If you have this type of system your thermostat will not work;
Multi-Stage Heat Pumps
3 Wire Hydronic Systems
Line Voltage Systems (120/240 VAC)
This thermostat is only for this type of HVAC systems;
Most 24V Heating and A/C Systems
1 Stage Heat/1 Stage Cool: Gas, Oil, Electric, or Single Stage Heat Pump Systems
2 Wire Heat Only Hydronic Systems (Hot Water Baseboard & Radiator)
Millivolt Systems (Wall Heaters / Furnaces & Gas Fireplaces)
- Never connect a low voltage thermostat to line voltage.
Two wires control a heat only system.
- Connect one wire to W and the other to RH.
Two wires control a cool only system.
- Connect one wire to RC and the other to Y.
Three wires for forced air heat only system, where the previous thermostat
did not have a clock or timer.
- The previous RH or RC wire is the 24-volt transformer wire. Connect it to RH. Leave jumper connecting RH to RC. Connect the forced air heat system to W, and the fan wire to G.
Three wires for a heat only, forced
water system that did NOT have a
clock or timer.
- This system employ 3 wire zone valves. Currently no Lux controls are compatible with this system.
Three wires control a heat only, forced water system that DID have a clock or timer.
- Tape off and do NOT install any clock or timer wire. Often they are labeled C or TC. Install the remaining two wires, one to RH and the other to W.
Four wires control a heat only system,
and two of the wires operate clock or timer. The other two wires operate the heater.
- Tape off and do NOT install any clock or timer wire. Often they are labeled C or TC. Install the remaining two wires, one to RH and the other to W. The jumper connecting RH to RC may remain or be removed.
Two wires control heating AND cooling.
- Currently no Lux controls are compatible with this system.
Three wires control heating and cooling. One wire operates heat, one operates cooling and the third provides 24 VAC.
- Connect the 24-volt power wire to RH. Install a jumper connecting RH to RC. This jumper is usually pre-wired. connect the heat wire to W, and the cooling wire to Y.
Three wires control a cooling only system. One wire operates the compressor, one operates the fan and the third provides
24 VAC.
- Connect the 24-volt power wire to RC. Connect the cooling wire to Y and the fan wire to G.
Four wires control a heating and cooling, electric, gas or oil, forced air system that
is NOT a heat pump.
- Connect the 24 VAC transformer wire to RH or RC. Install a jumper connecting RH to RC This jumper is often prewired. Connect the heat wire to W, the cooling wire to Y. and the fan wire to G.
Four wires control a Single Stage Heat Pump. They were labeled: G, Y, R or
RH or RC, With either B or was used.
- Do not connect wires to both B and O. Connect the reversing valve wire to B or O, just as the previous thermostat. Install a jumper wire from RH to RC. Connect 24 VAC wire to RH too. Install a second jumper wire from W to Y. Connect compressor wire to Y and the fan wire to G.
More than 4 wires are connected to the
old thermostat
