Cars & Trucks Logo
Posted on Jan 28, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My 2001 has warning signals in the dash board where there is a symbol of the four wheels of the car. In this symbol, the lights of the front two wheels are blinking, but not the lights of the two rear wheels. What does that mean? THank you.
Anonymous
Level 2:
New Friend:
  • Expert 118 Answers
  • Posted on Jan 28, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
118
Questions
0
Helped
32902
Points
357
This means there is a problem with the four wheel drive
2answers
Light on dash with open wrench nd four wheels with front wheels turned
The light is a service needed reminder, consult the dealer or your owners manual for details
Warning light comes on and beeps now and again
the lamps are all marked, at to what they are
in words or icon symbols.
they are called warning lights. the operators guide covers them.
if lost, get one at citroen.
or
luck out here( the endless list)
http://dashboardsymbols.com/the-symbols/
if still not sure send a photo (below) add image, of the lamp.
2answers
Dashboard lights - 2001 toyota corolla
May not be any fuse and if it was other things would not work either. It is most likely the sitch that controls the running and dash board lights.
Warning light on dash board, skid back wheels
his means your traction control is switched off. Somewhere on the dash or near the gear selector is a button with a similar symbol that has probably been pressed by accident. Press the button to turn traction control back on
I don't know how to get my 2001 kia sportage into four wheel drive
On small shift behinde gear lever there is 3 settings. H4 = 4 wheel drive high range, L4 = 4 wheel drive low range, h2 = 2 wheel drive high range. as soon as jou engage to 4 wheel drive a green light on the dash board will appear to indicate that the car is in 4 wheel drive. if not check fuse - check air pipes at front wheels. Enjoy Willem Sa
2001 Dodge Grand Caravan. Dash board stopped
sounds like an electrical nightmare! start by removing the cluster,now try signals are they working if yes then bad cluster, also i had a few caravans that just had bad connections i removed the plugs and reconnected them and it worked fine, also with the light coming on with your foot on the brake may be a bad or in correctly installed bulb, check all brakeand signal bulbs, try all of this , good luck,hope this is helpful.
Two years ago my four wheel drive stopped working. I wasn't using it at the time and the dash light came on...and since then it hasn't worked. Just wondering what the problem might be?
i had a problem with the four by four light coming on all the time. I would shut the vehicle off and the warning went away. Recently I had the bearings and tie rods changed on the two front wheels, and now the four by four light does not come on anymore. Not sure if they are related, but it seems to have fixed the warning light. You might want to get your alignment checked and if it keeps going out, then it may be loose tie rods. Hope this helps.
3helpful
2answers
2001 kia sportage 4wd
replace vacuum hoses they are located just out side shock towers front end
Four wheel drive is not engaging when you turn the swith
it is usually the sensor or the control button itself on the dash if you have an owners manual check in there for a fuse or a relay if no manual look under the dash on drivers side for the fuse box and under the hood for the relay box
Top Mitsubishi Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Mitsubishi Expert? Answer questions, earn points and help others
