Question about Intel Motherboard
Display chip in mother board is not functioning
Display chip in the mother board p2 slot processor system mother board the display chip is getting severe heat nothing is displaying on the monitor so please let me know what to do
  • Tim Babcock
    Tim Babcock May 11, 2010
    Do you have a place to put another fan in your computer cabinet?
Sorry but i dont know where are we going to put another fan in your cabinet......
Posted on Jul 19, 2008
Every thing is working fine but no display as i changed the display & also checked the same display on another set it is working ok changed display ic but still same problem
Power off your computer and remove the smps 24 pin connector to the motherboard and short the green and black pin and see if the SMPS is working if not replace the smps.
Remove memory from the memory slot and switch on the computer if you hear beeps clean the memory or change it with new one that fixes the memory slot
If no beeps by removing the memory then remove the processor fan and clean it with soft cloth and apply thin layer of heat sink compound and switch on the computer
If you still not hear the beeps then change the processor
If still no beeps take the motherboard to a chip level Technion the secondary power supply or the clock,reset etc in the mother board has gone wrong or not producing them
Apr 01, 2011 | Computers & Internet
In my display showing no signal but the motherboard light and the fan are woking properly where would be exactly the problem and how to solve problem tell me.
remove memory from the memory slot and switch on the computer if you hear beeps clean the memory or change it with new one that fixes the memory slot if no beeps by removing the memory then remove the processor fan and clean it with soft clot and apply thin layer of heat sink compound and switch on the computer if you still not hear the beeps then change the processor if still no beeps take the motherboard to a chip level Technion the secondary power supply or the clock reset etc in the mother board has gone wrong or not producing them
Display problem
remove your processor and the processor fan clean the processor surface with a clean cloth and fix it to the socket apply a thin layer of heat sink compound and fix the heat sink firmly to the processor remove your memory card and clean it with a neat cloth and insert it in the slot and restart the computer still not working remove the memory module and restart your computer you will hear long beeps now insert the memory and restart your computer if you hear only one short beet and display not coming add an pci or agp graphics card if it work the problem is with your graphics section in the motherboard
Nov 15, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
No Display
could be mother board or hard drive
Aug 11, 2009 | Intel D945GCL Motherboard
Motherboards is running but no display..
mother board have a problem,if warranty is still now u sent mother board service center,my friend is same problem,he send mother board and now it is ok.
Mar 31, 2009 | EliteGroup ECS P4VMM2 Supports Intel...
No display
No, it is a motherboard processor socket problem, repairable only with a new motherboard. Can you give me motherboard details to compdoctor2005@btinternet.com
Dec 13, 2008 | PC Chips MB PCCHIPS P25G V3.0 P4M800CE 478...
How to solve the asus K8V-Mx mother board
SANDEEPDATAS
try resetting bios first if that doesnt work check for dust around the first ram chip and slot
remove the dust and retry if that doesnt work try another psu if you have one
let me know if we need to go further
rhodnhelm
go to the asus site
support
downloads
select from right hand side motherboards skt754 k8v-mx hit search
select o/s and there are your drivers
Oct 30, 2008 | ASUS K8V-MX Motherboard
UPGRADING P 3 PC
THE SE440BX2 MOTHER BOARD CAN SUPPORT P3,P2 PROCESSORS(P3 850 MHZ)....,BUT NOT P4 AND HIGHER VERSIONS...THIS MOTHER BOARD SUPPORTS UPTO 768 MB OF RAM,NOT MORE THAN THIS...
Aug 19, 2008 | Intel Pentium 3 , 450 MHz Pentium III...
Intel mother board d845gbv
Zarta -
I don't recommend removing the cooling fan from the CPU. Taking away the cooling system will cause catastrophic overheating, and you'll burn up the processor. Perhaps first you should try adding an AGP or PCI video card to the system, and see if you get display output that way.
You also may need to check Intel's specifications for that motherboard, make sure the processor you have is supported by the system. If you try to use a faster cpu than what the motherboard is rated for, you'll always have trouble.
Hope this helps!
-thinstatic
Jun 12, 2008 | Intel D845GBV (BOXD845GBVL) Motherboard
Intel Motherboard Logo
82 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
