ASUS P4SGX-MX Motherboard
Problem for ASUS P4SGX-MX Motherboard
Asus P4sgx-mx
By nagard on Jul 19, 2008
Hey i got a computer but it wont turn on, there is a green light on the motherboard but it just wont turn on?...what can be the problem?thnx.
Comments:
Jul 19, 2008
- I tryed different power supplies but nothing? Cant afford to go to a computer shop :(
Jul 19, 2008
- Tryed different power supply but no go?...it had a 200watt now im using 350, it was in a mini atx case now its in a standard one. i dont have money to go to a pc shop :(...what else could i be looking at?
Jul 19, 2008
- tryed that, ive dcc all the cables and all to see if it would turn on at least but no go? i swapped about 10 rams but no go...its not giving out that the mobo is screwed as the lioght is green...could it be the pins where the atx power(power sw) go? is there any other way to turn on a pc without them there?...thnx.
Jul 19, 2008
- ah okay that sux bad :( well thank you ill keep on trying to wrok out the problem.
Same Problem
Mar 19, 2009
-   MY P4SGX-MX FANS TURN RED LIGHT ON NO LEYBOARD CAPABILITYS AND DARK SCREEN i FOUND THE ATX12V1 NO CONNECTED ON MOTHERBOARD-   Guest
Nov 01, 2008
-   exactly the same problem man. Power up the mobo but it doesn't turn on. -   Guest
Sep 23, 2008
-   I have an emachinesT2742 that keeps turning on and off every 1 or 2 seconds. Do I need a power supply or is the motherboard gone?? Thanx-   Guest
Best Solution
posted on Jul 19, 2008
Helpful)
country42740
Rank: Wiz
Rating: 80%, 454 votes
Issue: No power or computer does not turn on.
Cause: No power from the computer can be caused by any of the below possibilities.
  1. Connections not connected properly.
  2. Third-party hardware.
  3. Bad power cable.
  4. Incorrect power supply.
  5. Bad battery.
  6. Bad power supply, power button, and/or power board or inverter.
Solution: Note: If the computer is turning on but is not (beeping) or giving any type of picture on the display. If you are uncertain if the computer is turning on or not, this can be easily checked by locating any fans in the computer or visible from the outside of the computer. If these fans are spinning, the computer is receiving power and this document may not apply to your issue. Connections not connected properly Verify that the power connection is connected properly to the wall and the back of the computer. If the connections appear to be connected properly, attempt to disconnect and reconnection both ends of the cable. If you have a power strip (surge protector) or switch used to turn everything on at once, temporarily disconnect the computer from that switch and connect that cable directly to the wall. This will help verify that the strip or switch is not bad. Verify that the outlet works by connecting a different component to that switch. Third-party hardware : (If )additional hardware has been recently added to the computer it is recommend that you temporarily disconnect that device or devices from the computer to verify they are not preventing your computer from turning on. Bad Power cable : Verify that the cable supplying your computer is not bad or damaged by using another power cable. If you have a standard crt modem this cable can be used in place of the computer power cable. If you have a portable computer or laptop, when the cables are plugged into the laptop you should see a power light or battery charge light. If this light is seen, this is a good indication that the power cable is good. Incorrect power supply If you are building your own computer or if the computer has never turned on since you purchased it, it is possible you are using a power supply that does not supply enough power and/or the incorrect type of power supply. Verify your power supply meets the requirements of your motherboard and processor. Bad battery If your computer is a laptop or portable computer that utilizes a battery for mobility it is possible that the battery may be causing your issue.
  • If your computer powers on when the cable is connected to the portable computer but not when it is disconnected, we recommend you purchase a new battery.
  • If your computer does not power on when the battery is connected and when the power cable / charger cable is connected, try removing the battery and seeing if the computer can power on with only the power cable connected. If no power is still received, skip to the final section.
Bad Power Supply, power button, and/or power board or inverter If, after following the above sections, your computer still receives no power, it is likely that a hardware component in the computer has failed. It is most likely that the power supply has failed. If you do not plan on replacing the power supply yourself or if you have a portable computer, we recommend having the computer serviced by your computer manufacturer or a local computer repair shop. If you have a desktop computer and plan on trying to repair the computer yourself, we recommend you replace the components in your computer in the below order.
  1. First open the computer and verify the power connections. You may also wish to consider disconnecting the main power cable and reconnecting the power cable to make sure it has not become loose. Also verify the power button cable is correctly connected to the Motherboard.
  2. Replace the power supply with a new power supply.
  3. Replace the motherboard.
Hope this helps ya/Please dont for get to Vote.Thank You
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Somewhat Helpful)
Bubbabear64
Rank: Wiz
Rating: 85%, 2135 votes
Could be the power supply. Do you have a way of testing it?
If not some computer shops can do it for you.
Comments:
Jul 19, 2008
- Check you components to see if there is anything loose or not seated in properly such as hard drive cables, memory cards, and PCI cards. You could swap out memory cards to see if that the conflict.
Jul 19, 2008
- Its tought to turn the thing on without the pins. It sounds like somethings going on with the motherboard and it probably needs to be replaced if you have gone through all those steps.
Sometimes the light can be green indicated it sees the power from the out but thats as far as it gets.
Was this helpful?
Yes
No
Solution #3
posted on Jan 14, 2009
Not Rated)
bryanjatko
Rank: Master
Rating: 80%, 12 votes
The easyest way that I have found to check the power switch is to trace it to the motherboard and disconnect it. Then with a small flathead screw driver you can make the connection between the two pins that the power switch was connected to. If the computer comes on then you know the problem is the power switch. If the computer dose not come on then you can forget about the power switch being the problem.
Was this helpful?
Yes
No
Solution #4
posted on Jan 02, 2009
Not Rated)
pantha010203
Rank: Apprentice
Rating: 0%, 0 votes
were does the power switch lead go on the mother board on a rev1.1
Was this helpful?
Yes
No
Solution #5
posted on Dec 21, 2008
Not Rated)
Loteck
Rank: Wiz
Rating: 82%, 82 votes
If I am not mistaken, the green light stays on as long as the computer is plugged into 110v power source so that means very little. I would first check power button and wires from power button to mother board. But as with all computer problems it could be a lot of other things. Process of elimination.
Was this helpful?
Yes
No
Solution #6
posted on Jul 25, 2008
Not Rated)
comptronbah
Rank: Apprentice
Rating: 70%, 1 votes
check to see if the power supply fan comes on when the power button is press if not you will have to open the pc and test the power connectors with a digital volt meter to see if you get the right voltage 5V (make sure to place your meter on direct current) or you can get a known good power supply and do a test. If you get the same problem the issue isn't the power supply. It can be an onboard device the next step is to remove all onboard device (memory,pci card, disconnect all drives etc)one by one as you move each device turn on the system. One off the device could be holding the system from starting. If you move all devices from the system while trying to turn on the system after each device is move and the problem still exsist you have a bad mother board and it needs to be replace
Comments:
Jul 25, 2008
- Hey just a reminder check the power button sometimes they do go bad. also check to see if the cable that connects the power button to the board isn't loose
Was this helpful?
Yes
No
Popular Solutions for ASUS P4SGX-MX Motherboard
Questions and Unsolved Problems for ASUS P4SGX-MX Motherboard
Do you recommend ASUS P4SGX-MX Motherboard?
Answer
Answer
locate and inistall audio driver for MV42V1.3
Answer
Will not Boot Dell XPS600 Pentium D Processer 830 with Dual Core @ 3.0GGHz, 800FSB Vista Ultimate... (More)
Answer
the power cable from the front panel to the pins on the mother board is off
Answer
my computer is a dell inspiron 531. 2 1/2 years old. it developed shut down problems 2 months ago.... (More)
Answer
I have PC whit P4SGX-MX motherboard the PC dont start i dont her klick like my 2 PC please help... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Motherboard Experts
Top Computer & Laptop Repairmen
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
