Question about Epson PictureMate (C11C556001) InkJet Photo Printer
Looks like too much ink
When I try to print a picture it comes out saturated with purple ink. Why is it doing this and is someway to fix it? I have already tried cleaning the heads and the nozzles.
  • 114 Answers
Try a different brand of photo paper, some of the papers will cause this. Especially the lower cost photo papers.
Lou
Posted on Aug 24, 2008
Correct settings for printing on semi-gloss paper. I keep getting smears when printing and photo doesn't come out clearly
Well, it would be good to know why the photos are not good quality... like blurry or bad color or? Are you using a good paper? I have great luck with Canon glossy, and love the matte paper from Staples. Matte is actually easier and all around better color saturation, I find. I guess that you are using too much saturation of ink... see if your dialog box for printer options has a way to make saturation less intense. Also, I assume you are using the same dialog box to choose the type of paper. That is important, since different papers absorb ink at different speeds and amounts. I hope that helps... keep trying!
Nov 02, 2014 | Epson WorkForce WF-7520 Wide Format...
I print flower pictures. Purples/blacks/blues come out with a lot of red in them - for instance, purple comes out maroon. How to I reset the colour balance?
Assuming it is not a problem with ink or toner feed, the normal printer does not determine internally the colors but only follows instructions from the application (program) you are using.
If a test page from the printer shows the correct color or color balance, then you will have to do the color correction from the program that is controlling the printer.
Carefully read of the application's features and the variables possible from within the program itself.
BTW, the paper stock you are using and its absorption characteristics can also influence color saturation too.
Also, it is helpful if you include brand name and model number of the device for which you are requesting help.
Apr 05, 2011 | OKI Office Equipment & Supplies
Hi there I have the original canon cartridges in the printer and they all have lots of ink in them, but suddenly when printing the 'black' parts of a photograph looks purple. But when I print text in...
When you are printing a photograph, the back is resultant of combination of RGB but when you print a latter of document it usages only the black ink. So since the black is properly printed when it's combining RGB that means any of the color is low on ink. Replacing the color cartridge will solve the problem for you.
Mar 15, 2011 | Canon Pixma iP4500 InkJet Printer
When I print the picture has a purple haze in it ?
If you are using re-manufactured ink tanks, that would explain it, a mi-matched ink tank. To clarify the ink colour is not quite right.
If genuine ink tanks (Recommended) then maybe try different paper. If using photo paper you should be using compatible / genuine paper as the different chemicals react can give this problem.
If using fax / standard paper then could be print head fault....normally get an error code.
Jan 26, 2010 | Dell P703w Printer
When printing pictures, they are discolored
You are running low on your color ink cartridge. It cannot mix the primary colors right anymore and the color images start getting a pink-purple tinge to them. Get a new set of cartidges and install them and this should fix the problem fine. Hope this helps.
Mar 26, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Light in color and won't copy dark. It come out light purple
you may try
1) color ink cartridge--- no enough ink or the cartridge ink channel dryer and constipated, refill ink and put down the cartridge bottom surface to water a little for 1 hr, then set back. or change a new cartridge if not fixed go next
2) print head--- the ink channel dryer and constipated, take out print head clean it's ink channel using cleaner or steep in water (do not touch circuit pin area with water) 20 minutes or longer. then set back and test (you can do more times), still not fixed, your print head have to change.
Feb 06, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Bad color print out
u first check the ink level on the catridges,mostly inks are too low
ink is ok -u use printer utilities like headclean
Mar 01, 2008 | Konica Minolta magicolor 2300DL Laser...
Photo printing
What program are you using to print out photos?
Try to take the ink cartridge out and put it back in.
Go to this link, instructions on how to replace ink cartridges
http://files.support.epson.com/pdf/cx66__/cx66__pg.pdf
And then try to print. If you have the same problem, try to use another program that you can print pictures from.
Feb 04, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Epson PictureMate (C11C556001) InkJet Photo Printer Logo
162 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
