Question about Garmin nuvi 200W GPS
Update 2009 maps
It keep tells me that I do not have enough space......I have deleted voice, text, icons....and it only gives me 750 and total capacity is 991.9 so how is this suppose to fit and is there a way that I can only download the US and not canada.
  • 1 more comment
  • Anonymous Jul 19, 2008
    I have the same problem. It tells me that I need 37mb more space.
  • Mister Man Jul 28, 2008
    Same problem for me too. I unplugged the unit in the middle of the first update process.
  • Anonymous Aug 02, 2008
    Iam trying to update my garmin software and it says that i dont have space. I had even added a 256 kb memory card
  • 3 Answers
Connect your unit and navigate to the directory under "My Computer" where your GPS is located.  Usually called Garmin.  Open it and find the file called voices.  Delete all of them except the American one and it will give you more than enough room to load the new map.
Posted on Sep 01, 2008
No french laguage
On the Nuvi 7xx series as well as many other nuvi models, voice updates are free and downloadable from garmin.com. Garmin only charges for map upgrades. Maps do not contain voices. I have backups of french text to speech (TTS) voices. I would be happy to give you links to download them to you.
Mar 05, 2014 | Garmin nuvi 750 GPS Receiver
I tried to update my tomtom go live 750 inthe mid of installation it says no enough space then i canceled after that my device shows on screen no maps found i bought the device end of december 2009, any...
In the Memory slot at the bottom of your TomTom (Go 750) insert a 4GB MicroSD memory card and download Europe 2GB from your TomTom update. It worked for me Good luck !!
Jan 21, 2010 | Tomtom GO 750 LIVE GPS Receiver
Text to speech voice breaks up when giving directions
Download software update 4.80 released 5/11/2009, fixed this problem on my Gramin 750
Jan 26, 2009 | Garmin nuvi 750 GPS Receiver
Can't load Map update on TomTom XL 330S
You'll have to remove enough stuff to make room for the new map. I had the same problem which is how I found this site. Turns out, the new map is larger than the one that came on the unit. The 1 GB of available space is pretty much all used when you get the GPS. Just copy all the voices and POIs that you aren't planning on using to your computer in case you change your mind later (you can just download them again for free too). As for the voices, only one works for text-to-speech anyway and that would be Samantha though a male voice is available for download.
You'll need to clear just under 4 MB to make room for the new map, and that's if you haven't added anything. Having the drive/memory on this unit just larger than the map makes it very difficult to get much use out of TomTom's great add-ons.
Dec 28, 2008 | Tomtom XL 330S GPS Receiver
Lost maps off garmin nuvi 660
Please delete any MP3 files or extra vehicle icons on your Nuvi. The map file is 1 GB in size. There is a possibility that your Nuvi's directory is corrupted and/or there are hidden garbage files on the directory that are taking up your storage space. You can look for these using windows explorer but don't delete anything if you don't know what you are doing.
- Jim
SHARCNET-USA
Dec 17, 2008 | Garmin nuvi 350 GPS Receiver
Garmin C510 wont install download Europe maps to Unit
Take a look at the Garmin support page - there is a Question " Why do I get a not enough space message on my Nuvi2xx when trying to update my mapping?"
It tells you how to remove the unused voice files to free up space.
I have a Nuvi 255WT and deleting the voice files alone was not enough, so I set about removing a lot of other stuff *** NOTE THAT IF YOU FOLLOW WHAT I DID, DO IT AT YOUR OWN RISK **** it worked for me but there is always the risk of deleting a file that the device needs.
Also I was stupid and didn't try and save the files to a directory on my MAC before deleting them, from the satnav - worth a try so that if you can do that you have a chance of recovering one that you delete if you want it back.
First I also removed the un-needed text files - leaving only the 3 British-English files
Then I removed all of the POI files that were clearly examples/samples
Then I removed all of the Vehicle files except the one I was using
Then I removed all of the large ExtData files - now that was the one that caused me the most worry as I wasn't certain what they were there for!
This gave me a bit over 140Mbyte of free space which was enough to install the 2010 update for all of Europe.
Now I don't know whether the C510 has the same amount/less/more memory than the 255WT - so this may or may not work for you.
I didn't have an SD card available, which is why I went this far. I am going to get one and see if I can find out how to load the maps onto that.
cheers - Jeremy
Jul 05, 2008 | Garmin StreetPilot c510 Deluxe GPS...
Garmin Nuvi 200 2009 Map Update
Here's what worked for me. Nuvi 200 brand new w/2008 trying to upgrade to 2009.
After registering and download the map 2009, I started the install. I go to a point where I was told I needed 37MB more room. I went thru windows explorer and looked in the Nuvi. I went into the language folder and moved all of the languages I didn't need to my hard drive. I then went into the HELP folder of the Nuvi and again removed the all of the languages I did not need. I then went back to the install program and hit retry. All good from there. I hope this helps.
Jul 03, 2008 | Garmin nuvi 200W GPS Receiver
City Navigator Lower 48 States NT 2009
Hello parteeboy24,
The on board memory in your Nuvi 200 may not have enough free space to hold the map. You may be able to free up some space by deleting maps or language packs that you don't use. (Be careful to back up any files you are going to delete.) Or you can add an optional SD memory card to the unit to increase the storage capacity on the GPS.
Best Regards,
Ken
"Go Ahead. Use Us."
Jun 30, 2008 | Garmin nuvi 200W GPS Receiver
Nuvi 200w map download and sd card
Guys and or ladies... I know that you have to create a folder named "GARMIN" in the sd card so the maps can be recognize. Maybe this solves your problem. Let me know if it works.
BR from Spain,
Carla
May 11, 2008 | Garmin Nuvi 660 GPS Receiver
Map Update 2009
Very easy to fix the problem. When you plug in the Garmin Nuvi 200 to your computer, two drives will show up . Go to the Garmin drive and click on voice file, delete all the languages except for the one you want to use (i.e. American USA), this will give you all the 37 Megs you need to download 2009 maps. Takes a while to download using the web updater that you need to download into your computer from Garmin, but I had no problems.
May 10, 2008 | Garmin nuvi 200W GPS Receiver
Garmin nuvi 200W GPS Logo
139 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
