Trinitron kv32s20 :picture seems to move and there is no cable signal
    Problem Solver:
  • 17 Answers
Sounds like tuner problem.Tap lightly on the tuner (where you connect the antenna or cable or satellite) and if you see any change then there must be a loose connection near or iside the tuner.
Note - Tuner should be opened only by qualified tech.If you try be very carreful not to overheat the connection.Usually the poor connections are near the metal case.Good luck.
Posted on Jul 19, 2008
Is the sony trinitron 32"
U have pay cable or satalite service tv incomming broadcasting signal.Yes,than ur tv no need for a DTV converter.Those pay boxes will revert back to analog signal for ur analog tv.If u planning to get free over the air broadcasting,than u need a converter box to convert digital signal to a analog tv.
Mar 21, 2011 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony Trinitron KD-28DL10U switched off suddenly to standby mid programme and won't come back on.When trying the remote on I can hear it click on and immedietly off again.Switched off at set and socket and...
Hello
In time as the Sony Trinitron ages it begins to have power issues. While this can be true of most tube televisions it's the rate and severity at which this happens to Trinitrons that makes it particularly of note. Many Trinitron owners have complained of the Trinitron set turning itself off randomly and frequently. Some sets have failed to stay on for longer than a few minutes at a time. Eventually some sets will not turn on at all. These problems grow more severe with age.
Check the power cable running from the Sony Trinitron 32. Make sure the cable is completely inserted into the power connection on the rear of the TV as well as the local power outlet.
Disconnect the power cable from the electrical outlet, then plug it into a different connection. It is possible to electrical outlet has died, forcing you to obtain a power current from a different source.
Check the cable connection running from the cable/satellite receiver or VCR. If the TV is on but no picture is on the screen, the problem is most likely due to a connection issue.
Power off the cable/satellite receiver, then press the "Video" button on the remote control to switch the Trinitron 32 to the video input signal. Turn on the cable/satellite receiver and the programming now loads onto the television screen.
Nov 21, 2010 | Sony FD Trinitron WEGA KV-34HS510 34" TV
I accidently pushed something on the remote to my sony wega trinitron and now it says 'no signal' I don't know how to get the picture back
You probably switched the TV from analogue to digital mode or vice-versa.
There should be a small button on your remote control marked DTV or ATV. Try pressing this.
If you are using a separate cable/satellite/tuner box from a SCART cable, turn off the tv, and turn off the cable/satellite box. Then turn the TV back on, then the cable/satellite box back on. The TV should recognise there is an external input and you should be OK.
Oct 16, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Channels 2-6 picture is bad, but all others are OK
If this TV is connected to cable TV and you are using a cable box then the cable system is at fault. If you are connected to cable TV with no cable box then look at the pictures on other TV's in your home if you have another TV. If they look fine and are small enough to move around. Move the TV and connect it to the cable outlet where this TV is connected and then examine those channels again. If they are grainy then a call to the cable company is due. They can use a signal checker to see what the signal levels are at that outlet for any given channel range.
Mar 02, 2010 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony 36 inch trinitron no picture no sound
i cannot get a signal from my HD cable box to my Sony Wega KDF-E50A10 TV's thru the HDMI cable.
Jun 20, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
NO Signal KV32fv26 Sony Trinitron
I think your problem is in tuner stage.
1. Check 32V dc available on BT connection on tuner.
2.If 32V available on BT,connect dc meter and put the unit on auto search and check the BT pin on tuner.The BT voltage will decrease and increase while it tunes.
3.If nothing stored after programming replace tuner.
Good luck
Dals123
Oct 14, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV XA 21M80 Trinitron- HUMMING NOISE AND PICTURE NOT CLEAR
If your set has a humming noise when connecting the cable, call your cable company. There is a ground issue. This can also be a safety issue.
If your signal is PAL, and your TV is NTSC only, you will have to replace the TV with a PAL one in order to properly view the programs.
Jerry G.
May 15, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KV-24FS120 24" TV Color changes
Try turning down (off) the color during such an episode. If the image is tinted pink or green instead of black and white when you do this,you have either an intermittent short in your CRT (tube), which is terminal,or a gun drive problem, which may be repairable. If you're feeding it component instead of composite signal,it may just be a bad connection of the B-Y cable.
Mar 19, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Moved tv from 1 location to another
hi there, it may need some fine tune for the sony kv-27fs12 to be connected directly to cable jack wall. do some test. ty
Jan 10, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
