check your cable/dish box to see if there is a hdmi output. If so, buy a hdmi cable & that should solve your problems.
Mar 19, 2009 | Akai LCT4216 42 in. LCD Television
RCA P52937SG
Time to replace.
Mar 10, 2017 | Televison & Video
Problem solved, it was my green driver this time and only $25 to replace.
Jan 16, 2008 | RCA D52W136D 52 in. TV/DVD Combo
Toshiba TV repair
I have a Toshiba HD LCD tV, model 37AV50U. the screen is black. I still get audio and can change the channels but the screen stays black. It doesn't even show the menu box. Is this something I can fix myself?
Dec 23, 2007 | Toshiba 57H81 57" Rear Projection...
RCA SCENIUM trys to start up but wont start
I kind of had the same problem..I had picture..and the display would flash 5 times. Per the manual it said the lamp needed replaced. After reading a post by someone that had the same problem and replaced the lamp, it still didnt fix the problem..I took my set in to the repair shop. Turned out to be the light engine..$1000.00 for the part...$250.00 for labor! The tv was only 15 months old..and not even used on a regualr basis..I maybe had 300 hrs on it. I did not buy the extended warranty (will for my next tv!!!) but after many heated conversations with RCA..they agreed to pay for the part..I got stuck with the labor, atleast that was better than the whole bill. Anyway..starting to act up again..after only 5 months..bottom line..I'll never buy an RCA again!!
Oct 29, 2007 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
