Question about Panasonic PT-47WX49 47" Rear Projection Television
Pt47wx49e hello, my tv turns on and shuts off right away any ideas please?
  • 1 more comment
  • Anonymous Dec 11, 2008
    it blinks 3 times
  • Anonymous Jan 04, 2009
    I'm having the same problem- I replaced the r517 resistor and I still have the same problem. Once the TV goes off I hold the power button but nothing happens-
  • crownroyal19 Feb 04, 2009
    On a PT-47WX79E, Chassis DP820, I have the same problem. I checked R517and it is still good. The led light does not blink at all when the tv shuts off by itself. I turned it on and held down the power button down the entire time and no led light blink when it shut off. I turned it on and waited until it shut off and pushed the power button and no led blink. Would appreciate any other suggestions.
  • 3 Answers
Check resistor r517 if burnt replace with a carbon resistor 10k at 1/4watt.
Posted on Dec 20, 2008
  • Panasonic Master
  • 8,617 Answers
Does the led blink? If so how many times does it blink when trying to press power when it shuts off
Posted on Jul 19, 2008
Hi, my Panasonic PT47WX49E rear projection tv suddenly shut itself off. It won't turn back on at all unless I unplug it and plug it back in. However, when I do that, the power light comes on but nothing...
Either give me a yahoo or note if light on front of set blinks--count the blinks if it does.
most common is 3 blinks, pause 3 or 5 blinks etc.
Let me know if I can assist you.
SD TECH
Sep 14, 2010 | Panasonic PT-47WX49 47" Rear Projection...
How to turn off CC without original remote27ms4504
Noway to turn off captioning right away without the original remote.But U can unplug the tv for an hour,tv well reset itself back to original setting.The Captioning will shut off buy itself.Because captioning reqiure CC buttion on orignal remote and must manually turn on and off.
Feb 08, 2010 | Philips 27MS4504 TV
My tv will work for like 5 min then it shuts off
Sound like you have a overheating problem. Your capacitors might have reached their end of life thus making them overheat quickly. Try to check if there is a fan inside your TV. If there is a fan, try to clean it see if that helps.
I hope this helps. Have a nice day.
- HotRatchet
Dec 14, 2009 | RCA TruFlat 27F520T 27" TV
Tv turns off will turn on then off right away
the internal overload sensor is engaging to protect the system. The parts cost to replace the faulty board is about $70 But you need the skills to open the tv and change it I recommend you get a professional to do it More expensive of course but a lot safer.
Sep 19, 2009 | Planar PDP-42BK 42 in. Plasma HDTV
I have a two year old sharp flat screen tv recently when you turn it on it shuts off right away.
hello sir
i gues that u r facing a ignition panel problem.
its not bu u need to replace it with newer one that fit to ur tv.
if this is not helping u tell me so i can help u further if this is not helping u tell me.
plaese rate this post.
Aug 23, 2008 | Televison & Video
VS-45607 Rear Projection Television
Resoldered connector DY on the yokes and check caps C411, 2200uf/35v and C412, 10uf/50v on main pc board.
Bill
May 04, 2008 | Mitsubishi VS-45607 45" Rear Projection...
1996 sony projection tv model kp46s17
does the tv realy shut off or does the pic go away sounds like bad tube
Nov 03, 2007 | Sony KP-61V75 61" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
410 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
