Question about ASUS TUV4X (TUV4X/533/PA/6P-UAY) Motherboard
Not sure... i plugged in all the cables and the power cables and the hard drive and the cd roms wont power up???
  • kara80537 Jul 19, 2008
    pls help...
  • 781 Answers
Your hard drive should be set to primary if cd on same ribbon cable it should be set to secondary and do you have the power lead inserted into both
if the drives are not set nothing will work as the bios does not know whats is there
if need more info let me know
Posted on Jul 20, 2008
HP proliant DL380 gen4 PXE-E61, when trying to install redhat and solaris.
First, it's not booting from a CD or Hard Disk if you've reached that error. The 'last-ditch' effort to boot is to attempt a PXE boot from the network card, but your Ethernet cable isn't plugged in. Unless you know you've setup such a PXE boot server, you'll want to check the BIOS settings to be sure the CD-ROM is set to boot first, followed by the Hard Disc. Be sure you have Disc 1 of the Linux installation set in the CD-ROM Drive and reboot. If you don't get the install screen, you may have another issue (bad CD-ROM Drive, bad cable/controller, no power to CD-ROM, etc.)
Another note on the DL380, if there is a RAID controller, you'll need to setup the RAID before installing the OS. You'll want to make sure your hard drives are properly installed and aren't failed. The RAID configuration screen will verify the RAID status once it has been initialized, which will somewhat verify the drive status.
Nov 12, 2013 | Computers & Internet
I have a inspiron 530s series hard drive and my cd-rom has no power to it
You must open the case, then check the power cable that leads to the cd-rom drive. It should be pretty easy to identify the male/female Sata power plugs. If the cable is not plugged in, plug it, then start the machine to see if the drive works. If the drive is plugged in but still has no power, you'll have to acquire a new cd-rom drive.
5_22_2014_3_29_52_pm.jpg< The power plug should look like this.
Jul 28, 2012 | Dell Inspiron 530 Desktop Computer
Should the hard drive and the cd rom use the same connection cable to a M2N68-AM PLUS motherboard?
It is recommended that you use a separate cable for hard drives, and CD-ROM drives, especially if your CD-ROM drive is a CD burner. This goes for any computer system. Placing a hard drive and CD-ROM drive on the same cable can introduce performance problems, especially when reading from a CD or writing to a CD.
Mar 17, 2011 | ASUS M2N68AM Plus Motherboard
Dell Inspiron 1501 CD-Rom wont play.I can hear it start to spin.Can play stored music.Have no CD Rom or filters showing under "Device manager".
If the CD-ROM drive is not being detected under the device manager, chances are that either the power/data cable is loose or the drive is dying. To check the cables, turn off the power, unplug the power cord, open the case and examine the two plugs behind the drive. Touch yourself to something metal first to discharge static electricity.
If it turns out the drive is dead, then luckily drives are usually very cheap to replace. Somewhere in the line of $15 usually.
Mar 07, 2011 | Dell (6T980-A01) CD-ROM Drive
Well....my computer is not showing harddisk in bios i dont know what problem can be thatswhy my computer is not running and showing in starting error of "drive 3 not found unknown pata 1 "...
hi first open the case make sure the power is not plug in. second look for the hard drive , it s right next to cd rom right corner , make sure the data cable ribbon is correctly seated next , check the power make sure its connected . now the fun part is next . here how your going to find out if you hrddrive is working remove the ribbon data cable from the cd rom also the power ,now remove the ribbon from the hard-drive next place the ribbon from the cd rom to the harddrive next make sure ever thing connected right . power the computer go to the bois and see if the hard drive is being read. if it is then ribbon bad ,ifnot your hard-drive is bad if is bad put ever thing back in place take your hard drive out and replace with same bigger gb thanks hope this helps
Oct 27, 2010 | Dell OptiPlex GX280 PC Desktop
No matter what i do cd rom not detecting
check whether the powe plug has been inserted properly and the power plug is working fine. Even though if the power plug inserted is working fine and CD ROM not detecting means CD ROM was damaged.
Sep 04, 2009 | Intel Motherboard
Hoew to install CD Drive
You want to install a CD Drive. Ok you are Following these steps....
  1. Unplug the power cable from your power supply and open your Computer case.
  2. Determine which drive bay you are going to install a CD-ROM into. You should pick on of the uppermost drive bays
  3. Before you install a CD-ROM, make sure you have the proper jumper settings. You are only installing a single CD-ROM, set the jumpers as MASTER. The jumper settings are different for each CD-ROM drive, so consult your owner's manual so you know which pins to cover up.
  4. Once you have the jumpers set, install your CD-ROM in the computer's case. How you secure the CD-ROM in one of the uppermost drive bays depends on your case. Some CD-ROM drives have to be screwed into the drive bay.
  5. Connect the power to the back of the CD-ROM drive, then connect the ribbon cable to the back of the CD-ROM drive. Your ribbon cable has three connectors, one in the middle and one on each end. The middle connector is a SLAVE connector that is used if you would install an additional CD-ROM or DVD-ROM drive.
  6. Connect one of the end connectors to the CD-ROM drive, and connect the other end connector to the appropriate spot on your motherboard. Note, hard drives and CD-ROM drives have the same style of connector on the motherboard. You want to connect your CD-ROM drive to the motherboard slot that isn't red or is the highest numbered of all the IDE slots.
  7. Power on your computer after you plug it in. Your computer should recognize the new CD-ROM. If it doesn't, go into your motherboards BIOS and search around for the IDE channels, they need to be set to automatically.
Thank U
Aug 28, 2009 | LG Computers & Internet
Dell inspiron 1150 won't turn on
Remove the battery the memory the ac adapter,the hard drive, the cd rom.Press and hold the power button down for twenty seconds.try again if no go you will have to replace the systemboard.
Good luck
Jan 13, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
My computer does not show my D:/drive, so it does not work
I would assume that your D drive is your CD Rom Drive. If you go into My Computer and the drive isn't there, Lets assume first that there is a problem with the Drive. If you have power to it and the drive does open to let you insert a disk, then our next step is to see if your data cable running to the drive is connected. Make sure that all power cables are unplugged before you open up the computer. Once opened look at the back of the CD Rom drive to check that the power plug is connected. Its the first set of 4 wires closest to you. The next cable next to that is the CD Rom Data IDE Cable. This cable must be plugged in all the way. Most of the IDE Cables will have a red stripe on one side. Make sure this red stripe is closest to the power cable for the drive. This will insure that you have this plugged in correctly. If you follow the IDE cable from the CD Rom to the mainboard (Motherboard) , you can make sure that this end is also seated firmly to the board. If all this is as it should be, go ahead and plug all your cables back in and restart your computer.
If this still doesnt solve your problem you might want to check your bios and insure that the CD Rom is recognized. It will show up in there if it sees it. If any of these solutions dont solve your problem, I would be leaning toward a bad CD Rom Drive.
Joe < Data Miner >
Nov 01, 2008 | Computers & Internet
ASUS TUV4X (TUV4X/533/PA/6P-UAY) Motherboard Logo
41 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
