Question about RCA DRC8335
Stuck disc how would you suggest getting a disc out?
  • 258 Answers
Most disk drives have a tiny hole below the tray. I straightened paper clip pushed carefully into that hole should unlock the tray and push it forward slightly. Once unlocked, it is OK to GENTLY pull it the rest of the way out. The disc can then be removed.
Posted on Aug 14, 2008
Game stuck in console will not come out
My friend had the same problem once. repeated ejecting didn't work because there is a small bracket that retains a disc in the slot until eject is pushed. Sometimes, this can get stuck and the only solution I found was to open the unit up, clean and regrease the offending gear, and play on. Opening the console will void any warranty, though.
Also, I would highly suggest that you NOT attempt to pry the disc out as it will damage the disc and STILL not be removable. As I said, there is an arm that moves across the disc entry that prevents it's moving unless it is ejecting.
Jan 03, 2010 | Nintendo Wii Console
Game stuck after gummi ship!
Is your disc scratched or dirty?
If so, the game could be hanging because
it can't load the results screen.
If that seems to be the problem, I'd suggest getting the disc resurfaced at a video store or games store.
Oct 03, 2009 | Square Enix Kingdom Hearts II for...
Stuck disc
Unplug Wii Power.
Plug back the console power, start back and press repeatedly the start button while the console is starting. Before the laser lens starts reading.
If that does not work, then there is need to disassemble the Wii, in that case call Nintendo first.
Here useful websites:
this article
Wii Disc?
Apr 05, 2009 | Nintendo Wii Console
CD/DVD's "stuck" while playing. Panasonic SA-HT640
get a fue qutips and some rubbing alcohaul clean the eye if visable and u should have a black shaft with 3 berrings that hold the cd/dvd into place clean that thuraly. do this with the batteries out and it un plugged make shure that u use extra alcohaul on the shaft. let it sit for a little while then try it. if it dosent work get back to me. please rate my suggestion. thanks
Feb 01, 2009 | Panasonic REGION FREE SCHT700 5 Disc DVD...
Stuck disc (similar problem)
In the front of the tray there a small whole, try bending a paperclip straight with a small hook at the end and careully stivk it in that whole. Than gently try pulling it back thus opening the tray. Remove your disc and do not put any other disc in it but try to close the tray by using the button. If it closes, try to reopen it.
Check your disc for any dirt or perhaps some remains of stickers.
Be carefull with homemade discs, they might have a stickered label on it which can cause problems such as getting your tray stuck and not opening anymore ;-) .
Jan 05, 2009 | Philips HTS3450 System
NetFlix Disc stuck!
call service if it is under warranty sticky disks are common on these dvd included models i would get the service tech to remove it and go to walmart and buy a 38 dollar dvd player with 480 progressive scan and use that externally from now on, by the way can you change to tv viewing or is it stuck in dvd play only?
May 12, 2008 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
Stuck disc drawer rca model drc8312n
If there is a tiny pin hole in the front a straightened paper clip does wonders. Simply insert to release the drawer. At least that's how it works on computers ;)
Mar 28, 2007 | RCA DRC8312N DVD Recorder/VCR
Camera wont take a disc
hi NanaR, i suggest a try with new disc,problem still remain, i think there is a mechanical problem with disc holder. I suppose you have the facility to use memory stick so why you use the disc just use the memory stick. It is better for you. to fix the problem you have to go to sony shop.. good luck...
Jul 28, 2006 | Sony Mavica MVC-FD75 Digital Camera
RCA DRC8335 Logo
85 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
