Key pad A cat snapped my b key off my laptop, and I have pretty much everything put back together, i just can't snap it back on! It keeps sticking, instead of being bouncy like the rest of the keys. How can I fix this, or can i find someone who can snap it back on?
    Master:
  • 474 Answers
The plastic pieces are very fragile and may have been damaged.
If they apear fine, then you have to place them on the board first in the correct position. they usually cross each other to make a 3 demensional X and the rubber nipple in the middle on the keyboard acts as a spring effect to push the key back up once pressed. look very carefully at how the clips and things are and nakes sure it move freely. When yo first put it on the board, it will lay flat and the rubber nub will stick up in the middle, then you must slide the key on one end in order to catch the groves, then the other side or bottom clips on the actual key will snap into place when pressed down.
once in it should be fine. but if the plastic clips or anything are broken, then it wont work and you will have to order a new keyboard, get a used one off ebay or just press it with your finger without the key.
Posted on Jul 19, 2008
    Problem Solver:
  • 11 Answers
Typically, once a key is broken off, it's almost impossible to get it back on properly. However, replacing the keyboard is not terribly difficult. The procedure differs depending on the brand and model of laptop, but they're all usually fairly easy to replace and you can typically find one fairly cheap on an on line auction site (about $35 or so). If you search for the support pages of your computer, you should be able to find a step by step procedure for replacing the keyboard.
I was cleaning my laptop keyboard and accidentally popped off the 'N' key, I'm pretty sure the brackets are still intact, but I don't know how to reattach it, could you explain how please?
Hello and welcome to FixYa,
Carefully remove the cap from any other working key so the key retainer stays connected to the keyboard.
keyboard-key-repair-2.jpg Take a closer look at the key retainer, it's connected to the keyboard at four different points.keyboard-key-repair-3.jpg Assemble the disconnected retainer the same way as one on the keyboard and put it back in place.keyboard-key-repair-4.jpg Put the key cap on the retainer and snap the cap back in place.keyboard-key-repair-5.jpg
It is that simple! They should just 'snap' right back on!
Let me know how this worked out for you. If my solution helped you, please rate this solution!
It doesn't cost anything and only takes a second, but it is greatly appreciated.
KittyTech
May 29, 2011 | Computers & Internet
My key broke off in the ignition ,how do i remove the lock cylinder
Just an idea - could save a hell of a lot of time and money, but it depends how the key snapped if you can get the glue to stick...
you can put a tiny drop of crazy/super glue on the snapped part of the key, put it in the lock and make it so its perfectly touching the key, you can take the old bit of key out of the lock when it sticks and have a locksmith make you a new key from the two bits... cheaper than an ignition barrell.
use the tiniest speck of glue possible, use a hair or whisker to get a tiny drop of glue onto the key, put it in the same way round it snapped off so the two faces mate together properly - after 2 minutes pull out the key, if it is stuck give it a wiggle and still pull...
any glue that gets in the lock can be removed with nail varnish remover (acetone)
Dont know about how to remove the cylinder sorry...
Jan 25, 2010 | 1990 Jeep Cherokee Limited
My esc key popped off of my pavilion dv7. do you
you can search ebay
or
http://www.individualkeys.com/servlet/the-14355/HP-DV7-Laptop-Keys/Detail
Jan 14, 2010 | HP Pavilion Laptop dv7-1025nr
Ends of switch plate will not pop off. what am I missing? removed 5 screws underneath battery. the online repair manual 435182-001 only states 2. says to insert screwdriver in slots behind f1, f5, f11...
It would have been great if you mentioned the model.
These required the use of a T-9 Torx driver. The location of the screws are underneath the small rubber pads on the four (4) corners plus one center top. The panel and the back cover snaps together and needs to be pried apart using a thin spatula type tool to separate. It helps to have another of this tool to keep the side/areas already parted from snapping back together while working on the other side.
The hinge could either be part of the LCD bracket or attached to it. There would be no less than 3 screws holding the upper part. In some models the bottom part is slide in with two (2) screws at the rear of the laptop itself. In some instances, the rectangular panel above the keyboard has likewise to be removed. Some have screws some are just snap together.
In important note is not to bunch the screws together. Often they come in different lengths or threads.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information
Thank you for contacting Fixya.com
Nov 22, 2009 | Office Equipment & Supplies
Alarm on my car wont deactivate
Get the spare key and keep the wet key for cleaning and changing battery before reuse
Sep 02, 2009 | 2004 Kia Sedona
How to replace a key on laptop keyboard
a pair of tweezers a small flat head screw driver and persistence along with being careful and if you get irritated or annoyed stop and have a break and come back to it.
Take one of the keys off near it to see which way around the plastic parts go ( not too hard as you dont want the other plastic clips snapping or breaking off ) and see if any little bits of plastic are snapped - if they are you will need replacements so contact asus - if not and they are still in tact then put the 2 plastic hinges together the correct way around and then put them back in place ( you may have to slightly bend the metal clips on the bottom of the keyboard where the plastic bits fit ) which is where the small flat head screw driver comes in handy.
When you are putting the plastic parts together you may need the tweezers or possibly a paif of needle nose pliers ( being very careful as you dont want to snap the plastic clips / hinges )
Once you get the plastic hinges back in / on you can bend the metal parts back slowly and gently so as to hold the plastic bits and then push the key back on.
You should then be able to push the other key back on and that should be it.
If you need any replacement parts then you will have to contact asus.
Apr 10, 2009 | ASUS M51SN-B1 15.4" Core 2 Duo 1.83GHz 3GB...
Misunderstanding
Okcowboy -
While I didn't catch the whole thread, it sounds to me as though you might just be asking where to obtain an individual replacement key for your laptop's keyboard? Finding individual keys tends to be a lot harder than just replacing the whole keyboard. However, most big name computer repair businesses keep a stock of broken/old systems on hand that they can scrounge for just such parts. I'd say just call around to local stores - Best Buy/Geek Squad, Frye's, Staples, etc., and maybe even a few smaller shops, and ask them if they have on hand a key that would fit.
Replacing a key on a laptop keyboard is usually pretty easy; all you have to do is line up the key with its clips on the keyboard, and snap it in place. If you do find a replacement key, I would just buy the key, rather than have the store do the repair. Anyone can snap a key back in place, and it'll save ya forty bucks or so on labor.
Hope this helps!
-thinstatic
Jun 11, 2008 | Computers & Internet
My shaver head broke! PLEASE HELP ME!
I just fixed my husband's razor. I took everything out and washed it all. Then I took the three things that touch the skin and put them in the three holes so that they fit comfortably. Then I put the sharp parts inside those thin parts. The I took the gray thing with three holes and snapped the little brown thing to it and turned the arrows on the brown thing so it snapped it securely to the things with holes. Then I put the head onto the handle by sliding the hook into it's hole, than brought the head onto the handle and snapped it shut. It fell apart the first time I tried it but I put it all back together and after that it worked like a charm.
May 08, 2008 | Norelco 8170XLCC Electric Shaver
Putting keys back on acer 3100 laptop
yes..this is particularly a delicate operation. do you have a magnifying glass and small pliers..
Apr 03, 2008 | Acer Aspire 5100 Notebook
Computers & Internet Logo
185 people viewed this question
David Payne
David Payne
