Question about HP Photosmart M447 Digital Camera
My m447 hp photosmart...
My digital cam will not take pics or video. my batteries r good and i can view what i have on there. i need help. this cam is my "life line"
  • beat down Jul 19, 2008
    the pictures that i had on my memory card r still there, but the ones i try to take r not being taken and therefore do not go on the memory card. also ido not have an error code or anything like that showing on the screen.
  • Tim Babcock
    Tim Babcock May 11, 2010
    Are the pictures and videos being stored to a memory card?
  • HP Master
  • 2,794 Answers
Try copying your pictures to your hard drive and delelting the pictures off your camera. See if an empty memory card will change things.
Posted on Jul 19, 2008
Battery is only good for about 3-4 pics.
Try to set to no flash, then battery may last longer.
Jun 25, 2012 | Fuji Finepix Z20fd Digital Camera
Tip
How to protect ur Digi cam?????
If u have Digital Cam and you want to protect then don't touch the cam lans because if u touch it and try to clean them u scratch the cam lens cover..after do this the pic who u capture is not so good and the life of the Digital cam is too low ...so b careful about your cam lens and cover it very carefully...if u want to clean your cam lens then u use a cotton..because cotton is less harmful for cam lens as compare to another source ..Thanks..
on Jan 27, 2010 | Cameras
I CANT VIEW IN THE VIEWER WHEN IN THE CAMERA MODE. IT WORKS FINE IN THE VIDEO MODE.IT WILL TAKE PICS IN THE CAM MODE BUT NO SCREEN.
Think that you might have accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time.
Apr 23, 2010 | Canon PowerShot SD600 Digital Camera
Recently purchased the Sony DSC-W290 and I have
how long do you usually charged the batt? to make charge last slightly longer leave the batt inside the charger for an hour after the charger light goes off. if you have a fully charged batt you should be able to take approx. 300 pics or 2.5hrs approx.batt life. for viewing pics it should give you approx. 6800 pics and approx. 5.5 hrs. of course, number of still images and and batt life may vary depending on the camera settings.so if you're zooming in and out,using the flash,going from camera to play mode, turning cam on and off, using other settings and features of the camera, this will cause the batt to drain much faster.also ambient temperature also affects batt life.if it's very cold, the batt drains a bit faster.also, it's recommended that if you're not using the camera to remove the batt.retaining the camera settings, date & time will cause batt to drain even if your not using it. if did this and still you think it's odd that your batt drains quickly and looses charge even if it's fully charge, it might also indicate that what you might be a defective batt. one way to find out is to try using the same type of batt from a friend or a relative that has one to confirm and further isolate issue.anyway, supplied accessories has the same warranty that applies to your camera.so you may send it out and have it replaced if needed.hope this helps.thanks:)
Apr 08, 2010 | Sony Cyber-shot W290 Digital Camera
Can only wiew pis or take pis
take your battery out and your card and dry it out and let it sit for 30 mins then put it back in thats exactly what i had to do mine when i dropped mine in the ocean.. let me know if this helps!
Jun 11, 2009 | Canon PowerShot A450 Digital Camera
Pics have lines through them changing pic dark
This is not a solution, but how did you get your pictures onto Windows Vista because I've been trying to look for a solution and since you said you had some success, I could really use your help.
Mar 09, 2009 | Kodak EasyShare M883 Digital Camera
UNABLE TO VIEW PICTURES
no disc for these cams...should be able to view pics straight from SD card thru a card reader to pc...(may have to go thru START..MY COMPUTER...LOCATE DRIVE CARD READER IS DESIGNATED AS....
also should be able to view pics on tv thru video cable attached to cam.
Jan 24, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Why hasn't my Nikon Coolpix L15 ever really worked?
try rechargeble batteries. i switch to rechargeble batteries and they last much longer than regular batteries.
Dec 20, 2008 | Nikon Coolpix L15 Digital Camera
Vivitar
i have done exactly the same as you mate, 2gb SD maxell card, dosent function, however when we where at a family get togther i swaped cards with a mate, so i gave him my 2gb card to put into his camera which wan not a vivitar and gave me his 64mb sd card (cant remeber the make of his) and my vivitar 3720 worked fine, with his card... and my card worked fiine in his camera...
so i think its just that the vivitar cant take upto 2gb... try buying or even swaping your card for a lower memory..
i will be doing this, just havent got round to it.
Hope this helps.
take care.
carwyn
Dec 27, 2007 | Vivitar ViviCam 3720 Digital Camera
Polaroid i733 that eats batteries
Sounds like you need to change the camera settings and cut down on turning the camera on and off between shots. Viewing pics on the LCD screen eats up the battery life the most... just an FYI.
Aug 07, 2007 | Polaroid i733LP Digital Camera
HP Photosmart M447 Digital Camera Logo
95 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
