Question about RCA Televison & Video
Picure on tv is all screwed up
I am having problems getting the picture to come in clear on my rca tv. The screen just looks red, i've tryed to o in and reset the color controls and that is not helping, what do i do now.
  • 40 Answers
This is a malfunction of a video part of this tv-set(in the red section of video final or prefinal).contact the nearest repair shop
Posted on Jul 19, 2008
My rca hdtv has 3 split screens
T con board responsible for images on screen. If they are messed up, check this board out or replace it.
Aug 23, 2017 | Televison & Video
RCA Scenium 52 DLP
you should take it to a tv repair shop to look it over, they charge $50 and they will tell you want the problem is.
Dec 17, 2007 | RCA Scenium D40W20 40" Rear Projection...
I have model number 60pp9202 and the screen is mostly red and green and when words come up there is like a double image
Tv have any colors lines R,G,B mis alignments,have a colors shadows picures or a 3D pictures look alike?Yes?The tv have a problems known as a convergence pictures problems,it is dead and the problems.The tv convergence board must have to be repair like replacing like 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv pictures convergence problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 30, 2011 | Philips 55PP9502 55" Rear Projection...
The screen only shows the bottom half of the picture. I have a RCA TruFlat 27" TV and it has a horizontal line in the middle & only shows the lower half of the picture. I've smacked it a...
The problem of your tv is only a loosed solder.Remove the back cover of your tv but be sure to unplug it then try to look the solder part of your tv look for some loosed solder then try to resolder it using a soldering iron but be sure not to connect separated pin in the pcb.
Jul 05, 2011 | RCA TruFlat 27F520T 27" TV
Are ther advanced setting for my samsung pn64d8000 tv?
Unfortunately, the answer is no. Samsung pn64d8000 TV does not have any advanced settings.
I hope this is clear. Please let me know if you have any more questions about this TV.
Regards.
Apr 30, 2011 | Televison & Video
I have a 42" Vizio picture has an annoying thick red line
Ur backlight inverter video board is dying.
Need a new one.
Sep 22, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
RCA TV MODEL R52WM24
Projection sets have two very common problems outlined below.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith, RCA and others.
You can more info and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 28, 2009 | RCA R52WM24 52" HDTV Projection Television
RCA P52731WK REAR PROJECTION NO RED ON SCREEN
The RCA model is a 3 CRT projection TV. Most probably you need a new RED CRT, or there is a problem with the R(ed) channel (the picture is made up of 3 component colors: Red, Green and Blue). No way of telling without testing of the projector. Sorry!
Jul 11, 2009 | RCA P52926 52" Rear Projection Television
Picture looks like 3D without 3D glasses on???
The cost I don't know, but this can be fixed. I'd say shop around a bit. Make sure the repair person is certified for your TV's manufacturer. There are generally 3 lamps in projection T.V.'s, Red, Green, and Blue. They have to be aligned for the TV to project a clear picture. A credible TV repairman should be able to fix it. Depending on if it's new enough to be under warranty they may cover it as well. Really the only reason to get rid of it is if you want to get a new TV anyway. Depends on the cost of having the lamps aligned.
Dec 30, 2008 | RCA HD52W59 HDTV Projection Television
TV turns on and then, after a few seconds, picture changes to "double vision".
Projection sets have two very common problems.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
*Screen Looks 3-D
*Colors wont align
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 25, 2008 | RCA P46921 46" Rear Projection Television
Televison & Video Logo
55 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
