The first thing I would check is the breaker for the oven at the breaker box. I have encountered similar problems and a partially thrown breaker ( or one pole of a double-pole breaker) can cause this. Find your "range breaker" in your breaker box and cut it off then flip it back on. There is a good chance that might fix your breaker. If it is an older house with fuses, then the range would be on two fuses and one of them is blown. This happens to dryers also (if the right fuse/breaker goes, the motor runs but it won't heat)
Hope this helps
