The main thing to remember when doing this is to make sure that each of the routers have a DIFFERENT IP ADDRESS! If they do not it will not work. You can use one as 192.168.1.1 and one as 192.168.0.1 . This will resolve a IP conflict that will happen from default settings. Once this is done it will do the rest. All you have to do is disconnect each router from each other, reset them one my one and connect to each one individually with a cable and change the IP addresses to ensure that when they are connected together their is no conflict. When you hook them to the cable modem, you will need to connect the modem up first and make sure its online, then one router and wait 30 seconds and then the 2nd one. There you go... DONE!
Feedback appreciated!
To Configure the Router with Internet Access
Connect to one of the wireless router/access point's LAN Ethernet ports, turn off its DHCP server, and give the wireless router a static IP on your LAN:
