Question about Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony wega 27 inch
The autoprogram prompt keeps coming on. it allows you to exit by hitting the channel down button, but it keeps coming back on. Thoughts?
  • TabbyT Jan 13, 2009
    I have the same problem--it flashes the channel input screen over and over, for varying lengths of time. I will try the suggested solution of unplugging it overnight, but it may be time to ditch this TV set.
I posted originally about a year and a half ago about this very same problem. It is a known defect with the WEGAs that Sony refuses to do anything about. Here's the thread with my experience - the upshot is, try doing a "hard reboot" by unplugging it and leaving it unplugged overnight. That worked for me for about 18 months, but no longer...I'm replacing my 5 year old WEGA today (NOT with a Sony).
Posted on Jul 21, 2008
Can't get it to auto tune
Hello
To set the TV to autotune do the following.
1 Press "Power Button" to turn on the TV. The Initial Setup screen appears
2 Press CH UP button on the remote control or on the TV front panel to start Auto Program, or press CH DOWN button to Exit.
When you start autoprogramme, wait until it is finished; otherwise it will skip over channels that are available. If it happens so, perform autoprogram again by turning on the power button.
The initial set up screen appears each time you turn on TV until you perform auto program.
To perform Auto Program again
1 Press "Menu" button.
2 Press"=>"to highlight Channel Menu.
3 Press "Down arrow button" to highlight Cable. Press "+" button to select.
4 Press "Up Arrow button" or 'Down arrow button"to highlight On or Off according to how you connected your TV. Press "+" to select.
5 Press "Down arrow button" to highlight Auto Program. Press [+] to search for channels
6 After Auto Program finishes press "Menu button" to exit.
To reset the TV to factory settings
1 Turn the TV on.
2 Hold down [Reset key] on the remote control.
3 Press and release the POWER button on the TV front panel. The TV will turn itself off,
then back on.
4 Release [Reset] key.
Ok.
Jan 20, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
We have not had this tv on since went over to digital freeview built in hopwever just put it on and there are no channels stored how do we get channels?
Hello
Your TV has to be initilized. It should be retuned to get the channels memorized in its memory section. Then only you can get the channels stored. Hopes that you have its remote control hanset with you. Replace two new cells in it and proceed the folloing steps. Connect ariel to its back socket before doing these.
[1] Press power button on the front panel of your tv. The initial setup screen appears.
[2] Press Ch+ on the remote control handset or on the front panel of your TV to start auto program, or Ch_ button to exit.
The initial setup screen will appear each time you switch on the tv until you perform autoprogram.
To perform autoprogram again
[1] Press Menu button.
[2] Press to highlight Channel Menu
[3] Press Pr Dn button to hilight cable. Press [+] to select.
[4] Press Prog Up or Prog Dn to hilight On or Off according to how you connected your TV. Press [+] to select.
[5] Press Prg Dn to hilight autoprogram. Press [+] to search for channels.
[6] After autoprogram finishes, press "Menu" again to exit.
TO RESET THE TV TO FACTORY SETTINGS
[1] Turn TV on.
[2] Press and keep hold the "Reset' button on the remote control hanset.
[3] Press and release the "Power button" on the TV front panel. The TV will turn itsef off.
[4] Release "Reset Button" now from your hanset.
These are the processes to be done to either autoprogram or turn it to factory settings. Ok.
Oct 20, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitiron 27 inch. It's stuck on channel 27
go to menu then channel turn off channel fix that might help ya
May 24, 2010 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Describe your Sony FD Trinitron WEGA This started
I have the exact same problem. If you get anywhere (I can't) please contact me at tbiasi@hotmail.com. If I figure it out, I'll get back to you.
Good Luck.
T
Sep 09, 2009 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Sony WEGA 42" LCD Rear Projection TV It won't change channels up or down with the remote or the buttons on the television.  It will change channels with the number pad on the remote but not the channel...
Hi, it sounds like your saying that punching in 08, 09 etc. works but channel up button won`t switch from 08 to 09 correct??? If so you need to go into your tv`s menu and "autoprogram" your channels into memory, video-tek
Jan 29, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Remote sensor
the menu button on the set has a short and needs to be replaced I'm not sure which part # it is but there is only 2 styles of these buttons used in this set the part #s are
1-762-816-11 and 1-692-431-21 I would order them both, buttons on this set short (volume, channel, ect..) it's good to keep the extra on hand.
Jan 13, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
27" Sony Trinitron Wega
Hi
Your TV's memmory IC or Main proccessor ic software get problem. You want to re-programm the ic to over come this problem.
Dec 25, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony autoprogram problem
Try hard reset = leave unplugged from AC for a long time.......T.
Please rate this solution...................
May 18, 2007 | Sony KV-27V22 TV
Sony 32" wega tube
plug out tv and start over by then the tv will reset itself.if that does not work call in a tech to solve,your problem.good luck/
Apr 01, 2007 | Sony FD Trinitron WEGA KV-20FS100 20" TV
Sony FD Trinitron WEGA KV-27FS100 27" TV Logo
109 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
