Question about Dell 3000cn Laser Printer
An Empty Stripe along the right side of portrait setting
I have a Dell 3000cn color laser printer. In March I started to get an empty stripe (no print for about 1/4 inch on the right side of a portrait page or the bottom of a landscape page. I read what I could and decided to purchase a new imaging drum. I replaced and the problem disappeared for maybe 100 pages and then it came back, so I doubt that it is an drum problem. Can you help me. I have to write in the missing information or make a very wide margin that really doesn't work for some printing needs I have.
I REALLY would APPRECIATE your valuable expertise.
Thanks a bunch and have a great day.
Sue
  • sueleef Jul 19, 2008
    The stripe is about 1/4 inch thick and in about 3/4 inch from the edge of the page.
  • 1,879 Answers
Greetings,
Laser printers have mirror inside where you can clean it a built-in cleaning wand. Check your manual.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Posted on Jul 19, 2008
  • 4,472 Answers
Have you tried a new toner cartridge? There is a couple possible culprits.
Thanks,
Lee
I'm getting a line that isn't printing through my printing from a Fuji Xerox DocuPrint C3055 DX
Possible reasons are: 1.empty toner cartridge, 2.dirt under one of the toner cartridge's developing roller, 3. dirt on the primary charge roller in the drum cartridge, 4. obstacle on the laser path.
Replace the empty toners first and try printing again. Follow the next steps if it didn't solve the problem.
Print a test page with 4 stripes across the page - black, cyan, yellow and magenta. See if all have the missing toner line or only one of them. If the white stripe is going trough only one color, inspect the cartridge with that color. It has to have the same stripe on the developing roller. See if there is some dust beneath it that makes the stripe and clean it with a brush. If the stripe is across all colors, then inspect the drum unit. The drum itself has to be evenly shining on the light. If there are uneven matte tracks on it, consider replacing. There should be a gap somewhere for the laser beam to pass and the drum is visible trough it. Look trough it for obstacles like piece of paper or hair. The primary charge roller has to be close to that gap inside, touching the drum. Look for dirt on it. Clean if possible.
Toner cartridges last approx. 6500 pages. The drum cartridge lasts between 14 000 and 28 000 pages depending on the color use.
Jul 02, 2014 | Digital Products Office Equipment &...
Installed new yelloe cartridge but printer keeps stating to reseat cartridge
009-340 Error on the Dell Color Laser Printer 3000cn/3010cn/3100cn ...imaging drum cartridge. Turn the printer off using the power switch on the left side. Wait 10 seconds, turn the printer back on, and check if the error message...sensor solenoid nip. Turn the printer off using the power switch on the left... (English) 016-720 PCL Error on the Dell Color Laser Printer 3000cn/3010cn/3100cn ... Press Select ( ) to clear the error on the printer. Reset the printer NVRAM: Press Menu. Press the...and then press Select ( ). When Restart Printer appears, turn the printer off and then back on... (English)
KB Article How Do I Configure and Troubleshoot My Dell Color Laser Network Printer? - KB Article - 296059 ...Troubleshooting Guide for My Dell 3000cn-series / 3100cn Laser Printer ...available online for your Dell 3000cn/3100cn laser printer. The troubleshooting...printing, refer to the Dell Laser Printer 3000cn/3100cn Troubleshooting Guide... (English)
Dec 13, 2010 | Dell 3100cn Laser Printer
I need the Dell 3000cn printer service manual
http://support.dell.com/support/topics/global.aspx/support/my_systems_info/manuals?c=us&l=en&s=gen&~ck=anavml
You can download the manual from the above link. If that doesn't work, go to support.dell.com and follow the links to the downloadable manual. Start on the left hand side by selecing Manuals (found under the "Product Support" heading)
Feb 19, 2010 | Dell 3000cn Color Laser Printer
Dell 3000cn color printer - black/grey line down right side of page. Is it the drum? How to check drum?
Sounds like the black drum. You can't get the part from anyone but Dell so be prepared for the cost. It also requires some disassembly to install on my Dell 5110cn so yours most likely will also.
Jan 27, 2010 | Dell 3000cn Color Laser Printer
Pale vertical stripe on black prints
It sounds like the black drum unit needs to be replaced.
Apr 23, 2009 | Ricoh Aficio CL3500N Laser Printer
Why are documents printing with a black stripe on right side?
You most likely have a defective cartridge. It is also possible that your Charge and/or Transfer rollers have become defective.
Inspect the cartridge for any band of remaining toner.
You should notice one or two long thin rollers, with the cartridge removed. There will be a dark roller that should appear textured, but not dull. And they may also be a lighter colored roller with no marks.
These are the three common problems that create lines.
Lastly
If the band is mostly straight, it is most likely the cartridge
If the band is wavy or broken in anyway, it is probably the roller(s)
Let us know what you find
Apr 15, 2009 | Dell 3000cn Color Laser Printer
Changing Dell 3000cn printer cartridge
The instructions always come with the new cartridges and also are printed on the new cartridges. You move the right hand (colored) side up to unlock. Carefully pull the cartridge up and out (you can screw up the gears if you don't put the cartridges in and out straight. Make sure you've followed the instructions that come with the new toner cartridge (removing tape, shaking), put it in the same way and move the right hand side down to lock.
Apr 07, 2009 | Dell 3000cn Color Laser Printer
1995 Ford Windstar Speaker Coding Scheme.
www.installer.com as speaker schematics
Dec 22, 2008 | 1995 Ford Windstar
Printing
Try the settings in the printer.
Push Menu button till you see menu
then the down arrow around the enter button till you seetray settings - hit enter
go the paper size - hit right arrow
hit down arrow to the MPF then hit right arrow
then down arrow to change to "letter" size
Good Luck
Aug 15, 2008 | Dell 3000cn Color Laser Printer
Dell 3000cn Laser Printer Logo
208 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
