Question about Honeywell Heating & Cooling
My thermostat will not stay at the set temperature it will increase temperarue higher on it's own
    Master:
  • 726 Answers
Thermostat is buggerd on the inside
Posted on Jul 19, 2008
How do you increase the water temp?
Hi Donna:
The temperature is pre-set and is intended to be not too hot to inadvertently burn someone. Increasing the setting can cause a real SAFETY HAZARD, especially if small children or seniors are involved.
With that in mind, there will be a panel that unscrews from the side of the heater. After removing it, lift the insulation back and a dial should be visible. There will be numbers, and a pointer with a screw slot in the centre. Turning the pointer to a higher number will increase the temperature.
If you are going to adjust it, only do so a very small amount at one time, until you reach the desired temperature.
Remember, increasing the temperature will not give you more hot water, it will only give you hotter water. If you need more hot water, consider getting a larger tank or an "on demand" gas fired unit.
STAY SAFE!
Jan 12, 2016 | Water Water Heaters
How do I set my chescold to freezer mode do I put the thermostat on low or high
1) always list the brand name "chescold" AND the model number when you have a hardware query. Then google both or go to the brands homepage and see if they offer support.
2) If this involves a chescold operating on bottled gas, regardless of where the thermostat is set, it will like freeze as long as the gas lasts. Yes, even if the thermostat is set to OFF. If the freezer is being chilled by electricity, the thermostat WILL determine the temperature. My best "guess" if the chescold is powered by electricity, a high setting means increasing cold simply because who would make a freezer so that if you powered it to its highest setting, it would thaw out. I generally think increasing a setting means increasing the effect of the machine, be it a freezer or a heater. But it "ain't necessarily so."
3) Usually with freezers, the "higher the number" the colder the freezer will get. But it is a gamble unless you have received proper instruction.
Aug 10, 2015 | Refrigerators
Can't increase the heat on the thermostat
Instructions1 On nearly every Honeywell thermostat, the heat setting can be increased by simply pressing the HEAT option or AUTO and using the arrow keys to adjust the setting higher or lower until the desired temperature is reached.
2 To set an automatic heating schedule for Wake, Leave, Return and Sleep, press the SCHEDULE button, then EDIT.
3 Select the current day and use arrows to select the time and temperature for Wake. For example, if you typically awake for work at 6:00 a.m. and want the heat to come on, use that as your Wake time and adjust the temperature to suit.
4 Select the day and use arrows to select the time and temperature for Leave. Since you will be leaving the home empty for several hours, this setting will allow the thermostat to lower the heat until your arrival back home.
5 Select the day and use arrows to select the time and temperature for Return. This is the time and temperature that you will choose for returning home from work and may want the heat on to warm the house for your arrival.
6 Select the day and use arrows to select the time and temperature for Sleep. Set the time you normally go to bed. The thermostat will automatically adjust itself to your selected temperature at that time.
Thanks
Apr 01, 2012 | Lakewood 2096ET Oil Filled Radiator Heater
Fryer overflows often, turned thermostat down from 350 to approx 340 but food does not cook then. could the thermostat be bad? 10 degrees should not make that much difference.
Does the fryer have a" temperature reached light"? If so switch the fryer on and with the thermostat dial starting at its lowest setting increase the temperature setting in small increments. When the light indicates temperature reached, increase the thermostat dial temperature. Continue until maximum temperature reached.
If (starting from cold) the temerature reached light only shows when high up on the thermostats temperature scale, then unfortunately the thermostat needs replacing.
Hope this helps.
Mar 04, 2011 | Dean D50G-C Deep Fryer
Our coleman fireplace insert starts to warm and then shorts out
Not sure if you have an electric fireplace or a gas fireplace. But, from the way you worded the description of your problem, I'm going to assume that it's electric. I'm also assuming that all the other features of the fireplace work, but the heater doesn' t. If that is the case, below is what the Owners Manual recommends doing.
5. Flame effect operates, but heater does not blow warm air
The TEMPERATURE button is a thermostat control for the heater. Each preset temperature setting has a different thermostat setting as shown to the right:
The heater will NOT activate if the room temperature is above the thermostat setting. If the ambient room temperature is 78° F the user will need to select Setting 3 in order for the heater to be activated. It is normal in warmer climates and in rooms with higher ambient temperatures for the heater to not activate on the lower settings due to the thermostat control. 5a. Try increasing the temperature setting. See drawing:
temp-control-fig.jpg 6. If unit heater does not function, but Power and Heater switches are in the "ON" position and thermostat is set on "HI" 6a. Turn all switches to the "OFF" position and unplug the unit from the wall outlet for 5 minutes. After 5 minutes plug the unit back into the wall outlet, and operate as normal.
Mar 01, 2011 | Coleman Heating & Cooling
Oven flame on right hand oven doesent increase when dials turned up
The OVEN flame size is consistently one size.
The thermostat simply stays closed longer when asking for higher temperature in the oven.
Sep 22, 2010 | Rangemaster Classic 110 (Dual Fuel) Dual...
Thermostates not work properly,
I had the same problem just read the instructions very careful and you will be able to figure that out. I mine has two settings in the morning and two settings in the afternoon.
Jan 15, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Honeywell RTH2310 thermostat temp variance
Yes you can change that by change the number of cycles per hour that your t-stat looks from for youe furnace. Lower the cycles per hour number and it will increase the range.
You can see how to do it here
http://dl.owneriq.net/3/39359643-dfda-451d-bb81-828eecddd9fc.pdf
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 12, 2009 | Honeywell Programmable Thermostat Heater
Frigidaire oven model FEB500CEBI TEMPERATURE PROBLEMS
The short and simple answer is yes you do.
Dec 13, 2008 | Ovens
Gas Furnace doesn't come back on after giving heat for a while.
This is an erratic operation of the thermostat you can reset the thermostat. Please check the reset operation procedure of the installation manual
Nov 18, 2008 | Tappan 30IN ELEC IGNa Oven
Heating & Cooling Logo
67 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
