Question about Frigidaire FRS26R4A Side by Side Refrigerator
Water in the frig and possible overheating
For the past week we notice the frig side was freezing the food. So we turned off the frig, thinking there was some ice build up somewhere. Fixed the problem but now we have water on the frig shelves. Then we noticed that if you try to get water, then water would spray out from the filter. So we stopped using that feature. Now I noticed that the 'wall' that divides the frig from the freezer is hot. What do I do now???
  • 125 Answers
Clean the coils and check to see if the condensor fan is working. Call your local dealer and ask them to order you new o-rings for the filter mount to fix the leak from the filter.
Posted on Jul 19, 2008
Freezing food in frig. , not making ice .
Freezing food in the fridge also freezes the water line for the ice maker.
You have a thermostat problem. Get a new thermostat fitted.
Mar 31, 2011 | GE Profile¿ Arctica® Energy...
We have a GE profile refrigerator side by side and the food in the refrigerator is freezing. We have turned the control down from 6 to 3 and it is still freezing. We have had the frig for 3+ years...
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Mar 13, 2011 | GE Refrigerators
Hi I have A GE 18 cube frig model GTA18QBNBWW. Initially the food on the top shelf was freezing in the frig I discouver the coils were blocked by massive clumps of cat fur. i cleaned it out. next day i...
you have done a good job so far . so next ck the dampner at the top in the fresfood side . it may be stuck open causing the freezing . but the evap coil was frozen so you may have a heater out in the freezer so ck the defrost system heaters and defrost terminator . ..mm hope this helps feed back pls
Jan 19, 2011 | Refrigerators
My Maytag side by side refrigerator [mod. #MSD2656KES, Serial #50518503JL] is freezing everything on the frig side on the two top shelves. Coils have been cleaned. Temp set:Freez=3, Frig=2. One week ago...
I have this same refrigerator, also purchased in 2006. Same exact problem. Fridge freezes, starting actually in the water line, you will notice water on door does not work, then top two shelves start to freeze. Lasts for a few days, then prob does not happen again for 6 months almost to the day. I've had this problem for almost 3 years!!! My service tech said to buy another, glitch in this system he can't figure out. Replaced damper x2, control board, and thermostat x2. Not sure what else to do. I hate the thought of more food lost to spoilage!
Aug 09, 2010 | Maytag 25.6 Cu. Ft. Side-by-Side...
I have a Jenn-Air side by side frig. The freezer side cools too cold, the frig side not enough. 2 weeks ago I took all the food out of freezer and noticed ice build up on back. I unplugged unit, let it...
If the freezer is staying cold it sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out ACMEHowTo.com for troubleshooting the defroster problem.
There is a small duct between the freezer and refrigerator side if this is blocked the frig side won't cool.
Jan 09, 2010 | Jenn-Air JCD2389G Side by Side...
Food freezing in refrigerator and water dripping
The problem with the water is that the drain tube is plugged. The easiest way to fix this and to save money is to unplugg the refrigerator and leave the doors open all day. This will thaw out the drain tube without a service technician coming out. That will fix that problem. With it freezing the food on the where its not supposed, This may be a bad cold control. But try unplugging the unit for a day with the doors open and this may fix both problems. (i know it will fix the water issue)
Nov 24, 2008 | Whirlpool Refrigerators
GE Profile Arctica - Frig Freezing Food
Replace the damper assy, in the Refrigerator section. The damper door is stuck open. Very common problem on these refrigerators.
Nov 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Amana side by side
your thermostat in the frig is bad,you need to pull it and checkit with an omhs meter,let me know what you find-mike
Oct 15, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Whirlpool gold conquest refridgerator
if u find out let me know. when we turn both frig/freez switches off the frig light comes back on flashes to number 6. it still seems cold be like this 2-3 days the food still seems cold. good luck. jax, fl
Mar 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Frigidaire FRS26R4A Side by Side Refrigerator Logo
118 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
