Question about Cannon Office Equipment & Supplies
Loading the ink jets - Cannon Office Equipment & Supplies
    Genius:
  • 2,785 Answers
Do not connect your printer to your pc. put the cd on cd rom and follow the instruction
Posted on Jul 19, 2008
My printer ink is full and it just printing in black and yellow
The ink leaves the ink-cartridge, and should flow through the ink-jets to be sprayed onto the paper.
If some of the ink-jets are clogged (blue, red) and some of the ink-jets are fine (black, yellow),
then you need to run a few "print-head-cleaning" cycles, to try to unclog those ink-jets.
Jul 19, 2011 | Office Equipment & Supplies
How do I load ink and toner in hp laserjet 1100
By load the toner, if you mean inserting the toner cartridge.Then i will give you instructions.In laser toner printer, there is toner cartridge, and not ink jet cartridge.In laser toner cartridges, there is a black color toner power and it does have any liquid ink, which ink jet cartridges have.To remove the laser toner cartridge from hp laser jet 1100 printer, its simple.The front door open and old toner cartridge comes out.Just pull the front door towards you.While inserting cartridge.If you have problem, then take note that, sticker side of the cartridge is towards you.On the cartridge there is a rectangle flap, which you hold in your hand.This is meant for holding the cartridge, while removing and inserting cartridge.The stick side will be in your side.There is a green color drum, the drum side will be on opposite site.-------------- Still any problem.Keep updated.But i think that will help.Thanks.Helpmech.
Mar 25, 2011 | HP LaserJet 1100 Printer
It says used ink jet full. I don't know what that means. All of my color ink jets are full and I can't even make them come forward to check them but I'm sure they are full. What is the used ink jet.
Used ink jet is probably something like the 'waste toner' cartridge in laser printers. Look in the manual for a reservoir that has waste ink somewhere. Hopefully it'snot in the ink jet cartridge.
What year,make,model printer is this for further research?
Jul 02, 2010 | Office Equipment & Supplies
Has been setting 6 months , has new ink and paper
Ink jet printers are meant to be used regularly, at least once a week.
If it was used before you put it away for 6 months, the ink is dry on the jets.
First try the cleaning function. If you're lucky, after 2 or 3 tries it may work again, and the more you use it the better print quality will result.
Failing that, there are cleaning kits you can purchase.
They consist of a cleaning solution you can inject into a used-up cartridge.
Or better yet, you can take it to one of the places where they refill ink, and for a fee they'll get it going for you.
Apr 18, 2010 | Epson Stylus C88 InkJet Photo Printer
What cause the printer to pause during the printing operation?
This is normal. The printing stops to let the jets for the ink to balance (not get loaded up with too much ink) so the printing doesn't smear. Also allows time for ink to dry some on the paper so you don't smear it when you handle it.
Sep 18, 2009 | Epson FX 2180 Matrix Printer
Nukote Black Ink Jet Replaces HP21
clean the brown dotted circuit of both printer and cartridge with moist tissue and then try.
Aug 03, 2008 | Nukote Nu-kote Canon BJC 600 Multi Pack...
Loading ink jets
Go here. Type "replace ink" in the Search window in the center of the screen and click on the Search button. Select "How do I replace or insert an ink tank?", then go to the section for installing the ink tanks.
Jun 12, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Ink jet problems
> disconnect the unit from the computer
> powercycle the unit
> check if the printer itself is recognizing the inks
> if it doesnt - call the vendor with the issue (you a new model and it´s still very much in warranty)
Dec 25, 2007 | Office Equipment & Supplies
Yellow won't print with old or new cartridge
Some ink jets are differant. Some have an Ink jet cartridge system that has the print head on the cartridge itself. Others use a seperate print head. When you pull out the ink cartridge is there another small unit below the cartridge that you can pull out? If so that is the print head and you will need to replace it. Also make sure that you have taken off the tape off of the air pilot hole on the ink cartridge so it can work properly. www.tonerovernight.com
Mar 16, 2007 | HP OfficeJet G55 All-In-One InkJet Printer
18 people viewed this question
Top Cannon Office Equipment & Supplies Experts
Greg Cann
Greg Cann
Iqbal Husain
Iqbal Husain
Are you a Cannon Office Equipment and Supply Expert? Answer questions, earn points and help others
