Question about GE Refrigerators
Refrigerator/FREEZER I Have a side by side Refrigerator that will not get cold .Freeze very slow little Ice on upper back wall.Ice maker Ice look clear,Have turn up but gest get cool.I was told cleaning the coll may help.It is a older GE PROFILE 1997 model.
The problem was solve but not by turning upside down.
Posted on Jul 20, 2008
Ge refrigerator is not cold enough and ice is not working
What is the model number?
The ice maker will only run if the freezer is at the correct temperature.
Do you see any ice buildup on the back wall of the freezer or behind it?
Nov 27, 2012 | Refrigerators
The freezer isn't making alot of ice. Can the hose behind the ice maker freeze?
Hi and welcome to FixYa, I am Kelly.
When a refrigerator slows down ice production it is usually the result of poor air-flow through the evaporator coils. The poor air-flow is due to ice build up on the evaporator coils. The ice build up happens because the unit is not defrosting properly or the evaporator fan is not running at full speed.
To answer your question "Can an Ice-maker tube freeze?" Yes, they can and do freeze but when they do freeze that is caused by a defective inlet water valve that is leaking water by when it is supposed to be shut off. It can freeze if some one set the temp control to MAX cold. Additionally when they do freeze and the Ice-maker cycles the plastic hose on the back of the unit pops out of the ice maker tube and each cycle starts porting ice maker fill water on the floor.
This may sound odd.. but. Perform a manual defrost by removing the freezer contents and directing a fan into the freezer compartment for just over 2 hours. (Makes a water mess so do not leave it unattended) The return the unit to normal service and after 8 hours start watching the amount of ice produced. (Should be normal for 2 days!) If after 2 days the ice production slows again you have an automatic defrosting problem that is causing the ice build up on the evaporator coils.
If you need any more assistance please include your complete model number in any future responses.
Thanks for choosing FixYa,
Kelly
Feb 15, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
The freezer is not cold enough to freeze nor is the temperature in the whole refrigerator cold.
most likely you have a bad computer board if the freezer is getting warm too.if there's no ice on the back wall of the inside freezer wall then it's the board.you can check this site out
http://fixitnow.com/wp/2009/11/30/ge-refrigerator-motherboard-recall-list/
Feb 01, 2011 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
Ice maker not making ice
There is a tub that goes through the back of the freezer wall into the ice maker. Sometimes this tube will freeze shut and needs to be thawed out.
The water fill tube will freeze shut from low water pressure. Ether from a bad water valve or low pressure to the refrigerator itself.
Pull the refrigerator out and remove the tube from the back wall to check it
Good luck.......
Jul 28, 2010 | Jenn-Air JSD2789GES Side by Side...
Freezer does not get cold enough to freeze so ice maker does not work
Check for frost on back wall of freezer if there is frost you have a defrost problem
Feb 17, 2010 | GE GSS20IEP Side by Side Refrigerator
The freezer isn't gettting cold enough to freeze solid and the ice maker isn't making ice because of that too. Repairman says we have a freon leak. Is that a valid response...
possible causes: bad door seals or condensate drain plugged causing evaporator coils (in freezer) to ice up, condenser or evaporator fans not on, condenser coils dirty, compressor not working, or a freon leak. if the back wall of your freezer is frosty or super cold, the coils are iced up. remove the back wall and defrost it with a hair dryer. if the water doesn't drain, unclog the drain tube. check the door seals for gaps. replace if necessary. check the fan in the freezer and the fan in the back. both should come on when the compressor is on. if not, check the fuses on the main board. replace if needed. if all that is fine, and there is no frost, you have a slow leak or a bad compressor. call in a pro or get a new fridge.
Nov 12, 2009 | Amana SXD524VW Side by Side Refrigerator
Freezer not freezing
if there is ice on the back pannel then your defrost element has gone bad. look at the back of the freezer and see if you see ice on back wall then that will be the problem all so check speed of evap. fan if rotating to slow this will cause a problem also in freezer....
Jul 27, 2009 | Maytag MSD2756G Side by Side Refrigerator
Ice maker was hot and could hear water dripping on
yes.you will have to replace the ice maker.if further used without replaceing the compressor will get damaged and you will completely loose cooling in your unit.
Mar 07, 2009 | Whirlpool ED0GTQXMQ Side by Side...
Here is a complete service and repair manual for your refrigerator. It has everything you will need to know about this fridge. The manual has how to run all the diagnostics to determine which parts may have failled.
Good Luck,
Thanks
Jan 03, 2009 | Samsung RS2630WW Side by Side Refrigerator
Freezer not cold enough to freeze items solid
Here are some things you can check yourself. Does it run all the time almost non-stop? if so check the vents under the front of the frig and make sure they are clean. Aslo check the condenser coil (either in back of the frig,or under the frig)Make sure that coil is clean. The condenser coil has to have contact with the outside air in order to release the heat it removed from inside the freezer.
Make sure you frig has plenty of ventilation ( wall too close on sides and back) Hope this helped. If not then you should have a pro look at it.
Jan 28, 2008 | Frigidaire GLRS264ZA Side by Side...
Refrigerators Logo
109 people viewed this question
Top Refrigerators Experts
Sal De GO PATS
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
