Question about RCA R52WH73 Projection Television
I have serial number hd52w59
I am having the same problem as the hd52w20. The convergence is not an option any longer on our set up menu. Do you happen do have any information on this serial number? Would it be the same type of "fuse" repair as you described on the hd52w20? Thank you very much.
Mary McCann CONVERGENCE IS NOT IN SET UP ANYMORE. AND PICTURE IS DOUBLE WITH RED, GREEN, AND BLUE COLORS. HOW DO I FIX?
    Genius:
  • 1,030 Answers
Yes although not as common on these sets if the convergence option is missing i believe that the fl231 problem is what is wrong with you set
Posted on Sep 20, 2008
2 Suggested Answers
  • 1030 Answers
SOURCE: I have serial number hd52w59
the fl231 fuse problem will apply to any itc222 chasis set. The hd52w20 is an itc22 chasis.. although i have not seen it in that set if you do not have the convergence option in setup. that is my first choice in possible problems. a simple ohm chech of that fuse can determine if it open. Warning this television can generate potetial leathal voltages care should be taken when working with set with back off.
Posted on Jul 11, 2008
I see a possible fix for missing convergence on a rca hd52w59 by replacing the convergence fuse. I've looked all over and can't find it. If it really has this fuse, where is it??? Thanks
If your looking in the rear of the set on the far left side you will see a large black HV transformer that has a large red wire coming from its top. Thats the flyback transformer look directly to the right of that and you will see three small brown rectangles with FL221, FL231 and FL251 stamped on it. The center one is FL231 if thats blown the set will have a 3D look and the auto convergence feature will no longer be listed under the setup menu.
Dec 18, 2011 | RCA HD52W59 HDTV Projection Television
I need to know what convergence board I need and part number. TV is RCA Model HD52W59YX36. Symptom is see 3 d like shadows. When I go to do the covergence adjustment from the setup menu....nothing appears...
You dont need a convergence board. The convergence option missing from the setup menu is a easy cheap repair. www.tvrepairworld.com has the kit called ITC222 & 222A convergence option missing repair kit. It also has the CD with instructions along with the three components that repair that problem.
Mar 27, 2010 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 HDTV Television--the picture 3-d images colots red blue and green, been working great till this after noon any help please
When you presss menu and then select settings is the auto convergence and convergence options still there or have they disappeared/ Let me know and I will assist you with the problem.
Dec 17, 2009 | RCA HD52W59 HDTV Projection Television
Convergence option missing from set up menu rca hd52w59
Usually if something is missing from the main menu or no longer listed in the menu, is because the Main EEPROM has crashed. To get the right replacement, you will need to have the Chassis number, (CTCXXX), at the time of order. You can order it from Encompass Elect. at 1800-638-3328.
I hope this helps
Skyassoc
Nov 15, 2009 | RCA HD52W59 HDTV Projection Television
Rca 52 in convergence problem, colors not aligning. convergence is no longer an option on the set up menu to attempt to fix. it no longer appears there. how much to fix this or just junk it. it is almost 4...
You can repair it for about 24.00 you can get the repair kit for that issue at the following link. The Kit contains the parts and the cd with instructions on how to do the repair. Its called the ITC222 and ITC222A convergence option missing repair kit. Its under the RCA repair kits Category.
http://www.tvrepairworld.com/
Jul 13, 2009 | RCA HD52W59 HDTV Projection Television
I have an RCA HD52w59 with a convergence problem. I've been told different things on this site. First I was told to change FL231, CL230, and DL231. I've also been told to replace both IC's (STK392-110)...
Your set doesnt have STK ICs. If the convergence adjustment option has disappeared from the on screen menu, then replace FL231, DL231 and CL230 If the adjustment option hasnt disappeared from the menu then you need to check the resistors on the convergence power supply board some of those will be open. The actual convergence Board will usually not develope problems just the Convergence power supply if the convergence adjustment option is still in the on screen menu.
Mar 15, 2009 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 Crooked Convergence
Convergence power supply needs to be rebuilt as its no longer available new. You can get the board rebuilt at the following link and its fully guaranteed.
http://servicemanuals.vstore.ca/
Mar 04, 2009 | RCA HD52W59 HDTV Projection Television
Fl231 fuse compatibility
yes, thats the replacement fuse for your set. However unless you have replaced the convergence power supply also chances are the fuse will blow again, as the power supply shorting is what causes the convergence to get out of alignment and it will then blow FL231 thereby removing the convergence option from the menu.
Sep 02, 2008 | RCA HD52W59 HDTV Projection Television
Jul 10, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Conversation
The service # is hd52w59 and then something like yx1 or etc..... On the model # tag, this is written in very small writing. There is no way to remove the convergence option. Go to menu the set up and there you should find convergence. Choose convergence and run auto converge. If this does not work then there is a failure on the convergence power supply, convergence amp, or the deflection/power bd.
Mar 19, 2008 | RCA HD52W59 HDTV Projection Television
RCA R52WH73 Projection Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
