Question about Lands Phones
Have purchased an Uniden SS E15 1 cordless phone. I followed the set up instructions. The second phone when dialing emits a squealing noise as I connect. The person I called can hear me and I can hardly them. I have tried to alter volume with no result. Number 1 phone is fine. I have re-registered both phones 3 times. Frustrated, Pel.
Frustrated Pel. packed it up and returned phones to store.
They replaced it with no trouble. The second phone WAS a dud !
Sorry to have wasted your time.
Pel.
Posted on Jul 24, 2008
I cannot get a dial tone
check the base unit is plugged into the line socket at the wall
if it is a new set then follow the setting up instructions in the owners manual
if it has been working the make sure that all the end call buttons have been pressed as if not you will have a line still in use and there will be no dial tone ( phone off the hook)
Apr 28, 2015 | Uniden Cordless Phone
Speed Dial
Select the model of the phone from the list at
http://www.uniden.com/index/manuals_results.cfm?cat=1
May 20, 2010 | Uniden Cordless Phone
Uniden cordless just squeals when green button pressed.
Your best bet is to completely take apart the phone and let it air dry for a day or two. If this still doesn't fix the problem then your phone will never work again. Sorry to be the bearer of bad news.
Sep 21, 2009 | Lands Phones
Purchased New Uniden cordless phone wih and answering machine. This item works properly. Purchased the matching space phones Uniden DXI 8560-2. The instructions on the back of the phone simply says to set...
YOUR PHONES ARE NOT EXPANDABLE TO MORE THAN WHAT THEY COME WITH, ONLY BECAUSE YOU WANT THEM TO WORK TOGETHER DOESNT MEAN THAT THEY WILL WORK TOGETHER...
Jul 19, 2009 | Uniden Cordless Phone
How to set up Speed Dial on a Uniden phone?
My Mom had this same problem.   I found these instructions on Uniden's website (uniden.com) under the "Owner Manuel" section.
Here you go - good luck!
Using the Speed Dial Memory
Storing Numbers in Speed Dial Memory
Your cordless phone can store up to ten numbers (up to 20 digits each) in the speed dial
memory. To store number in memory:
1) When the phone is in standby, press [memory]. The talk/batt low LED flashes.
2) Use the keypad to enter the phone number.
 (To enter a 2-second pause between numbers, press [redial/
pause]. Each pause counts as a digit. )
3) Press [memory] again.
4) Select the speed dial location where you would like to store the
number ( [0] to [9] ). You will hear a confirmation tone indicating
that the number has been stored.
NOTE:
• Storing a number to a speed dial location will
overwrite the any previously stored number without
warning.
• When storing numbers into memory and the handset is idle (i.e., no key is
pressed) for more than 0 seconds, it will beep rapidly, and then the phone
will return to standby.
Dialing a Stored Number
1) When the phone is in standby, press [talk], and listen for a dial tone.
2) Press [memory] and enter the speed dial entry ([0] – [9]) that has the stored number
you want to dial. (If you enter a digit that does not contain a stored number, the
handset will beep rapidly, and the phone will not dial.)
Chain Dialing
The speed dial memory is not limited to phone numbers. You can store any number (up
to 20 digits) that you need to enter once your call connects. This is referred to as Chain
Dialing. An example is a frequently refilled prescription number. Store your pharmacy
phone number in one speed dial and your most frequently refilled prescription number
as another speed dial. To use, once you ring your pharmacy's automated prescription
line, simply press [memory] and the speed dial number where you stored your account
number.
Erasing a Stored Number from Memory
1) With the phone in standby, press [memory] twice.
2) Press the number of the speed dial entry. A tone indicates that the stored number is
erased from memory.
Jan 11, 2009 | Uniden Cordless Phone
Noise before dial tone
that usually means you have messages waiting. clear your messages and that should stop.
Nov 11, 2008 | Uniden Cordless Phone
Ge 900 MHz cordless phone set on rotary dialing
Lisa, If the 900MHZ phone is Model 26928M programming for rotary dial usually goes like below, can't hurt to try on any model. TONE/PULSE DIALING This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for touch-tone use. To set to tone or pulse dialing: 1. Press and hold the program button for two seconds. You will hear a beep. 2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing. 3. Press the program button again. You will hear a confirmation tone.
Sep 29, 2007 | Uniden Cordless Phone
Lands Phones Logo
113 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
