Question about Hitachi 53UDX10B 53" Rear Projection Television
Hitachi 53uwx10ba Saw your comment and having the same problem with led DP23. I have the schematics but am not a technician and am not sure what to do. Can you help? Thanks, Gil
  • gilcurameng Jul 19, 2008
    you were asking if anyone had the schematics for the tv - I do. Do you still need them?
  • blkmax May 11, 2010
    Gil, after replacing my burnt FP05 (3amp pico fuse), DP23 was on, only for a short moment as I have a short in my B+ 115 V1 that I need to sort out. I am a technician, but have not done much repairing for the last 15 years, due to a carreer change. I only have an Oscilloscope and a Multimeter at my current disposal. The oscilloscope is quite useless unless you can get power going. When I plug mine in I get smoke from RP24.
    Generally, when a fuse this size burns, it means that there is a short somewhere. The fuse is designed to burn before any devices. Just replacing a fuse will just send power to the short potentially damaging the component it was protecting. the problem can escalate to a point where it is more costly to repair.
    If you are planning to do the work yourself, I can give some advice. But I have no experience with televisions as far as electronics goes. I worked with Amplifiers and mainframe motherboards.
    Marc
    Sergeant:
  • 291 Answers
Radio Shack (in New york city) has a small,inexpensive in\out transistor checker. I live in Deltona,Florida and have not seen it or any of the tester kits that I use to find in NYC.
Posted on Jul 30, 2008
Gil, thanks, I found it. It was a 20mb pdf. I used it to isolate my short. I need to find time to remove the board (Again!!) and do some measurements. I want to look at Q701, Q707 and Q777.
Marc
Posted on Jul 19, 2008
I have a Hitachi 53uwx10ba power light flashes and tv won't turn on
It is rare in this set but it indicates a short somewhere that is pulling voltage inside the set down---not a do it yourself repair unless you are a Technician with some basic equipment and a schematic diagram.
Have someone look at it from a repair shop or ?
Apr 14, 2012 | Hitachi Televison & Video
53uwx10ba hitachi. just recently changed the stk chips out with what it had in it. stk392-180. but in the service manual i just got it is a different one. i think 110. but the front power light blinks with...
you have a shorted horizontal output. you just wasted your time and money on the convergence ic's that or you have a short from a bad solder job replacing those ic's.!!!
Jan 10, 2010 | Televison & Video
Disassembling hitachi 18v reciprocating saw
In addition to the 8 obvious bolts there are 4 more under the gearcase insulator holding the gearcase to the housing. I looked at a schematic for the 18V recip saw and that is all I saw. Have you tried the Hitachipowertools.com website for the schematic? Let me know if you still have trouble.
Mar 29, 2009 | Hitachi 18V Lithium Ion Cordless Hammer...
Need a detailed schematic for handle of a hitachi C10FC mitre saw
I would go to Ereplacementparts.com and type in your exact model number (there are about 5 saws) and they you can download a schematic of your tool. Hope this helps.
Dec 30, 2008 | Hitachi C10FCE2 10" Compound Miter Saw
DP23 LED not lit on deflection board no picture on tv
Good Day, Gil;
Your problem is in deflection circuit (115+v) check these: FP05, DP15, Q777, QH01, TH01, T701, etc. BUT suspect C707 1k pfd, 2kv, and check all the pico fuses (brown) 2" to the right of cap. Good Luck, big IRISH.
Jul 19, 2008 | Hitachi 53UWX10B 53" Rear Projection...
No power
common fault on hitachi is the -26 volt supply is bad,ther should be voltage markings near or around the led's,find the b+ one thats missing or being pulled down
Aug 12, 2007 | Hitachi 43FDX15B 43" Rear Projection...
Hitachi 43UWX10B No Picture No Sound
Check the stand-by circuit to the main pcb for the keyboard control. If no voltage present, check the 5v regulator in the main supply. If you are not seeing the LED on your supply up, it's likely you do not have the 5v stand-by.
Apr 10, 2007 | Hitachi 43UWX10B 43" Rear Projection...
Hitachi 53UDX10B 53" Rear Projection Television Logo
101 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
