Question about Garmin zumo 550 GPS Receiver
Zumo 550 When I turn off the bike and turn off the GPS, I will come back a few minutes later to find that it has turned on by itself. This plays havoc with the battry. I don't want to remove the GPS every time I'm off the bike. In addition, I purchased XM radio service but cannot connect through my Zumo. I am registered and can listen 'on line' but the bike has me baffeled.
  • docnomo2 Jul 19, 2008
I have had the same problem with my Zumo 550.
I found that if I turn the power off on the GPS first and then turn the bike off this handles the problem.
Andy
Posted on Jul 30, 2008
    Genius:
  • 1,673 Answers
Make sure that the bike's electrical connection to the GPS unit is actualy not having power once you turn the key off in the bike. This GPS turns on with external power. It is inherent in to its design.
In the case were you cannot have the bike's power source to the GPS turn off with the key, see if you can wire a small in-line switch in series with the GPS unit so that you have an external power switch. This should be easy to do.
The models I have used from Garmin have their own power switch. You should be able to use its power switch to turn it off.
Jerry G.
Posted on Jul 19, 2008
Zumo 550 randomly shuts down, sometimes won't power up again.
Commonly happened when playing MP3's using an early version of the firmware. Install the Garmin updater and install the latest firmware and patches.
My original unit did the same thing.
Jul 13, 2009 | Garmin zumo 550 GPS Receiver
Garmin Zumo 550 Freezes
If the unit freezes with something on the screen, then the book that came with the unit tells you to push the power button and the + sign button at the same time and this should fix the problem. Good Luck.
Jun 30, 2009 | Garmin zumo 550 GPS Receiver
Zumo not accepting a 12v charge
Mike,
My friend had the same issue as you mention. Puts his Zumo 550 on his bike only to have it discharge in a few hours. He later found out the pins on his motorcycle cradle had corroded and therefore was not keeping the Zumo charged. His solution was to purchase a new motorcycle cradle at about $100.00 CDN.
Oct 20, 2008 | Garmin zumo 550 GPS Receiver
Zumo Wull not charge form bike mount
Experience the same problem with my Zumo 550. Told by service advisor @ Radio World that this is a common problem. Unit needs to be charged on the DC charger occasionally. The motorcycle mount and car mounts, I was told, does not charge the battery on these units, but maintains a charged battery.
Oct 19, 2008 | Garmin zumo 550 GPS Receiver
Looooooong time to load and start playing MP3s
Hmmm, the Zumo doesn't have a harddrive, it's flash memory. The best place to store mp3's is on a fast SD card, and don't get the biggest size and cram it full, I had like 100 mp3's on a card adding up to almost 450 mins of music, started up without a problem. Not as fast but pretty snappy!
Oct 10, 2008 | Garmin zumo 550 GPS Receiver
Garmin
i have contacted garmin and they requested i return it to them for repair.
Feb 17, 2008 | Garmin zumo 550 GPS Receiver
No power
I had exactly the same problem with a 3 month old Zumo 550. Removed battery, waited a few minutes and replaced. System now poers on OK. All data on-board was retained.
Dec 22, 2007 | Garmin zumo 550 GPS Receiver
GARMIN c550 will not turn on
There is an ISSUE with the DEAD ZUMO, however some of the are solved, and some need to be shipped back.
There are a couple of options.
1) remove the battery, keep power button pressed for a few minutes. install battery, try.
2) fully recharge the battery with the wall charger, try
3) With a fully charged battery, press and hold the + button and press the power button(hard reset).
4) hold thumb firmly on top left of touch screen and hold power button till it switches on(hard reset).
5) Try a different battery (fully charged)
6) Ship it to Garmin
Sep 08, 2007 | Garmin zumo 550 GPS Receiver
Zumo 550
My Zumo would not start after a normal shutdown. I removed the battery and left it for a few minutes, reconnected battery and it started OK. I guess it locked up for some unknown reason.
Aug 21, 2007 | Garmin zumo 550 GPS Receiver
Garmin zumo 550 GPS Receiver Logo
176 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
