Question about E-Machines EMA IMPERIAL GV (845GV) TG3 eMachines (145119) Motherboard
Computer will not start up :(
My computer when I press the power button will not start up.
The fans turn on and the light in the front near power button lights up. I get nothing on the screen and it stays like it is starting up forever..
What could be the problem?
also this is not my product I dont know how to find what mine is. It is an emachine though.
  • 80 Answers
Hi my name is wesley. ok thereare a few problems that it may be il list them all. 1 it could be a loose cable to your hard disk. 2 your pc might of over heated and fried the cpu. 3 it might be that your graphics controller has crashed witch means you might need to get a new graphics card. 4 it might be your memory try taking it out and puuting it in a different slot on the board. if it is the cpu you will beable to smell it if it is that is a big problem but unlikely the problem tho. please let me know what happens.
Posted on Jul 21, 2008
My dell inspiron 1525 wont even come on when i press the start button, nothing?
Hi Jerrel Castille,
Request you to try following the below steps which might help:
    (1)Turn off the computer.
    (2)Remove all the external peripherals like AC Adaptor, flash drives, battery, etc.
    (3)Press and hold the power button for 30sec which releases the static on the computer (if any)
    (4)Put back the battery and plug in the AC Adaptor.
    (5)Let the computer charge for some time.
    Now try turning on the computer. If still same issue then check if there are any series of beep codes emitted from the computer and see if there is a Power/ Battery status light glowing near the front (touchpad) of it.
Feb 05, 2015 | Dell Computers & Internet
Pc not starting When I press power button on cpu
If you are not getting the computer to start up but you are getting the fans to whir for a moment and the keyboard lights to flash, then that means that you probably have a bad motherboard. If you had a bad power supply, most likely none of these secondary indicators would be present. I would advise taking the computer to a local computer repair shop and having a professional investigate the problem. More than likely, he will be able to tell you the cause of your problem in short order.
Oct 12, 2014 | Computers & Internet
My friend karen press the power button, thre is no power... there blinking lights on the back of the computer near the fan power ...
Do you hear the harddrive start up? When you push the power button (or switch on the back) do the lights go out? If you hear fan running and hard drive start up then the computer itself might be on but the monitor isn't. Check the power to the monitor, the connection between monitor and computer to make sure they are all on and connected.
If you don' t hear the fan running then you have other problems. Any blinking lights would indicate something is getting power. I'm assuming the computer was working before the power button was pushed... If the monitor is actually working, you could hook up another monitor to check too then you have other problems but need more info to know what that could be.
would need to know the answer to the above questions as well as if it was working before, what was done, what changed between it working and this problem. Also what age the machine etc.
Jul 06, 2011 | Computers & Internet
When the computer on/off button is pressed , the CPU fan and tower exhaust fans start running, the blue light around the power button does not light and the boot up process goes no further. Fans continue...
A) When you hold a Power On button, (Switch actually), in for a count of 10 seconds, it turns the computer off.
(There is a Power On switch, located behind the plastic Power On button. Usually, the Power On switch snaps into the housing of the plastic Power On button.
Example of a typical ATX Power On switch,
http://www.directron.com/atxswitch.html
The Power On switch turns the Power Supply on.
Old computers had a metal rod, that when the Power On button was depressed, the button pushed against the metal rod, which in turn pressed against a power switch located inside the Power Supply.
The design after that, was a power switch located in the Front Panel. (Plastic front of the computer) A large cable, (Wire) ran from the switch to the Power Supply.
Now there is the Soft Power On feature. (PS_ON)
The Power On switch is a small Momentary Contact Switch. Pressing it closes a circuit. The Soft Power On circuit.
When a power supply is plugged into power, there is a constant 5 Volts (DC) present.
This is the 5 Volt Standby.
Closing the Soft Power On circuit, redirects the 5 Volt Standby power to a circuit within the Power Supply.
This in turn 'excites' the Power Supply, and turns the Power Supply on.
Sorry to be windy, but I wanted you to know how the Soft Power On feature works )
eMachines are a budget computer. As such they save the consumer money.
However in order to do this, the manufacturer will install low quality parts, in some areas of the computer.
One such part is the Power Supply.
1) ALL the LED lights combined use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts
3) A typical Processor can use 51 to 125 Watts.
Depends on what Processor it is.
(Had you stated the Model Number I could have told you)
Enough power to spin fans, but not enough to spin fans, AND turn the Processor on.
Do you have access to another computer that is unused, but has a Known to be good, Compatible power supply?
It could be used for a test unit.
Tell me the Series, and Model Number of your eMachines, and I'll tell you what Wattage it should have, and what power cables, for the Power Supply.
(Some examples of Series, and Model Numbers, T1090, E4264, W2925, and so on. The T, E, and W are a few examples of the Series letter.
The numbers following the Series letter, is the Model Number)
If you wish I can direct you in removing the Power Supply, and installing the test unit. (And/Or a new Power Supply)
Sep 12, 2010 | E-Machines eMachines Desktop PC
Computer was working fine. Turned it off and the next I went to use it the screen will not come on. I understand that there is a certain key that you press to get it back on but I don't know which one it...
When you press the ON button, do any lamps on the front of computer light up? Do you hear any fans start to spin?
Do you feel any air being blown out the back (source is the fan inside the power-supply) ?
If not, your computer's power-supply has failed.
Take your computer to a computer-store, and get them to sell you a replacement. Probably less than $50.
Hint: the smaller store that you take it to, the more-likely that the sale of the power-supply will _include_ "installation" of the new power-supply.
Aug 05, 2010 | Computers & Internet
Fan works randomly....when it's not working plug
Hi, If the computer is hot near the electrical plug in the back of the computer then the power supply needs to be replaced. This will also cause overheating problems if the fan does not exhaust enough air. You should not run the computer in this condition because the power supply can short out and take other components with it. Also there is a risk that it will burn up. Power supplies are very inexpensive and can be changed by anyone with basic computer repair knowledge. Hank
Jul 26, 2010 | eMachines T5212 PC Desktop
Press power button. Green light turns on, fan
there is power buttom on the keyboard makes it wake up. try it
Oct 02, 2009 | Dell Inspiron 530s Desktop Computer...
I have a Gateway Mx6440 Laptop and et CPU FAN error upon boot. afte w while i try spinning th efan and it starts working, i belive it is the heat sink that is defective but where can i find the proper fan...
"Turn off computer and unplug power cord. <br>Disconnect all external devices. <br>Remove the battery. <br>Press power button and hold for 10 to 15 seconds. <br>Plug power cord back into computer and press power button. <br>Check front panel LEDs (lights) on bezel (front face) or optical drives and listen for power supply fan. <br>If LEDs are on or power supply fan starts spinning, watch for boot screen on monitor. <br>If computer begins to start, turn it off. <br>Reconnect any external devices. <br>Press the power button and make sure the computer starts.
Please save this steps and go through that. If in case you require further help, you need to contact Answers by Gateway department which is a paid support. The phone number for Answers by Gateway is 1.800-237-6483. Or please consider contact with a local technician for a detailed troubleshooting."
worked for mee!! good luck
Feb 22, 2009 | HP (158800-001) for Compaq Presario 1246,...
Front panel Ac Switch failing to start computer.
Try these steps.
If Power supply light does not turn on (or no power supply LED)
Perform the following steps, in order, until power is restored or it is determined that there is a hardware failure:
NOTE: If the Power Supply fan spins when the PC is turned on but the light does not come on, it is possible the LED is defective. If this is the case, use the section Power supply light comes on or flashes .
1. Disconnect everything from the PC, including the power cord.
2. With the power cord disconnected, press the power button on the front of the computer. Plug in the power cord and test to see if the computer can turn on. If not, continue using these steps.
3. Replace the power cord with another power cord, like the one used by the monitor.
Test to see if the computer can turn on. If not, continue using these steps.
4. Ensure that the voltage selector switch is on the correct setting, 115V for North America.
5. With the power cord removed, flip the red voltage selector switch to the opposite position, wait about five seconds, and then switch the red voltage selector switch back to its original location.
This ensures that the voltage switch is engaged and set correctly for your country/region.
6. Plug in the power cord and test to see if the computer can turn on. If not, continue using these steps.
7. Plug a lamp into the same outlet to see if the wall outlet has power. Try the computer in a different outlet in order to eliminate the outlet as a possible source of the issue. Test both to see if the wall outlets have power.
8. Remove all extension cords, power strips, surge protectors and any converters that remove ground. Plug the power cable directly to the wall outlet. Test for power. If this fixes the issue, find the device that is causing the issue and do not use it.
9. Use a vacuum cleaner to remove the build-up of dust from the power supply fan vent holes. Make sure that the PC is turned off and that the power cord is plugged into a grounded outlet. Only use the end of the vacuum hose near the outside of the fan entrance.
10. If all of the above steps have been tried and the power supply light remains off, use the steps in the next section, use the next section Power supply light comes on or flashes , to reseat the cables and check the power switch connector.
Jan 11, 2009 | Compaq Presario SR1000T (568657) PC...
Hp nx7010 not starting
hi
it is mother board problem replace it it will help full to you.
by by.
Nov 18, 2007 | Compaq Presario 700 470024-192 Notebook
Computers & Internet Logo
70 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
