JVC DVD players
Hi
does anyone know which JVC DVD players use the 8 pin "system cable" to connect to a powered sub-woofer? I have a set of speakers including the powered sub-woofer, but no dvd unit to connect to the 8 pin input. Can anyone help or even suggest a method of converting the 8 pin format into something a little more commonplace?
Thanks Guys
Graham (UK)
  • 2,071 Answers
Use a sling for multiconnection to connect 8 pin input;
Sling Media - Slingbox
Posted on Jul 19, 2008
I have a jvc seteup but reciever is broke.is there a way i can get a adapter to plug sub woofer with power amp into a a yamaha reciever?the plug that goes from sub woofer also powers other speakers, cable...
Here's a manual.
http://www.retrevo.com/support/JVC-TH-M505J-Home-Theater-Systems-manual/id/318dj491/t/2/
That cable not only carries audio but it also powers the sub and other channel amplifers. Even if we could supply the pin-outs for the channels I'm not sure what we could do to provide subwoofer power. We're talking about a major rework.
This is a highly proprietary design, meaning it's really not very adaptable to normal spec audio equipment.
There's a flat-fee repair service for the receiver ($99.95, free return shipping):
http://cgi.ebay.com/JVC-TH-C50-TH-C5-TH-M505-Repair-Service-/360178567658?pt=LH_DefaultDomain_0&hash=item53dc50c9ea
Maybe they could fix your receiver.
You COULD try to reach the manufacturer for other options.
http://www.jvc.com
800-252-5722
Jan 12, 2011 | JVC TH-M505 System
I recently picked up the THC-c60 system without the supporting amplifier. Can I still use the subwoofer and the speakers without the amp? I note that it also came with a DIN cable, is there some way to...
You can use the sub-woofer and the speakers even without a supporting amplifier. The sub-woofer alone is powered with 167w per channel enough to power all the speakers. The DIN cables used to connect the sub-woofer to any source device like a computer, multi-media projector and others.
Dec 02, 2010 | JVC TH-C60 System
My JVC SP-PWM508 no longer functions.
I am looking for the cable connecting the sub woofer and the main system(CD Player)
Mar 14, 2010 | JVC SP-PW100 Subwoofer
Digital Optical port to 8-pin din
Optical digital cables can't be magically wired to copper inputs. NO digital signal can be magically connected to an analog interface and work.
Even if you could do what you propose, how would you control volume?
Why don't you just connect the BluRay to the JVC system and let IT handle the audio to the sub and satellites?
Run an optical cable to the JVC TH-C60's Optical In port. Make sure there are no tight bends in the optical cable as that will degrade its ability to transmit a signal.
Jan 30, 2010 | Audio Players & Recorders
AV receiver single line output to two line input on sub woofer
You are trying to connect the powered sub output of the receiver to a standard (unpowered) subwoofer. Can't be done.
May 05, 2017 | JVC Audio Players & Recorders
Connect a new dvd player at the home cinema set??!!!!
You can go for Samsung, Lg or any product of your choice. The most important thing is that you check the back of your old player to see the connections, and make sure the player you are about to by has those connections also so that you would be able to connect your old sub woofer and speaker with the new player.
Nov 06, 2009 | JVC TH-M45 System
I just replaced the cord running from the sub to the dvd player. now my sub will not turn on
hi,
steps to trouble shoot for sub-woofer detection :
1. please check whether the cord is securely connected at both the ends.
2. check if there is transmission through the cord (there'll be a small static through the cord if there is transmission.)
3. reset the dvd-player to default audio-output and then choose the 5.1 sound system which is the correct setting for the th-c6.
4. also check the settings in the th-c6 whether it is in 5.1 mode(whether it includes the woofer-as it can also simple use the stereo speakers)
5. now check the sound output in all speakers by playing any original home-theatre system enabled dvd.
the system will work perfectly if the cord is in good condition, otherwise please replace the cord again, and this time check it at the store.
cheers
Jul 17, 2009 | JVC TH-C6 System
JVC TH-M45
no, u cant use the speakers with other normal DVD player because it wont have amplification for the speakers... u can use the sub to other dvd player because its inbuilt 120 watt woofer. ur dvd player is 5-disc player as wel as 120 X 2 and 80 X 3 watts amplifier (AV receiver ).... so just the JVC better sound thru the sub and speakers... ENJOY
kanny_amancha@yahoo.com
www.kanny-sounds.blogspot.com
Jan 24, 2009 | Pioneer 1000 Watt 5.1 Surround Sound...
JVC THR1 DVD Digital home cinema system.
There is other Cinema Surround systems that use the same 8 Pin setup Aldis had one retailing at £49.99 and there are plenty on E-Bay www.eserviceinfo.com will provide schematics for these systems so you can select the right one.
Jul 17, 2008 | Audio Players & Recorders
JVC 8 pin pinout - speaker cable
Looking at the connector, there are 3 rows of pins.
Starting with the first row closest to the alignment mark:
[Power On],[Center Speaker],[Sub Woofer]
[Surround Right],[Speaker Ground],[Surround Left]
[Right],[Left]
If you are trying to connect two JVC units, you will need an 8-pin cable that has the SAME pins connected on each side. You will need to test this using a multimeter set to ohms or 'connectivity'.
There are other 8-pin cables out there like the one for apple networking, but they use a crossover pinout where pin 1 on one end = pin 3 on the other end. This is bad. JVC needs pin 1 to = pin 1.
This is a standard connector/pinout setup that JVC uses, so connecting a TH-C3 to a TH-C50 works fine. There is a bunch of intermixing that you can get away with. The only thing to keep an eye on is the power in watts that one unit sends and the other recieves. Worst case is that the speakers are quiter than expected or that you can turn the volume up so high that it can damage the speakers. In all cases, you should get desired volume somewhere on the dial.
If you are trying to wire the speaker set custom, then you will need to take note that an '8-pin' connector is actually a 9-wire connector. Along with the above pinout, you will need to add Case Ground, which is the metal circle that surrounds the pins. To make the speakers turn on, you will need to apply 12v to the Power On pin and ground the 12v source to the Case Ground outer ring.
The system takes 3 to 4 seconds to fully turn on after this connection is made. Speakers should be wired using the center pin for speaker ground and each other pin respectful to each speaker.
Apr 01, 2008 | JVC TH-C50 System
136 people viewed this question
 Grubhead
Grubhead
