Question about GE Microwave Ovens
Will not cook it is only four days old - GE Microwave Ovens
  • GE Master
  • 9,098 Answers
If consulting your manual is no help, I would suggest taking it back.
Most dealers give you 30 days to return or exchange units.
Otherwise, you may get stuck with a problem unit.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 19, 2008
Magic chef microwave just stopped heating, can you tell where the fuse is so i can check it, and i am open for any suggestions. model # hdm111ow
Sounds like the magnetron has failed, if it were the power supply or capacitor or fuse, it would have failed to heat straight away, not faded out. Probably more economic to replace the machine.
Feb 22, 2017 | Magic Chef Microwave Ovens
The fan on the one day old Oster Microwave runs after finished cooking. All cardboard has been removed.
It is supposed to run on and will stop on its own as long as the door is closed. The purpose is to remove steam and condensation, plus smells from the cooking cavity and cool down the magnetron (the part that emits the microwaves).
Nov 23, 2016 | Oster Microwave Ovens
Exterior of oven , top and both sides gets very hot to touch, when cooking +- 10 minutes or more the last couple of days; no Error ( E41/42/45 or 47 are being displayed. Fan is normal, functions: OK
There could be food or oil buildup around the door frame which will absorb some of the radiant and microwave energy whilst cooking. Give it all a good clean and see if that helps. If everything else is working properly, it may be a problem with the cooling fan. Microwave ovens have a "stirrer fan" inside the roof or rear of the cooking area to disperse the microwaves and some convection / microwave ovens also have a cooling fan which assists in dissipating heat within the cabinet.
Jan 04, 2016 | Microwave Ovens
Microwave comes on but no cook
This could be one of four items causing the problem:
1, High voltage Diode
2.Magnetron
3. High voltage capacitor
4. High voltage transformer
Aug 29, 2014 | LG LRM1260SW Microwave Oven
I HAVE A GE MICROWAVE/BROWNER NODEL WES1384SM2SS. IT HAS STOPPED RUNNING. I CAN SET IT UP TO COOK BUT WHEN I HIT THE START BUTTON NOTHING HAPPENS.
Re: GE JES1384SF Mine quit working so I unplugged it and put a pot of boiling water in it and let the steam dissolve whatever was gumming things up. I used an electric hot plate to keep the water boiling. I let it boil for a couple of hours. I left the door 2/3 open. The microwave is working again. It is four years old and has been used every day, many times a day before it stopped working.
Jan 08, 2011 | GE JES1384SF Microwave Oven
Oven will not cook. turntable and fan will not operate, but light, timers controls all appear to operate. checked door seal and allignment and appear to be ok. oven is 4 days old. it stopped operating...
its a defective lower door interlock switch or a faulty relay or triac. First try again a pick up a little or push down a little on the door and see if it will work
Sep 12, 2009 | Haier MWM10100SS Microwave Oven
GE Microwave won't heat or cook - one year old
More than likely the magnetron has failed. This could be for a number of reason. Do you use your microwave to heat wheat packs or warm plates? If so, you may have dried the magnetron out (they use the moisture in whatever you're cooking to heat it, and plates/wheat bags have no moisture).
I'd say a trip to your local Microwave repairer could be in order. It could also be the High Voltage Fuse which has failed. Either way a repairer will be able to tell you!
Mar 25, 2009 | GE Profile Spacemaker Over-the-Range...
Microwave shuts down after cooking three or four minutes
Your magnetron is overheating and tripping the thermostat, which interrupts power until it cools.
Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
You can find your nearest Maytag-authorized servicer here.
Nov 20, 2008 | Maytag MMV1153A Microwave Oven
GOLDSTAR MV150W
HAS NO POWER AT ALL. WHAT COULD BE PROBLEM
Sep 22, 2008 | Microwave Ovens
Microwave Turns on automatically
I would remove the plug from the mains for at least one hour. This should remove any memory
Jul 04, 2007 | GE JVM1440 Microwave Oven
Microwave Ovens Logo
20 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
