Kenmore washer I finally replaced the timer and now it does advance but nothing happens and now there is like a burning smell coming from the washer.Dead motor perhaps? I guess it wasnt the timer.It still wont agitate or spin or drain.Thanks again for the help.
    Novelist:
  • 172 Answers
Im sorry to here the timer replacement didnt help
T
Posted on Jul 29, 2008
Kenmore washer 110.16112503 works in wash & spin cycle but not rinse. After wash cycle finished I hear a humming sound and the machine does nothing until I manually start spin cycle. Broken timer?
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
Sep 18, 2016 | Kenmore Washing Machines
Why wont my kenmore elite sm9711034 wont cycle automatically?
This is almost always caused by a bad time. The solution is to replace the timer. What happens is the timer has a small motor on it that turns the timer, if the motor burns out or the timer gears wear the timer doesn't advance like it should.
Jul 01, 2014 | Kenmore 24032\24036 Top Load Washer
Washer seems to be stuck on spin. Has slight oil/rubber burning smell. Will only advance out of spin if you manually turn the knob to the next step.
The timer is bad and needs to be replaced. if you continue to run it this way you will need to replace the motor coupling real soon. That is where the burning rubber smell coming from.
Jan 20, 2014 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer stays in cycle and doesnt advance to additional cycle
Hi, It sounds like you timer has gone bad. Would need more of the model # ro be sure on what type timer you have.
Please let me know if I can assist you further.
Vic
Jun 05, 2009 | Kenmore 22622 Top Load Washer
Empty washer tub wobbles during spining, plus burning smell
BOTTOM OF TRIANGULAR PLATE ARE 3 SKID PADS, USUALLY WHITE OR BROKEN HALF MOON SHAPE WHEN WORN OUT RESULTS IN THIS
Nov 30, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite Front Load - smell of burning rubber while in use
I've never had a smell problem like this before, but I have had the rubber lining to the door "shred", leaving eraser shavings all over the laundry. This happened with my first HE3t and I complained at SEARS and they just sent out a brand new replacement. About a month or two later, the same thing happened. I had SEARS come out and replace that rubber seal, and haven't had a problem since.
Although I can't answer on the smell, I highly suggest you keep an eye out for shavings on your laundry. Also, with the door open, at the bottom you can pull back the rubber seal slightly and expose the drain to be sure nothing is clogged or getting caught in there.
Oct 10, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore washer will not drain
I would check the lid switch first using a pen open the lid set into spin and depress down on the lid sw if you dont hear it click then it is bad
Aug 17, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore direct drive washer - not spinning
While it could be the tranmission, that is a fairly rugged part (although not impossible). More often, you have bad contacts in your timer. These will short together and cause the machine to try and do multiple things at once, thus causing the burning smell. You didn't list a model number, but for most of the Kenmore washers, you can open the console (two phiilips screws on the front or back towards the bottom) to access the timer. Most timers are able to be opened to verify visably black or silver marks on the normally brass colored contacts.
Jun 18, 2008 | Kenmore 24032\24036 Top Load Washer
70 series Kenmore washer
POWERUP, YOUR WASHER COULD BE THE LID SWITCH OR THE COLD WATER VALVE. AT THE END OF THE WASH CYCLE, THE MOTOR WILL SPIN OUT THE WATER, BUT ONLY IF THE LID SWITCH IS ACTUATED. IF THE SWITCH IS BAD, IT WILL NOT SPIN OUT THE WATER AND THE TIMER WILL NOT ADVANCE FROM THAT POINT.
IF THE WASHER SPINS, THE NEXT STEP IS TO FILL WITH WATER FOR THE RINSE CYCLE. MOST WASHERS USE COLD WATER FOR RINSES. IF THE COLD WATER VALVE IS RESTRICTED OR FAULTY, THE WASHER WON'T FILL. IF THE WASHER WON'T FILL, THE WATER LEVEL SWITCH WON'T ACTIVATE AND THE TIMER WON'T ADVANCE TO THE NEXT STEP.
Mar 31, 2008 | Kenmore 22422 Top Load Washer
Wont power on after replacing drain pump.
could be just the fuse, but failing that check all circuit boards for signs of blowing or burns, some machines when there is a short on the pump blow the circuit on the timer which is the most expensive part to replace best of luck
Oct 05, 2007 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
63 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
