Question about Panasonic PV-GS250 Mini DV Digital Camcorder
Switches between modes!
Please help, the wheel used to select different modes of use for the camcorder (record, play-back, still photo, etc) has been damaged and the cam occasionally switches modes mid-play-back etc. Where can I have it fixed. I love my camera and use it often. Please help, thanks!
  • 594 Answers
If you would be kind enouph to give me your zip code I will be glad to give you a list of repair man close to you.
Posted on Dec 22, 2008
How do i make this product 16:9? it seems to not let me.
See Page 39 of the Online Manual - link below
Goto Camera Menu> Camera Setup > 16:9 > On/Off Make sure you are in camera Mode - see page 46 - modes 16:9 can be used in See also page 77, for details of how 16:9 can be set and used - see below
  • The 16:9 mode is an electronically processed effect.
  • The 16:9 mode cannot be selected in the Easy Recording mode.
  • The multi-image screen cannot be used when the 16:9 format is selected.
  • Simultaneous recording on a memory card cannot be used when the 16:9 format is selected.
  • If you play back a 16:9 recording on a normal TV, the image appears vertically “squashed” (compressed).
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Apr 06, 2010 | Canon MV730i Mini DV Digital Camcorder
Malfunctioning One-Touch Navigation & Joystick Control
You can try first a reset from menu, then , if firmware is available you can reinstall firmware.
Sep 11, 2008 | Panasonic PV-GS300 Mini DV Digital...
How to switch from sp to lp mode when playing back?
Did you try setting the rec mode to SP in the playback menu?
a54f98a.jpg This is from the D250 manual.
Dec 18, 2007 | JVC GR-D250 Mini DV Digital Camcorder
What are the differences in the record modes? (HQ, SP, & LP)
The amount of recording time on a disc depends on the recording mode selected. The approximate recording time for each of these modes is listed below:
  • HQ (High Quality): Recordable time is up to 20 minutes.
  • SP (Standard Play): Recordable time is up to 30 minutes.
  • LP (Long Play): Recordable time is up to 60 minutes.
  • NOTE: If you record in LP mode, the quality of the scenes may be degraded, or scenes with quick movement may appear with a block noise when you play back the disc.
    Jul 08, 2009 | Sony Handycam DCR-DVD92 DVD Camcorder
    Sony TRV308 Camcorder is not picking up light when recording
    Hi there and welcome to FixYa.
    Do your videos come out dark when you play them back? Or Is it dark while you are recording?
    If it's dark while you are recording, is it dark in the viewfinder, or the LCD screen?
    If your videos come out dark when you play them back, check the manual exposure. Hit the exposure button and turn the sel/push execute wheel to change the exposure to lighter.
    If you are looking through the view finder to record and it's dark, check to make sure the window is clean.
    If your LCD screen looks dark while your recording, put the power switch to player, hit the menu button and scroll down to LCD, select it and turn the select wheel to brighter.
    I had to guess at what your problem was due to the information you provided, so I tried to cover the most obvious. If I failed to answer your question, please comment and be more specific.
    Hope this helps, and thank you for coming to FixYa.
    Rob
    Mar 20, 2009 | Sony Video Cameras
    Mode for playback of older 8mm tapes using Sony DCR-TRV730 ?
    In 1990s Sony camcorder records movie in analog format so playing in digital camcorder like DCR-TRV730 doesn't mean it will be converted in digital format and you can not import file in PC for editing purpose. You will get analog signal while playing back old cassettes.
    Regarding SP, LP speed, its decided at time of recording. Camera sens SP or LP automatically in playback and set itself accordingly.
    If you want to convert old cassettes into digital format, connect our camcorder to DVD recorder and burn DVD which is digital format, copy DVD files in to PC and do desired editing.
    Nov 24, 2008 | Sony Handycam DCR-TRV730 Digital Camcorder
    Format a cd
    First some explanations:
    The Canon DC210 will only take 'minus' format DVDs (DVD-R, DVD-R DL and DVD-RW). Only the DVD-RW must be formatted (initialised) before use. During initialisation you'' be asked whether you want to initialise the disc in VIDO mode or in VR mode.
    VIDEO mode: Once finalised discs recorded in VIDEO mode can be played back in most common DVD players, offering the best compatibility. However, recordings cannot be edited (deleted, rearranged etc) on the camcorder.
    VR mode: You can easily edit the recordings on the camcorder. However, discs recorded in VR mode can only be played back with DVD players that are compatible with DVD-RW discs in VR mode.
    My preference is Video mode - I can then play the disc on a DVD player and edit it on a PC.
    Now, to initialise a DVD-RW
    1. Press the 'FUNC.' key
    2. Use the joystick to select 'MENU' - it's in the bottom left corner of the screen
    3. Use the joystick to select 'DISC OPERATIONS'
    4. Use the joystick to select 'DISC INITIALIZE'
    5. Use the joystick to select either 'VIDEO' or 'VR' mode
    6. Use the joystick to select 'YES' to confirm your choice
    7. Use the joystick to select 'YES' to start initialising the disc
    Close the menu only after the screen display returns to the 'DISC OPERATIONS' menu.
    Don't forget to rate this solution once you've tried it !
    May 11, 2008 | Canon DC210 DVD Camcorder
    BLACK SCREEN IN RECORD MODE
    I have the same problem faillure of the CCD-chip. when your camcorder is produced between 2000 and 2004 you can have this problem. Problem also known in other fabricats ( sony etc.) Sony repairs it for free. Samsung refuses this
    Aug 26, 2007 | Samsung VP-W90U Camcorder
    Record button doesn't function
    You may want to check the record lockout safety switch located on the tape. This button can get moved by accident and the camera will refuse to record on that tape. Also, be sure the camera is in "video" mode, not "photo" mode. Some of Canons camcorders have a digital still camera mode which stops the camcorder from functioning because the photos are being recorded to a memory card and not your tape, please check this swithc as well. Good luck. Joe Weibel customelectronics.org
    Feb 26, 2007 | Canon Elura 65 Mini DV Digital Camcorder
    Recording sound on video.
    Audio Dubbing may vary by model. Most Digital Camcorders are equipped with this feature. To verify that your model is, please view the User Manual. Audio Dubbing * The AUDIO DUBBING function only works in PLAYER Mode. * You can add sound to the original sound on a pre-recorded tape, recorded in SP mode with 12bit sound. * Use the internal and external microphones or other audio equipment. * The original sound will not be erased. Dubbing sound 1. Set the camcorder to PLAYER mode. * If you want to use an external microphone, connect the microphone to the external MIC input jack on the camcorder. * When you wish to dub using the External A/V input, connect the AUDIO/VIDEO cable to the camcorder by inserting the cable jack into the A/V in/out terminal at the left side of the camcorder. - Press the MENU button, turn the MENU DIAL to highlight A/V and press the ENTER button. - Turn the MENU DIAL to highlight AV IN/OUT and press the ENTER button to select AV IN. 2. Press the (PLAY/STILL) button and find the timeframe of the scene to be dubbed. 3. Press the (PLAY/STILL) button to pause the scene. 4. Press the A.DUB button on the Remote Control. * A.DUB will be displayed on the LCD. * The camcorder is in a ready-to-dub state for dubbing. 5. Press the (PLAY/STILL) button to start dubbing. * Press the (STOP) button to stop the dubbing. Notes: * You can not use the audio dubbing function while playing a write protected video tape. * When you wish to dub using the External A/V input, you must connect the AUDIO/VIDEO cable to the audio system from which you wish to record. * You cannot dub sound on a pre-recorded tape in LP or 16 bit mode. Dubbed audio Playback 1. Insert the dubbed tape and press MENU button. 2. Turn the MENU DIAL to highlight A/V. 3. Press the ENTER button to enter the sub-menu. 4. Use the MENU DIAL to select AUDIO SELECT from the submenu. 5. Press the ENTER button to enter the sub-menu. 6. Using the MENU DIAL, select the AUDIO playback channel. Press the ENTER button to confirm the audio playback channel. * SOUND1 : play the original sound. * SOUND2 : play the dubbed sound. * MIX(1+2) : play back SOUND1 and 2 equally mixed. 7. To exit, press the MENU button. 8. Press the (PLAY/STILL) button to playback the dubbed tape. Note: When you playback added sound (SOUND2 or MIX mode), you may experience loss of sound quality.
    Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
    Panasonic PV-GS250 Mini DV Digital Camcorder Logo
    61 people viewed this question
    Top Panasonic Video Cameras Experts
    Kenneth Walker
    Pieter Vleeshouwers
    Pieter Vleeshouwers
    Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
