Question about HP PSC 2210 All-In-One InkJet Printer
My printer when I lowin on my pc the only one thing work the printer, not the fax, not the scanner. How I can make this thing work. My coputer is emachine.
  • kitty_lui Jul 20, 2008
    I'm install the sofwares from the CD,or I thing that is mfd?
    thank you for your respond.
If you are running on VISTA then i believe you cannot fix it at this moment in time, Vista will not allow you to install the correct drivers because it should have them installed within Vista's plug and play settings, but it does not work correctly.
Posted on Jul 19, 2008
    Genius:
  • 2,785 Answers
Have you install all the softwares for the mfd
How can i fax from a printer
hook your phone line up to it.  Hit the fax button, set your document in the feeder face down, and dial a working fax #, and then hit the send or enter button.  Let the fax do its thing and voila fax sent.
Oct 26, 2009 | Epson Stylus Multifunction Inkjet Printer/...
I CAN`T SEND A FAX
Fax machines are sorta like printers, sorta like scanners, and sorta like dial up modems all wrapped into one expensive box.
1. First thing to make sure of is that you are hooked to a phone line. most fax machines have a phone handset that you can make calls from. Call someone and make sure that works. If So, you are able to connect to phone networks, and should have no trouble sending or receiving data. If you have a dead line or no sound, check the line and check the power. (its always the easy stuff that is overlooked, just check it and make sure).
2. If this fax machine has computer interface, (usb port or parallel cable port), see if you can scan with it. Drop a document into the scan area and see if the computer can scan an image from the scanner. If the scanner works, you can scan images into the fax machine to be sent to the fax number. (If your fax machine does not have a scan to computer feature, skip this.)
3. if your fax machine has a print from pc feature, try to print a document to it from your computer. If you can print, then the printer works, and you can receive faxes. (if your fax machine does not have a pc printing feature, skip this)
4. Here is how a typical fax machine works. You place the document or image into the scanner feed area. You press a big button that usually says "fax" and then, a screen pops up saying to dial the number. You dial the number and press SEND. once you press Send, the machine will scan the document, dial the number and sing a little dial up modem song awaiting a response from the receiving machine. the receiving machine acknowledges the fax, and the singing is no longer audible (but it continues because the modem song is actually data transmission/reception). after about 20-60 seconds, the fax completes and the call ends. As for the particular model you have, the functions should be about the same, though the buttons and arrangements may be different. FYI, you can send a fax straight from the PC too, if you have a dial-up fax/modem card.
Jul 03, 2009 | Brother Multi-Function Center MFC-665CW...
Lexmark series x2350 all in one scanner does not work.
Is the scanner driver installed ?. You can check this by unplugging the USB cable from the back of the printer and connecting it again. If you get any Plug and Play prompts on the computer, install the driver by pointing it to the correct scan driver location.
May 27, 2009 | Lexmark X2350 All-In-One InkJet Printer
Do not know how to use scanner
If you have install HP s/w photosmart essential, you can scan material into coputer by selecting the get image function then select from scanner. A window will pop up. In which you can change the scanner parameter setup or accept the pre-scan quality and do the scan right away. Another method is in printer and fax folder, you can find the icon for scanner is located here too. Just click on the icon for scanner then you can get the scan result too. Hope this can help you.
Jun 23, 2008 | HP PSC 1510 All-In-One InkJet Printer
Canon image class MF5750 printer/fax/scanner
If you're in the USA, go to this link. Enter your zip code or city / state and click the "Find Service Location" button.
May 22, 2008 | Canon imageCLASS MF5750 All-In-One Laser...
Scanner problems
try to change cableof scanner to pc.
Apr 01, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Scanner problems
Hi
Try this it has worked for me. Go to hp.com/uk/diagnostics from here you can do a check on your printer to see if it is compatible etc as i found out that the scan button on the hp1210 is the problem. There are instructions after you do the check to either try the scanning with windows fax and scanning or for me it worked with scanning with paint. good luck !
Trap55.
Nov 08, 2007 | HP PSC 1210 All-In-One InkJet Printer
Scanner quit working
the scanner works with the windows built in driver. Uninstall the hole mfc suite and reinstall after restart. This is the fix for the software. You can check the hardware simply by copying a page. If you can copy there is no hardware prob. Post here again if it does not work and let me know your windows version, too, please.
Sep 29, 2007 | Brother MFC 420CN All-In-One InkJet...
HP PSC 2210 All-In-One InkJet Printer Logo
23 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
