Question about Ovens
Kenmore Ultra Bake GAs oven
We had some power outages a couple of months ago and after the power cam back on the display says Loc- and the oven won't work.
    Scholar:
  • 170 Answers
Here's a link: http://www3.sears.com/ put in your make and model and you can order a manual. Good luck!
Posted on Jul 21, 2008
MY OVEN WON'T HEAT
Hello - Does any part of the range work? I would recommend verifying that a fuse is not blown or a circuit breaker tripped. Test the power outlet with a lamp, hair dryer, etc. Another questions, does "Loc" appear in the display if any button is pushed? The Oven Lockout feature automatically locks the oven door, prevents the warmer drawer and most oven controls from being turned ON. If so, press and hold CLEAR/OFF for 3 seconds. A beep will sound. LOC will clear. The "DOOR LOCKED" will continue to flash until the oven door has completely unlocked. Does the clock display "Sd" or "dddd"? If so, the clock is in sales demo mode. Press and hold the "BAKE TIME" button for 6 seconds to exit sales demo mode. If this does not prove to be successful, contact a professional to have EOC diagnosed and/or to confirm that there isn't a wiring failur
Oct 26, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
I have a Kenmore Ultra Bake Stove, we had a power outage and neither the oven nor burners works. The code on top reads PF 5Ab. What can i do to reset the stove?
PF is usually power failure.
If "PF" appears at any other time, a power failure occurred. To remove "PF"and to reset the clock, press STOP/CLEAR.
Unplug the unit for half an hour or so to see if it will reset.
If not try to get into the diagnostics so you can see if there is a stored
error code
Feb 15, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Upon recovery from a power outage, the oven door on a Kenmore model #911455881C engaged the automatic door lock, and it will not release. I have cycled the power off and back on; have tried starting the...
I traced the problem to a faulty motor in the automatic door latch. In an effort to get the range operable again quickly, I removed the latch and got the door open. However since I just removed the latch and did not rotate the cam on the motor, the electronics did not "know" that the door latch was open, and therefore it still would not allow the oven to bake or broil. To remedy this I had to completely disassemble the motor and rotate the cam 180 degrees so the the sensors would recognize an open latch.
Dec 23, 2009 | Ovens
Touch pad does not work and flashed FO
FO- the touch pad is faulty. replace the eoc(electronic oven control)
May 17, 2009 | Kenmore Ovens
Cannot get display clear on kenmore oven
Unplug the cord behind the oven. You'll need to pull out the oven a bit. Not too far as the flexable gas line is there also. Wait 10 min and replug the oven. This will reset the curcuit board after the power surge.
Apr 29, 2009 | Ovens
Display is in LOC but door is not locked. Can't set temp. to bake
check if u can find any reset procedure.
alsio u can let it with no power for 30mi that will reset it Int.Memory.
Feb 16, 2009 | Whirlpool RBS275PD Electric Single Oven
Kenmore ultra bake oven is locked
The manual is located at the back of your oven. If your oven is against a wall, pull it back, not too far, and you will see a manual taped to the back of it. From there, it will provide you with answers some employers won't know. If it's not there, sorry, you're outta luck!
Oct 27, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Electric Kenmore Ultra Bake Oven
I finally found my manual to the range, and to change from celsius to fahrenheit press the BROIL button for 5 seconds. A tone will sound, and the temperature should switch to Fahrenheit.
As far as the code PF 5ab--it could be PF Sab which means the power went out during Sabbath mode. Try pressing and holding TIMER OFF for 5 seconds. If that doesn't work, then open the oven door, press STOP/CLEAR, press both the HOUR "up" and "down" arrow pad at the same time and hold for 5 seconds, "Sab OFF" should appear. Press START to accept the change, then close the oven door.
Dec 13, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
292 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
