Question about Dryers
I want a diagram of the heating element of a Nepyune dryer
    Champion:
  • 210 Answers
Whats the model #
Posted on Jul 19, 2008
Need diagram for wires that hook up to heating element on fridgeidaire model LAQE 7011KWO Dryer
Hello. There are black and yellow wires that connect to the heating element. The black comes from the inlet thermal limiter fuse, the yellow comes from the main drive motor. There is always 120 volts at the element. When the dryer is initiated, the motor, using a centrifugal switch, connects another 120v supply across the other side of the element which totals 240 volts and causes the element to heat. This is done intentionally as a safety feature--the element can't heat if the motor isn't running.
Aug 18, 2015 | Frigidaire Dryers
How do I replace the heating element in a 11063032101 dryer?
KENMORE Electric Dryer Parts Model 11063032101
Link shows the parts explosion. You can click on various diagrams and find your part.
Sep 13, 2014 | Kenmore Dryers
Change element in a samung dv665j
Usually, one takes the rear cover off revealing the element area. I doubt if the heating element is burned out. Typically the small thermostat or thermal fuse link blows before the heating element goes. You would have to see the diagram of your model online. Most sites have the exploded parts view of that section online. If you don't have a meter tester you may have to replace all 3. Some models have them all tied into 1 board. This site has video troubleshooting. http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/8-160-1067262-/Samsung-Dryer-doesn-t-heat-DV665J Samsung Dryer Doesn Heat
Sep 13, 2014 | Samsung Dryers
Does it have a heating element
Yes, as with all dryers, this unit has a heating element. This site: http://www.searspartsdirect.com/partsdirect/part-model/Fisherpaykel-Parts/Dryer-Parts/Model-DEGX196010B/3068/0151200/P0606083/00006?blt=06&prst=&shdMod= has a diagram of the dryer including the pair of heating elements. See part 3 in this Dryer Base diagram.
I hope this helps.
Aug 19, 2014 | Fisher and Paykel DEGX1 Electric Dryer
I need to change the heating element on my dryer. how do I do this?
The exact process will depend on the model of dryer. I would suggest starting by looking at the assembly diagram for the dryer. You posted the question in the Kenmore section, so assuming that it is correct, you can get these diagrams from the Sears website. You can also order a new heating element there.
Sep 16, 2010 | Kenmore Dryers
I have a Maytag Nepyune dryer model# MDG4000BWW. The drum turns, the ignitor glows but the gas does not always ignite. When the ignitor is glowing, if I wiggle the wire going into the 2 prong coil, I here...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 27, 2010 | Dryers
White knight tumble dryer CL432WV wiring diagram please
This has lots of diagrams on white knight http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
How to Replace A White Knight Tumble Dryer Heating Element Heater and Thermostat
For a full list of appliance Video Repair help see our video section
White knight tumble dryer not heating this video show you how to change and fit a new heating element and thermostats can be used on Ariston, Electrolux, Ignis, Neutral, Tricity Bendix, Whirlpool,
Here is the element in this video
For all you tumble dryer spare parts click here
The easiest way to find you part is put your model number into our search bar at http://www.apart4u.co.uk/ TEL 08455218000
Apr 19, 2010 | Dryers
My ge gew9250p dryer heating element is needing replacement what is a good part number for this
Hello there:
this should help you out ok
See Part # 14 on diagram.
or
See all parts for this section / diagram Heating Element (11" long x 5" wide) (Heater Element) This heating element fits later model Whirlpool/Kenmore brand electric clothes dryers. Each of its two terminals measures 5/16 of an inch, while the unit itself is approximately 11 inches long by 5 inches wide. This element carries 5200 watts and 240 volts. Appliance Help Part Number AH344597 Availability: In Stock Compare At: $56.32 Your Sale Price: $46.93 You Save: $9.39 SALE PRICE:$46.93 -->
Nov 22, 2009 | Whirlpool GEW9250P Electric Dryer
Dryers will not heat
IF THE DRYER COMES ON AND WILL NOT HEAT THEN THE HEAT ELEMENTS ARE OUT,,LOOK ONLINE FOR DIAGRAM AND CALL YOUR LOCAL APLIANCE PARTS STORE.THEY SELL THE ELEMENT--USUALLY THEY HAVE THE DIAGRAM IN PACKAGE---SIMPLE FIX ,,DONT PAY SERVICE TECH,,I SHOULD KNOW I AM ONE--HA HA
Sep 08, 2009 | Dryers
Dryers Logo
71 people viewed this question
Top Dryers Experts
