Question about Xerox XG-91D 19" LCD Monitor
I have a 3" vertical band of red lines displaying
    Master:
  • Xerox Master
  • 566 Answers
Posted on Dec 21, 2017
3 Suggested Answers
SOURCE:
Mark_Webber
  • 472 Answers
SOURCE: vertical band on new monitor
Without a second thought, send it back.
When you say the monitor has not be dropped, wht you are really saying is it has not been dropped by you.
There were alot of hands involved in getting it from the production line to your house.
At any stage it could have been dropped or given some form of impact (normally in transit)
That fault is in the panel itself and cannot be fixed.
Posted on May 31, 2008
skotkolr
  • 558 Answers
SOURCE: Xerox XL592DS Flashing Colors, Nothing on Screen
Sorry time for a new monitor you might open it up and look at the capacitors and see if any need to be replaced the bad ones will be domed on top normal is completely flat
Posted on Jun 19, 2008
A horizontal band of green and red lines across the screen
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Type in the brand name to your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 17, 2015 | Panasonic TC-P46C2 - 46 Inch 720P Plasma...
Tip
How to Troubleshoot Vertical Lines on an LCD TV Screen
<p>There are two prevalent formats for video programming: full screen and wide screen. LCD TVs are designed to show a wide screen picture to go with high-definition (HD) programming. When standard-definition (SD) programming is watched on an LCD HDTV in its default settings mode, there will be two vertical lines on the right and left sides of the picture. You need to go into your TV settings menu to troubleshoot this issue.<br /> jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); <span><br /></span> <span>Instructions</span> <ol> <li> 1 Press the "Menu" button on your remote control and open the "Picture Settings" sub-menu.<br /> </li> <li> 2 Select "View" from the list of options.<br /> </li> <li> 3 Choose a viewing mode that will eliminate the vertical lines. Select "Zoom" to crop the on-screen image to fit the screen. Select "Wide/Widescreen" to stretch the on-screen image to fit the screen, or select "Panoramic/Panorama" to stretch the sides of the onscreen image to fit the screen (recommended).<br /> </li></ol>
on Dec 27, 2010 | Televison & Video
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
Display Issue, Hisense 42" LCD
Hello
Do a factory default reset to this set. You can get details about how to do this, from its user manual. If it does not help you, the t'Con bard [Timing Control Board] may need replacement.
The board sill look like this.
http://www.dataentryjobs.us/67948.html2_15_2012_7_21_33_am.jpg
Feb 14, 2012 | Televison & Video
My eee pc suddenly had screen problem a week ago--- when it boots up the screen is solid fluorescent green, then as Win XP starts there wide vertical bands appear, and finally what i'm left with is an...
I just had a smilar problem with the vertical lines and resolved it by disabling the display adapter, the display driver was corrupted, and i am using it to type right now and no problems. Go to the device manager and disable the disp0lay driver by right clicking on it and selecting un9install and restart. I could hardly see through the lines but I did it and it worked. Windows automatically comes with drivers from many manufacturers for many devices and it seemed it has one for mine and it worked as my display adapter is still disabled but my graphics are perfect....All the best!
Aug 17, 2010 | Computers & Internet
The shape of the cursor in Visual Foxpro
I, too, am a veteran of DOS to Windows conversions, in fact, I make my living at it. But I learned over a decade ago to get over the differences, like using Tab instead of Enter to move around the screen, and of course, the cursor shape.
If you want your converted program to be accepted by people who have never seen DOS, you need it to follow Windows UI conventions.
Dec 13, 2009 | Microsoft Office Excel 2003 for PC
My 15 year old Toshiba Televisiononly shows a narrow horizontal band in the middle of the screen. Sound OK.
Hiii fairley,
You aren't specsificly dercribe yor tv set.
For common TV horizontal problem ;i.e : White line accross the horizontal screen, horizontal band,etc..it's can solved by replacing the IC Vertical/Transistor, and olso to replace the cap nearest the IC.
For common TV Vertical Problem :i.e : White line at the center of the screen (top to bottom),Vertical band,etc...It's can cure by Replacing the Horizontal IC/Transistor,and offcurse the cap's.
Tha's what all I know....
Hope can help you to solved the problem.
Thank's
h3liax
Jun 22, 2009 | Toshiba 32A33 32" TV
Not printing in foxpro 2.6 dos to hp laser jet 1020
You write "type the above line at command prompt". I dont't know Where exactly to write? Can you tell me!
Feb 05, 2009 | HP PSC 1610 All-In-One InkJet Printer
My Computer Screen
My monitor problem is: it's screen display rotate 90 degrees to left, so we can't watch it normally, I can't work with some program (word, excel, and adobe reader, etc) because it's screen dislay isn't at vertical position but falling to left side. How can I fix this problem? Help me please.
Post by: Syukri Datasan
Aug 19, 2008 | Gateway FPD2275W LCD Monitor
How to convert exel file to foxpro file
You can import the Foxpro file after you've used the DataConnection Wizard. You'll find this under the Data tab in Excel 2007 - under Get External Data section and click on From Other Sources
http://office.microsoft.com/en-us/excel/HP102017101033.aspx?pid=CH100648471033#Importing%20data%20by%20using%20the%20Data%20Connection%20Wizard
Aug 04, 2008 | Microsoft Excel for PC
Xerox XG-91D 19" LCD Monitor Logo
50 people viewed this question
Top Xerox Computers & Internet Experts
Aditya Agarwal
saurav777
Level 1 Expert
Jim LeVerso - IT...
Jim LeVerso - IT...
Are you a Xerox Computer and Internet Expert? Answer questions, earn points and help others
