Question about Sony KP-53V80 53" Rear Projection Television
Does not turn on until you unplug cord, and replug in
Help..is this problem worth fixing?
It only turns on if you unplug set from wall outlet, and replug in...then, the
screen doesnt come on until red light blinks about 15 times, but when it
comes on, it shuts itself off quickly, and then its dead again.
A tv repairman said its the transformer. Is this correct?? And is it
worth fixing or dumping to the trash and buying a new one??
    Problem Solver:
  • 4 Answers
Its protecting ... the system just detected some other problems 2 ur system or power supply.. modern television has an auto shutdown protector circuit... i just said whwt i know... tnx
Posted on Jan 12, 2010
My printer is hp deskjet 4625 fls advice me. there is a problem with the printer or ink system. turn printer off, then on. if problem persists, contact hp error. 0xc 19a0022
You may try to reset the printer. I was not sure if you followed these steps and unplugged the power cord. That may fix your problem. Good luck this can be very frustrating.
In some cases, a printer reset can clear the error message.
  1. Turn the printer on, if it is not already on.
  2. Wait until the printer is idle and silent before you continue.
  3. With the printer turned on, disconnect the power cord from the rear of the printer.
  4. Unplug the power cord from the wall outlet.
  5. Wait at least 60 seconds.
  6. Plug the power cord back into the wall outlet.
    NOTE: HP recommends connecting the printer power cord directly to the wall outlet.
  7. Reconnect the power cord to the rear of the printer.
  8. Turn on the printer, if it does not automatically turn on.The printer might go through a warm-up period. The printer lights might flash, and the carriage might move.
  9. Wait until the warm-up period finishes and your printer is idle and silent before you proceed.
Apr 13, 2016 | HP Office Equipment & Supplies
I need to reset my Officejet Pro K8600, can anybody help?
Follow the below mentioned steps to do a reset :
-Press the Power button to turn off the product.
(The product might not turn off after pressing the Power button. Continue to the next step regardless)
-Disconnect the power cord from the rear of the product.
-Unplug the power cord from the electrical outlet.
(Wait 30 seconds.)
-Replug the power cord into the electrical outlet.
-Reconnect the power cord to the rear of the product.
-Press the Power button to turn on the product.
Sep 22, 2011 | HP OfficeJet Pro K8600 Printer
Cannot get past initial set up ie two problems cannot power of printer with button on front panel also cannot get any language up on small screen
Try to unplug the power adapter from the printer.
Then unplug the power cord from the power outlet in the wall. Wait for at least 10 seconds before you replug the cord. Then replug the power adapter to the printer.
May 20, 2011 | Lexmark C533DN InkJet Printer
Good morning, i was printing and the printer shut
Try to unplug the power adapter from the printer. Unplug the power cord from the power outlet in the wall. Replug the power cord after at least 10 seconds - bypass any power surge devices or power strips. Replug the power adapter into the printer. Your printer should automatically power on, otherwise, press the power button. If the printer still won't power on, please contact Lexmark technical support for additional assistance.
May 12, 2011 | Lexmark X5470 All-In-One InkJet Printer
Hp officejet 6500 all lights are flashing and mechine says turn off and on . Please can someone Help??
: Check the power cord
1.
Turn on the product.
2.
Remove the power cord from the back of the product.
3.
Check the power cord for any physical damage. If the power cord is damaged, replace the power cord.
If these steps resolved the issue , you do not need to continue troubleshooting.
If the issue persists , continue to the next solution.
Turn the product off and then on again
1.
Press the Power button ( ) to turn the product off.
2.
Wait 60 seconds, and then press the Power button ( ) to turn the product back on.
3.
If the product does not turn off when the Power button ( ) is pressed, wait three minutes, and then proceed to the next solution.
Plug the product into a wall outlet
Follow these steps to make sure the product is plugged in correctly.
1.
Unplug the power cord from the back of the product.
2.
Unplug the power cord from any surge protectors or power strips.
3.
Select a wall outlet to plug the product into. Test the wall outlet by plugging another electric appliance, such as a lamp, into the wall outlet and turning it on. Unplug the test appliance.
4.
Plug the power cord into the back of the product.
5.
Plug the power cord into the wall outlet.
6.
Press the Power button ( ) to turn the product on.
Solution six: Reset the product
Follow these steps to reset the printer.
1.
2.
3.
Wait 10 seconds, and then plug the power cord back into the wall outlet.
4.
NOTE: Many power cords have an LED light on the power module or on the end of the cord that plugs into the product. Make sure the LED light is lit and steady.
5.
6. Perform a partial reset of the product
  1. Disconnect the power cord from the product.
  2. Wait for 20 seconds.
  3. Press and hold # and 3 while reconnecting the power cord.
  4. When the product turns on, release both buttons.
  5. Try printing again.
IF still won't resolve it by following steps mentioned above then your printer needs replacement. Malfunctioning hardware.
Mar 28, 2011 | HP Officejet 6500 Wireless All-in-One...
Hello, the printer keeps saying alignment failure refer to device documentation for help...
Follow these steps to reset the product. Make sure you connect the product directly to a wall outlet and not a surge protector or power strip.
  1. Press the Power button (c01602202.gif ) to turn off the product.
    NOTE: The product might not turn off after pressing the Power button. Continue to the next step regardless.
  2. Disconnect the power cord from the rear of the product.
  3. Unplug the power cord from the electrical outlet.
  4. Wait 30 seconds.
  5. Replug the power cord into the electrical outlet.
  6. Reconnect the power cord to the rear of the product.
  7. Press the Power button (c01602202.gif ) to turn on the product.
  • If these steps resolved the issue , there is no need to continue troubleshooting.
  • If the issue persists , see the next step.
Step two: Clean the electrical contacts on the printhead and inside the product The ink nozzles on the printheads might clog if you expose them to air for more than a few minutes. The ink nozzles also might clog if you do not use the product for long periods of time. Follow these steps to clean the electrical contacts on the printheads.
CAUTION: Follow these steps carefully to avoid damaging the sensitive electrical component
  • Make sure that the product is turned on.
  • Open the top cover of the product.
  • Press and hold the OK button for five seconds. The carriage moves to the left side of the product. Release the OK button.
  • Wait until the carriage is idle and silent.
  • Unplug the product power cord from the electrical outlet.
  • Use a dry, soft, lint-free cloth to remove any ink from the electrical contacts on the printhead.
    Nov 17, 2010 | HP Officejet Pro L7680 All-In-One Printer
    My display screen is rolling and nothing stops it. My computer says the printer is offline.
    Try doing this procedure to correct the problem.
    1. Unplug the power cord from the back of the product.
    2. Unplug the power cord from any surge protectors or power strips.
    3. Select a wall outlet to plug the product into. Test the wall outlet by plugging another electric appliance, such as a lamp, into the wall outlet and turning it on. Unplug the test appliance.
    4. Plug the power cord into the back of the product.
    5. Plug the power cord into the wall outlet.
    6. Press the Power button to turn the product on.
    7.Now check if its already working.
    May 16, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
    HP 2210 All-in-One quit right after I made a copy.
    I was looking for a manual online but did not find any, you can check your manual on how to reset the printer. They normally have it in the manual and once you reset it, the printer will return to factory settings including releasing the scanning part.
    Aug 17, 2009 | HP LaserJet 3055 All-In-One Printer
    Error message 222aO-reset power
    Unplug the power cable from the All-In-One aswell as the power outlet.
    Leave it unplugged for atleast 1Min.
    Then plug the power cable directly to wall outlet without any surg protector.
    And then press the # and No 6 button in the All-In-One and the without releasing the buttons insert the power cord untill it showas up a message as Semifull reset.
    If the Printer turs off then release the keys and turn the All-In-One On and then try.
    Good Luck
    Jun 29, 2008 | HP Officejet 5610 All-In-One InkJet...
    Alignment failed
    Just try to reset the Printer.the pro L series printer can be reseted as follows.
    POWER DRAIN:-Turn off the printer, Unplug the power cable from printer and from the wall outlet.Press and hold ON buton for 30-60 seconds.
    PARTIAL RESET:-Unplug the printer power cable while its ON, press and hold # and 3 button and connect the Power cord while holding.Wait untill the ON light flashes, then release the button.
    ----(for below reset cartridges must be removed out)---------
    SEMI_FULL RESET:-Unplug the printer power cable while its ON, press and hold # and 6 button and connect the Power cord while holding.Wait untill the ON light flashes, then release the button.
    FULL NVM RESET:-Turn the printer OFF, Disconnect the power cable from printer and from the wall outlet.Wait for 1 minute.Connect one end of the power cable to wall outlet.Press and hold # and 9 button and connect the Power cord while holding.After connecting , release the button.Then Turn ON the Printer.
    (Notes - resets will take a while)
    Feb 07, 2008 | HP Officejet Pro L7680 All-In-One Printer
    Sony KP-53V80 53" Rear Projection Television Logo
    Top Sony Televison & Video Experts
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
