Trying to install more memory and it won`t detect it
  • 47 Answers
What kind of ram are you trying to install and are you sure it's compatible with your pc. If not, you can run into problems with the wrong ram.
http://www.crucial.com/index.aspx?gclid=cipjt-xkypqcfqrksgod02kkla&ef_id=1705:3:s_72111363d43fe66f7bba91a76ae1a8e2_580972463:tk@jp9bkfbwaafl7ocqaaaae:20080719012154
Run a scan from here to see if your installing the right ram, and find out what you need.
Posted on Jul 19, 2008
ASUS Motherboard M4A88T-V EVO/USB3 won't post
Specs say it is a dual channel platform for the memory slots. It requires two DIMMs to take advantage of this, but you would have double check the manual if it will run with a single DIMM.
Feb 04, 2013 | ASUS Computers & Internet
Won't post
AWARD POST Code Definitions
C1
Detect memory
-Auto-detection of DRAM size, type and ECC
Try to clean the mainboard for dust with compressed air and reseating your memory modules or try rebooting with one memory module at at time. Try also to clean the ram modules contact point with a pencil eraser
DO NOT touch the contact points with your fingers and beware of static electricity.
Good luck
Oct 27, 2012 | Computers & Internet
Non-stop beep sound and won't display
A constant beep, usually indicates the post is detecting no memory installed. This is usually caused by the memory not being installed correctly or incompatible memory. double check you have the correct memory for this mother board. If you have 2 chips, install one and test. If this does not work swap the memory and try again. If both chips fail, you might try a different brand of memory.
Jan 27, 2012 | ASUS A8N-SLI Premium Socket 939 NVIDIA...
How can i able to use my usb flash drive, it won't open due to i haven't remove it while my computer is formatting.
Hi arjeevergel ,
The USB drive should work fine even if you have removed it while formatting your hard disk (if this is what you mean when you say formatting computer).
Try connecting the drive to some other slot after you install the operating system and check it it works.
If it does not work , then you can probably check it in your neighbor's PC whether it's been detected or not , if it's being detected then the problem could be that your USB ports have been disabled which you need to enable via BIOS or the hardware manager.
Hope this helps ...:)
May 10, 2011 | Electronics - Others
I hav a sandisk sansa 2gb mp3 player version BE0704UHB.it has a microsd memory card slot,but when i try to keep it,my player won't detect it,nor even my computer.how should i fix it?also i dont see any...
First off, have you installed the drivers for the MP3 player? That is important because without the drivers the computer will not communicate with the new devices.
You also have Windows drivers that detect Micro Cards.
Without these drivers installed there is no connection whatsoever. Go to your DEVICES and see if they are located in the inventory of hardware attached to the computer. Micro cards need to be formatted, just like a new hard drive etc. in order to communicate.
Jan 12, 2018 | Cameras
An unsupported memory module was detected a
Sounds like the Memory Ram that you tried to install went haywire. Take it out and make sure this ram is compatible.
Apr 10, 2010 | Dell Latitude C810 Notebook
2 RAMs are not getting detected together -- Intel D101GGC
hi im josh in cebu phils. friend no setting to be modified the problem is in *********** board.it can not detect two memory at a time especially having different value. coz when the memory works it will swap since one of the memory is hgher it will create complications.so to avoid such problem you choose to use the same value of memory in both memory banks. like if youre using 256 of the 1st memory bank use alson 256 for 2nd memory bank. then try to use the same brand for better. good luck!
Feb 19, 2009 | Intel D101GGCL Motherboard
Dell PE 1600SC invalid memory configuration detected
You may need to install memory in matching pairs. If the new memory is a single 1Gb module and you didn't already have a similar one they may not work together. Try removing the original module(s) and see if it makes a difference.
Oct 28, 2008 | Dell OptiPlex GX280 PC Desktop
Both ram not detect
More than likely the 2nd slot your trying to use is bad, however before you make that assumption try inserting a stick in the possible bad slot by itself and see if it will post. Let us know :-)
Sep 17, 2007 | HP (D7580-60003) Motherboard
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
