Question about HP Photosmart 720 Digital Camera
How to turn on the camera
What button do i turn the camera with
The green button that sits under your left hand. If it has new batteries installed and it still won't start, it may be that the internal battery has run out. (See my other posting.)
Posted on Oct 25, 2008
Error message "turn power off and on again" I did this and it did not work.
Performing a manual power reset (If your camera does not have reset button and initialize function)
  1. Turn off the camera.
  2. Remove the battery pack.
  3. Remove the button-sized lithium battery.
  4. Allow the camera to remain without power for 30 seconds.
  5. Reinsert the button-sized lithium battery.
  6. Reinsert the battery pack.
  7. Turn on the camera.
Jan 07, 2014 | Sony Dsc-s2000 Cyber-shot Digital Camera...
How do I disable the PTP mode in my Samsung ST150F smart Came
TO CHANGE THE PTP MODE OFF IN SAMSUNG ST150
1) Turn the camera off
2) Hold the zoom out (-), flash button( PHOTO TAKING) and the Menu button.
3) While holding, turn the camera on.
4) When the camera turns on, it will show a text screen
5) You can let go of the zoom out and the Menu button
6) Press the Menu button
7) Press left. This will turn PTP Mode off
8) Turn the camera off and on, and you're good to go
Aug 21, 2013 | Samsung ST150F Smart Digital Camera Red
Camera will not turn on. it shut down when turn power on. is it iossible it's the battery
I know exactly the model, but may be a bug that needs reset, see the Internet, in a similar model is to get the Fimrware, download to the SD card and do what follows.
1. Turn on the Camera
Press and hold the Up button and the Shutter button (S2) simultaneously and then press the Power button to
turn it off.
Turn on the camera and check whether the camera is reset or not.
This is a lastset upgrade and full firmware for S860 camera.
(UP/FULL ver. 803141)
- Improvement -
1. How to UPGRADE firmware(Upgrade version)
-.Insert the SD card that has the firmware attached file.(file name : "S483.ELF")
-.Turn on the camera and press the Up button twice to select the Voice recording mode.
-.Press the 5 function button as following order. (Left button -> Right button -> Up button -> Fn button)
-.After pressing the buttons, Firmware upgrading is shown on the LCD and then the firmware will be upgraded.
-.After upgrading the firmware, the camera will be turned off automatically.
Feb 10, 2011 | Samsung Digimax S630 Digital Camera
I cannot download my pictures from my polaroid x800 digital underwater camera. One user said to turn the camera on and press the picture button. My usb cable is where the batteries are so I cannot turn...
1. Turn PC on.
2. Plug camera cable into Camera.
3. Plug camera cable USB end into computer USB port.
4. Turn on Camera... wait until camera show message 'USB, PC, Pictbridge'.
5. PC should be selected if not select by highlighting and press shutter button.
6. Press 'Shutter' button.
7. Window 'Autoplay' appears on PC. Select 'import' in Autoplay window.
8. Another window will ask you to name your picture folder. Give it a name.
9. The pictures download to the picture folder automatically.
10. Turn the camera off and disconnect cable from camera and from the PC
11. ENJOY!!
Jan 31, 2011 | Cameras
When I turn the camera on the screen shows a white light. No image
  1. Verify that the lens cap is not covering the camera lens.
  2. If operating the camera with a battery, ensure the battery is fully charged.
  3. If operating the camera with the power adapter, ensure it is plugged into a working AC outlet.
  4. Verify that the LCD screen is turned on.
  5. Adjust the LCD brightness control.
  6. Change the shutter speed or aperture settings.
  7. If the issue is not resolved, try resetting the camera.
Using an Initialize option in the menu
Since Cyber-shot cameras have different menu system layouts, refer to the instruction manual specific for your camera model.
Using a RESET button
  1. Locate the RESET button on the camera.
  2. Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds.
  3. After 2-3 seconds has elapsed, release the RESET button.
Jan 01, 2011 | Sony Cyber-Shot DSC-S40 Digital Camera
Cat knocked my digital camera off the desk now the screen is blue
Try reseting your camera
  4. if you dont have a reset button try the manul reset below
If your camera is experiencing an issue and the issue is not resolved by performing the appropriate reset procedure above, then service may be required. hope this helps
Aug 02, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Turns off right away
hi...ensure that the camera is turned on. If applicable, ensure the lens cover has been removed before taking pictures. the LCD backlight is turned on by pressing the DISPLAY button several times until the screen appears. Depending on the camera model, the DISPLAY button may be labeled as DISP or with a display icon. This button could be a standalone button or it depends upon the camera model.....
Ensure the battery is inserted properly in the camera.
Ensure no Audio/Video (A/V) cables are connected for viewing pictures on a TV; the LCD screen will not display when an A/V cable is connected.
Perform a reset procedure on the camera....
rate me!!!
May 24, 2009 | Sony Cyber-shot DSC-S730 Digital Camera
Camera turns on but screen is blank and no buttons work
h...i try to do the following steps...
Ensure the camera is not connected to an AC power adapter.
Remove the battery from the camera for 15 seconds.
Reinsert the battery.
Turn on the camera.
thank u rate me!!
Feb 10, 2009 | Fuji Finepix® F31fd Digital Camera
M527
my camera lens doesnt work every time i turn it on the screen stays on and then the lens error: M527-22 error comes up can you help me
thanks
Feb 25, 2008 | HP Photosmart M527 Digital Camera
Lens won't open and retract.
It sound like a problem with the zooming mechanism (lens would not retract or extended) Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Sep 03, 2007 | Kodak EasyShare CX7530 Digital Camera
HP Photosmart 720 Digital Camera Logo
55 people viewed this question
Top HP Cameras Experts
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
