Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
Lawn hog nut won't tighten
Hammer,
You left someone an answer about tightening the nut on a B&D lawn hog. I checked the site you linked to, and it doesn't have lawn mowers. Can you give me some more info? It looks like a square plastic washer broke or something. I can't find any schematics or parts or anything.
  • kswans1 Jul 19, 2008
    Yes. No lawn mowers. At least not that I could find.
    I found it! It's right there on Dewalt's site, which BlackAndDecker.Com links to. Took a long time to find because it's not listed under Lawn Hog. In case someone else needs it, here's the link:
    http://www.dewaltservicenet.com/Products...
    There's an owners manual. It says to use a 2 foot 2x4 to hold the blade in place. I think the deal is that the plastic spacer is damaged. I'm not yet sure how holding the blade in place is going to help...
    Champion:
  • 313 Answers
Did u try to check www.toolpartsdirect.com for parts & diagram.
Posted on Jul 19, 2008
  • mr aicnelav Jul 19, 2008
    if your looking for the plastic square washer part # 241381-01.
    how to install. after the fan next is the blade/there is mark on the blade which should be facing to the grass,then the plastic washer either orange or black plastic washer,next is the metal square washer the lastly the nut. i perfer to go at www.tool partsdirect.com which you can inlarge the picture.
Blade insulator fails immediately
if the blade isolator is slipping and breaking off then the shaft isn't being locked properly to blade , there can be a few reasons 4 this too happen ,(1) teeth on bottom of lock nut worn off (2) shaft is rounded off in one spot ( lock nut not properly tightened)
Apr 23, 2016 | Garden
Harley steering head bearing
1. Grease the fitting on the side of the neck
2. Use chisel and hammer to bend back the lock tabs on steering stem nut, then remove the nut and plate, if any. The spanner nut for the adjustment is visible at full lock right and left positions. The spanner nut should be adjusted so the forks return to the center position, when released from full lock position. The Stem nut should be tightened to between 60-80 ft. lb.s .
3. When doing the adjustment, it is necessary to have any windshield, fairing or accessories mounted in order for the adjustment to be correct.
4. If any problems with wobble, vibrations, etc. check that the tire tread hasn't worn unevenly, i.e., no cupping or high spots.
Dec 13, 2014 | Harley Davidson FXST Softail Standard...
How do i tighten the blade on a black and decker MM575-18
Hi Kevin,
User a pair of channel-locks to grab the square spacer below the nut. Then tighten down the nut using wrench.
May 07, 2012 | Black & Decker Lawn Hog 18-Inch 12 Amp...
What is the torque setting for 1999 ford 182 exaust manifold
Check this for 1996-1999 FORD 3.0L (182) V6 DOHC...
- Install the exhaust manifold with a new exhaust manifold gasket.
- Install the exhaust manifold retaining studs and tighten to 13-16 ft. lbs. (18-22 Nm) in the sequence illustrated.
Raise and safely support the vehicle.
Position the Y-pipe assembly using a new flange gasket and install all the retaining nuts and bolts loosely.
Starting at the front of the system tighten the Y-pipe to exhaust manifold nuts to 26-34 ft. lbs. (34-46 Nm).
- Tighten the converter to transaxle nut and bolt to 30 ft. lbs. (40.3 Nm). Tighten the converter outlet bolts to 26-34 ft. lbs. (34-46 Nm).
Fig. Right side exhaust manifold mounting bolt tightening sequence-3.0L DOHC engine (click image for zoom)
Fig. Left side exhaust manifold mounting bolt tightening sequence-3.0L DOHC engine (click over image for zoom)
Hope this helps (remember to rating this answer).
Oct 06, 2011 | 1999 Ford Taurus
Cannot tighten blad for 18" Electric B&D Mulching Mower
You may be missing a couple of washers, 2 flat and one lock waasherAre all the pieces there. Sometimes it calls for a spCER
May 26, 2010 | Black & Decker Black and Decker Mm575 18"...
What direction do you turn the nut to take blade off Black and decker edge hog edger?
Turn in the same direction that the blade turns. It is self tightening (so it will not spin itself off.
Apr 10, 2010 | Black & Decker Garden
2 broken wheel studs need to remove wheel and replace studs think someone was trying to steal the tire and loosen all the nuts
steal or wheel wasnt tightened correctly check other studs for damage any damaged replace them also use drift pin and hammer or press unit to press out broken one push new one in and use a stack of washers and lug nut tighten nut until stud in place
Oct 19, 2009 | 1992 Lexus Ls 400
Broken stud on left front wheel
Remove: wheel, brake caliper & rotor. Drive out the remaining stub with a hammer and punch. Insert a new stud and pull it into place by tightening the lug nut. Before running out of threads, remove the nut, insert a stack of washers or a large nut which slips over the threads without contacting them, tighten the lug nut to seat the stud.
Jul 12, 2009 | 2001 Pontiac Sunfire
How do i remove the magneto flywheel from a yamaha dt 175 1991 model? tapered or threaded shaft?
You will need a flywheel puller, ( dealer can sell you one > low cost ), and a hammer.
Remove the nut and washer holding the flywheel. Now screw the puller into the flywheel as far as it will easily go. Be sure to back off the pullers' center screw when mounting puller. Tighten the center screw REALLY tight then firmly strike the center of the puller screw with a medium size hammer. Alternate tightening the center screw and striking with the hammer. To tighten the center screw you will want to strike the screw handel with medium hammer force. A few blows with the hammer should pop the flywheel.
Please rate this answer after all is done. Thanks.
Mar 17, 2009 | 2006 Yamaha DT 125 X
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
170 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
