Question about Clarion XMD3
XMD3 unable to select anything but satellite
Clarion XMD3 came with a new boat in 2005 and has worked fine until this season. When I turn on the radio it goes right to Sirius and I cannot get it to select tuner, aux, etc. It keeps telling me to call the sirius number. I never bothered to activate the satellite since we do not use the radio very much - not until gas got so expensive anyway.
I have had several problems like that. It is probably one of your controllers especially if you have the old oval ones. Go to the back of the stereo and unplug them, then plug one in at a time and isolate the problem to a controller.
Posted on Sep 02, 2008
I have a Clarion Marine XMD3 radio in my boat. There is a set of speakers in the back of the boat and a set in the cabin below deck. The set in the below deck cabin work fine. The set in the back of the...
Look for loose or broken wiring connections. Swap front and rear speakers wires at radio and determine if problem is the radio or the speaker system.
Aug 01, 2013 | Car Audio & Video
I have a Clarion XMD3 am/fm marine cd player that came with my 2000 Searay boat. I was somehow able to turn the inside cabin speakers off last season and only have the outside speakers on. I must have...
Might be set on mute !
Mute instructions
Use this function to turn off the sound immediately.
1. Press the [ M ] button.
The sound turns off and "MUTE" appears in the display.
2. Press the [ M ] button again to cancel the mute mode
in this other user manual it is a mute button[m] page 4
http://www.clarion.com/us/en/MungoBlobs/552/388/XMD3.pdf
or
Adjusting the fader
1. Press the [ A-M ] button and select "FAD 0".
2. Press the [ w ] button emphasizes the sound from the front
speaker, press the [ z ] button emphasizes the sound from the
rear speaker.
? The factory default setting is "FAD 0". (Adjustment range: F12 to
R12)
3. When the adjustment is complete, press the [ A-M ] button
several times until the function mode is reached
May 04, 2017 | Clarion XMD3-RET AM/FM MARINE CD PLAYER
Clarion XMD3 No Sound
instead of trying to put a new head unit on it i would get a new wiring harness might have some bad connections in that if that doesnt work a new cd player would be the way to go can get a brand new one at abc warehouse for about 75 bucks
Jun 10, 2010 | Clarion XMD3
Bass and Treble controls
Use Z-enhancer to select custom (you may have to hold it down for 2 secs)
A-M button then selects or bass treble settings.
volume up/down changes the setting
May 19, 2010 | Clarion XMD3
Can't get sound to come out of rear speakers.
go to the menu and select fade f/r then adjust until happy should be in the middel
Jun 13, 2009 | Clarion SIR-CL1 SIRIUS Radio Receiver
No Sirius function available.
I have the same problem. When scrolling through the source options, the display goes from tuner-cd-aux and back to tuner...no sat. radio. need help.
May 29, 2009 | Clarion XMD3
Clarion Marine XMD3 / SIR-CL1 Sirius Troubleshooting
I had the same problem with invalid channel on all channels ! Had to reset the siriuss receiver by removing power for 15 sec and restoring! that means not just shuting it off but removing all power to the sirius unit not the clarion unit itself and reastablishing power to it turning on the clarion head unit and walah! satelite would recieve ESN and 184 and programing! Hope it works for you after 3 long waiting periods on the phone!
Oct 21, 2007 | Clarion SIR-CL1 SIRIUS Radio Receiver
NO SOUND FROM CLARION XMD3
I have a XMD3 with Sirius on a Larson boat. Had same problem - everything seemed to be fine on unit (everything lit up and CD showed different tracks and time changing), but no sound. I suspected a ground problem and checked wires I could see. Found one speaker wire that had been frayed due to faulty installation. As soon as I wiggled that wire I got sound on all speakers. Not sure why one faulty speaker would kill all sound, but it did for me.
Oct 19, 2007 | Clarion XMD3
Clarion Xmd3
Bottom line is that boats are a hrsh environment for electronics. Moisture, salt, and vibration all conspire to undo solder joints and electrical connections. 4 years is a pretty good life span on a boat. A solder connection within the unit could have let go. A good repair shop could probably fis the bad connection but you can probably replace the unit for less.
Jun 26, 2007 | Clarion XMD3
Clarion XMD3 Logo
239 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
